oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Aggiornamento firmware TPM 2.0
Mik_99
Windows 11
Produttore Intel TPM ver. produttore 11.7.03290 ver. specifiche 2.0
Messaggio errore: è necessario un aggiornamento del firmware per il processore di sicurezza TPM
Non vi sono indicazioni utili per eseguire l'aggiornamento sul sito Intel e Microsoft
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
Mik_99
Hi I apologize but I don't have much knowledge of the English language.
I have attached the report of Intel Driver & Support Assistant. Thanks
Mik_99
The report has been saved in text format. Thank you
AlHill
You have an 8th gen processor (i5-8250U) which is supported by Windows 11.
There should be no issue with PTT (TPM).
You may want to RUN TPM.MSC to determine if TPM is turned on in your BIOS.
Mik_99
Translation
Preview
This snap-in displays information about the TPM of your computer and allows administrators to configure the device, as well as view and manage the commands supported by that device.
Status
TPM ready for use
Available options
You can clear the TPM to remove properties and restore the TPM to its factory settings
AlHill
Ok, so what is the problem?  Your TPM (PTT) is working as it should be.
Mik_99
Error message:
A firmware update is required for the security processor (TPM)
I can't find the update on the Intel website
AlHill
Update the bios on your motherboard/device.
Mik_99
I will update the motherboard BIOS as soon as possible.
I am in Italy and you?
Many thanks for the moment.
