Wireless
8373 Discussions
intel ax211 ngw not detected
Yoann44
Bonjour,
j'ai un laptop sous WIN11 il ne détécte pas la carte wifi malgrès mise à jour des drivers et du téléchargement de BT-22.250.0-64UWD-Win10-Win11.
Quand j'échange avec une autre carte wifi autre je n'ai pas de soucis.
Nom de l'appareil LAPTOP-80QIQM0V
Processeur AMD Athlon Silver 3050U with Radeon Graphics 2.30 GHz
Mémoire RAM installée 12,0 Go (9,88 Go utilisable)
Type du système Système d’exploitation 64 bits, processeur x64
Cordialement
Jose_Intel
Hello @Yoann44
Thank you for posting on the Intel️® communities.
We understand you are installing a new wireless adapter to your system.
Please answer the following:
·      Was it working before?
·      Have you contacted the system manufacturer in order to verify compatibility?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
3Fees
Intel AX211 runs with Intel 600 series chipset. Try Intel AX210 since you have a AMD chipset.
Intel AX211 fonctionne avec le chipset Intel série 600. Essayez Intel AX210 puisque vous disposez d’un chipset AMD.
Cheers
3Fees
Jose_Intel
Hello Yoann44
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you still need assistance by sending the required report.
Jose B.
Jose_Intel
Hello Yoann44
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
