Summary: Invalid buffer destination in iwlwifi during startup
Description:
The following iwlwifi error message appears during startup:
19:48:52 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
System Information:
- Distribution: Ubuntu 22.04
- iwlwifi Version: 6.5.0-35-generic
- Firmware Version: 83.e8f84e98.0 so-a0-gf-a0-83.uc
- Wireless Hardware: Alder Lake-P PCH CNVi WiFi
Additional Information:
This message does not affect wireless functionality but should be reviewed.
Hello MohammadEtemaddar,
Please generate an SSU report to help me further analyze important details on your system, such as the complete model of your system, the complete model of your Wi-Fi network adapter, etc. To generate the SSU report, please refer to the article: Intel® System Support Utility for the Linux* Operating System. Please send us the generated SSU.txt file.
And also, may we know when you first noticed this error message? And did you attempt to troubleshoot the issue? If yes, please share those troubleshooting steps that you have performed so we can avoid repeating them.
We look forward to your response!
Carmona A.
Hello @ACarmona_Intel
I have the same issue on Arch Linux localhost 6.9.5-arch1-1 #1 SMP PREEMPT_DYNAMIC Sun, 16 Jun 2024 19:06:37 +0000 x86_64 GNU/Linux
As you can clearly see, @MohammadEtemaddar is running Linux as well. How on Earth is he supposed to run some Windows utility?
The issue is probably with iwlwifi.
Some info:
Network: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
[ 23.859290] iwlwifi 0000:03:00.0: loaded firmware version 89.e9cec78e.0 ty-a0-gf-a0-89.ucode op_mode iwlmvm
Error:
[ 24.563316] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
Things I've tried:
sudo iw dev wlan0 set power_save off
/etc/modprobe.d/iwl.conf
options iwlmvm power_scheme=1
options iwlwifi power_level=5
options iwlwifi power_save=false
Any help is appreciated! (and the formatting on here sucks too)
Hello Penpal
Please file a new case so that we can properly support you.
Intel Support: https://www.intel.com/content/www/us/en/support.html
By the way, I'm truly sorry, it should be Intel® System Support Utility for the Linux* Operating System.
Thank you for your understanding, and have a great day ahead.
Carmona A.
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
istg ur a bot and u cant help people running linux
this forum is so unhelpful and has even locked my previous account behind some MFA so im just creating new ones at this point
To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file..
ON WINDOWS!!!
op has already provided enough info wdym more info do u need his social security number too???? like wtf
oh and what's that? Ubuntu? some sort of Windows microsoft-spyware edition ig???
System Information:
+1 on openSUSE Tumbleweed
I hit the same issue using OpenSUSE Tumbleweed. It appears to be impacting Linux users on rolling distros like Tumbleweed and Arch. I found that with the normal BIOS settings, my laptop (Framework 13) would not find any available networks. If I changed the BIOS wireless setting to Fallback (I think that was the setting) vs. Default, it would find the networks but when attempting to join it would cycle with quick failures in a loop. I had to rollback to a prior kernel snapshot and my wifi is now working fine.
We are checking in with you, as we have not heard any response from you.
Carmona A.
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
Hello @ACarmona_Intel,
I encountered the same issue on Fedora 40, with a Lenovo Yoga Pro 7.
I'm sending the requested file as well.
In case it helps, I had the exact same issue on Ubuntu 24.04.1 LTS with kernel 6.8.0-45-generic and iwlwifi-so-a0-gf-a0-86.ucode. It appears the most recent 89 ucode was not solving anything either but an old one especially iwlwifi-so-a0-gf-a0-73.ucode.zst is solving the issue for me.
[ 3.316140] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 3.316375] iwlwifi 0000:00:14.3: loaded firmware version 73.35c0a2c6.0 so-a0-gf-a0-73.ucode op_mode iwlmvm
[ 3.678865] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x430
[ 3.865005] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 3.865037] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 3.865069] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 3.865077] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 3.865294] iwlwifi 0000:00:14.3: loaded PNVM version 35148b80
[ 3.881872] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[ 3.952364] iwlwifi 0000:00:14.3: base HW address: 30:f6:ef:a1:c8:4f
[ 4.671713] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 4.671746] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 4.671756] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 4.671767] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 4.769024] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
The ucode is loading properly, I don't have those "WRT: Invalid buffer destination" errors anymore.
And I was able to configure the wifi.
