Wireless
8718 Discussions
wireless module for Win 11
jeffw723
I have a new ASUS MB (ProArt B-760 Creator D4), that requires an add-on WiFi module.
It allows an M.2 Wi-Fi module (E-key, type 2230).
I found the Intel Wi-Fi 6 (Gig+) Desktop Kit, AX200, 2230, 2x2 AX+BT, vPro on Amazon
However, this is what it says in the description:
  • Compatibility: Only for use on Intel Windows 10 64-bit machines, that are not currently on a BiOS lock, and do not contain an Intel 9560 CNVI part.
I'm installing Win 11. Does this mean it just won't work on Win 11?
If not do you have a newer product / upgrade that is compatible with Win11?
Thank you!
--Jeff
Catulpos_Intel
Hello jeffw723,
If I may put an input here, please be informed that Intel® Wi-Fi 6 AX200 Gig+ is compatible with windows 11 as it is indicated on the supported platforms. For your complete reference on the wireless adapter specifications, you can check out the link below.
Link: https://www.intel.com/content/www/us/en/products/sku/189347/intel-wifi-6-ax200-gig/specifications.htmly
You can also check the product specifications of another wireless adapter through the link below.
Link: Intel® Product Specifications
We hope this helps and since we answered your query, we will now go ahead and close this one. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Thank you and have a nice day!
JCatulpos
n_scott_pearson
I have no idea where that comment came from. I use AX200 cards on Windows 11 machines without issue. Perhaps the comment precedes the Windows 11 release (it does mention the 9560 card, which is a 2017 product)?
I actually recommend that you purchase a kit with the AX210 card instead. It's typically $10 more, but it also gives you support for WiFi 6e and the 6 GHz communication band. I don't see a full kit that includes a genuine Intel AX210 card, but I do see kits with 3rd-party cards that utilize Intel's AX210 module (and use the same drivers from Intel).
Hope this helps,
Catulpos_Intel
Hello jeffw723,
JCatulpos
