Wireless
8534 Discussions
wifi replacement
alirezaxix
I want to change my laptop's Wi-Fi. Is intel wifi 7 be200 compatible with the 11th generation Intel processor?Laptop model asus tuf 15 fx506lm core i7 11800h with mediatek 7921 wifi card . it always disapper icon with all updates even . ....maybe its is e key m2 slot. .can i replace BE200 on it ? or any suggestion other models for it ?photo_2_2025-09-15_01-05-36.jpg
AlHill
You need to consult with the laptop manufacturer for anything regarding laptop integration.
[AI is the same as snake-oil]
DigitalBoy
You can install any model (older or newest) compatible with your m.2 key slot. This module is with key "A+E"?
DigitalBoy
I've seen Intel BE20x installed on OEM PC desktop of 10 years ago, but maybe for notebook/laptop is different. Well, to send an e-mail to Asus is easy and fast, and he has the security of compatible piece at 100%... Maybe is better.
alirezaxix
some people who has mylaptop  installed ax21 and problem sloved.
DigitalBoy
Ok, if some user with your same laptop has this module and work fine, maybe is a secure solution for you too... Maybe you can ask that on Reddit for a confirm from other Asus Tuf 15 fx506lm users?
alirezaxix
yes. its e+a slot. ....they(asus) do not answer me .also noone here dont know. this mediatek wifi has problem itself. i should change it
