При попытке установиться oneAPI Base Toolkit появляется следующее окно:
Устанавливаю его на Visual Studio 2019 версии 16.11.7. При установке Visual Studio в качестве дополнительного пункта установки было выбрано "Разработка классических приложений на C++", так как программа необходима для дальнейшей установки компилятора Intel Fortran. При проверке в Visual Studio 2019 я не смог обнаружить oneAPI Base Toolkit, хотя, возможно, я просто не доглядел. Прошу помощи.
We only provide support in English. I have translated your question.
" When you try to install the oneAPI base toolkit, the following window appears:
I install it on visual studio 2019 version 16.11.7. when installing visual studio, "developing desktop applications with c++" was chosen as an additional installation item, since the program is required for further installation of the Intel Fortran compiler. when checking in visual studio 2019, I couldn't find the oneAPI base toolkit, though maybe I just didn't. I'm asking for help."
Could you please confirm whether this reflects your question correctly?
Vidya.
Hi PhasGerd,
Thanks for the confirmation. Based on the provided details, we would recommend you try integrating the Intel® oneAPI Base Toolkit with a compatible version of Visual Studio build (such as VS 2019 16.10.3) from the below link.
Intel® Compilers Compatibility with Microsoft Visual Studio* Info Link: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-...
Make sure to select the 'Desktop development with C++' component while installing it, as before. Since it would change the order of installation, please repair the Intel® oneAPI Base Toolkit 2021.4 after you are done installing Visual Studio.
Please let us know if the issue persists with the compatible version of Visual Studio installed. Kindly get back to us with a copy of the Info (using 'Copy Info') from 'About' of the Help section of Visual Studio. It will allow us to check further.
Soumya
Hi PhasGerd,
Please let us know if there are any further concerns.
Soumya
Hi PhasGerd,
We understand that you might be looking into the issue. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this thread active.
Soumya
Hello, thank you, but it didn't help, even on the version of Visual Studio 2019 16.10.3 Intel oneAPI gives an error during installation
Hi PhasGerd,
Thanks for providing the update on the post. Please let us know the below details.
- Did you select the component: 'Desktop development with C++' while installing the Visual Studio?
- Was it a clean installation of the Intel® oneAPI Base Toolkit?
- The version of the operating system
- The installation log file (of the latest install process) from the path: %tmp%\intel_oneapi_installer\
- A copy of the Info (using 'Copy Info') from 'About' of the Help section of Visual Studio.
- Is there any other version of Visual Studio installed on the system, at the same time as Visual Studio 2019 16.10.3?
- Is it the exact same error? If not, please provide a screenshot of the current error.
The information will allow us to check on the issue further. Looking forward to your update.
Soumya
Hi PhasGerd,
Please let us know the requested details. They will allow us to look into the issue further.
Soumya
Hi PhasGerd,
Soumya
