As said in title, boot time extends by 60 seconds waiting for iwlwifi.
The Intel adapter is as follows according to lspci :
00:14.3 Network controller: Intel Corporation Cannon Lake PCH CNVi WiFi (rev 10)
And here is the dmesg output pointing to iwlwifi :
[ 6.373095] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 65.517047] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
[ 65.620467] kauditd_printk_skb: 115 callbacks suppressed
What can I try to maybe load another firmware, or otherwise get these 60 seconds of boot back ?
Hello and thank you for your answer.
As it happens, I solved the issue by deleting all remembered Wifi connections that I didn't use, keeping only the one I have at home.
It immediately made NetworkManager load instantly instead of waiting 60 seconds.
Thanks again,
Best regards
Hello alb1,
Thank you for posting in the communities. To help you with the slow boot, we need to first make sure to be more familiar with your system. Would you be able to share with us your SSU logs? I will be waiting for your reply.
Ramyer M.
Thanks again,
Best regards
Hello alb1,
I'm delighted to hear that you've resolved the issue with NetworkManager's loading time by removing unused Wifi connections. It's a smart troubleshooting step!
If you encounter any further issues or have additional questions, feel free to reach out. Your proactive approach to solving this problem is commendable, and we are here to assist you with any future technical challenges.
Norman S.
