Hi, I am using the HP EliteBook X360 1030 G2 notebook and with inbuilt WiFi adopter Intel Dual Band Wireless AC 8265 and my issue is that my Wi-Fi download speed is in Kbps and upload speed is 80 Mbps due to this Skype is not logging in and website is opening very slow outlook mails are stuck in outbox and we have already replaced the main board and WiFi adopter with HP as Notebook is under warranty and we are using windows 10 1803 version
- « Previous
- 1
- 2
- Next »
Dear Intel Team,
i have found the solution myself to do lots of research on mentioned case
We have to manually disable RSC following these steps:
1. Hold the Windows Key and Press X.
2. Choose Windows Powershell (Admin) from the context menu.
3. Type powershell Get-Netadapter and note down the value under Name for your Wifi.
4. Then type, powershell Get-NetAdapterRsc when you do this it will show you the current values, if it is False, then it is already disabled
5. If it is True, then disable it by typing powershell Disable-NetAdapterRsc -Name WiFi
6. Replace the value for -Name with the name of your Wifi.
Verify that the values are disabled by typing powershell Get-NetAdapterRsc.
Then test Wifi slowness will be resolved
Kind Regards
DKumar
i am a bit surprised why intel is not able to provide the solution
- « Previous
- 1
- 2
- Next »
