Wireless
6692 Discussions
scheda di rete compaq 6710b
tondam
(it) notebook compaq 6710b window 10 scheda di rete wifi pro / wireless 3945abg
vorrei sostituire la scheda wifi con una piu 'performante, potete indicarmi una piu performante che sia compatibile.grazie
(uk) Compaq 6710b Notebook window 10 gods spread sheet for WiFi / Wireless 3945ABG ha
sostituito la scheda WiFi con un pin ', Service, potete indicarme single pin compatible, Service sia
n_scott_pearson
Super User Retired Employee
My first comment is that any laptop that came with an ABG wireless card is simply too old to make this upgrade worth the effort.
My second comment is that, in many cases, these old laptops used inclusion and exclusion lists in the BIOS to prevent the user from upgrading the wireless card themselves. I usually recommend that you check with the laptop vendor to find out if this is the case.
The Pro/Wireless 3945abg card utilizes the original Mini PCIe connector. The recommended replacement for this card would be the Wireless-AC 7265. The version of this card that you want to look for is the 7265HMW; this is the one that is designed for the Mini PCIe connector. You specifically do NOT want the 7265NGW; this is designed for the M.2 connector, which you do not have.
Oops, almost forgot: your existing card is a full-length Mini PCIe card while the replacement is a half-length Mini PCIe card. If the laptop has the screw hole for the shorter cards, great. If not, you may need an extender bracket to make this work. Here is an example of what this extender bracket looks like: https://www.amazon.com/Pocaton-Express-Bracket-Adapter-Wireless/dp/B072R2NQQS (yes, it's just a piece of metal to make the card longer).
Hope this helps,
tondam
thanks it was useful. the notebook is used with ADSL line, the 7265HMW card should improve the download of the transmission as the 3945abg goes to 50mbs and the 7265HMW
the minimum speed is 300mbs.
grazie e' stato utile .il notebook viene utilizzato con linea adsl , la scheda 7265HMW dovrebbe migliorare il download della trasmissione visto che la 3945abg va a 50mbs e la 7265HMW
la velocita minima e' a 300mbs.
n_scott_pearson
