oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1641 Discussions
BaseToolkit 2022.1.3.210 installation failure
robertodias
Hi, windows crashed during the installation of BaseToolkit 2022.1.3.210. Now, after recovery, every time I try to reinstall the toolkit, I get the following message from the installer: "Installer has failed. The application has encountered errors which caused failure. For more details, click on the log link at the bottom of the dialog." When I try to click, I get "cannot open the link". Then, at the command prompt, I specified a log file and got the following log in which I can't see any problem. Is there a way I can fix it?
16.03.2022 08:23:26 : 3100 : Start
16.03.2022 08:23:26 : 3100 : Web Image Build Info: Package ID: w_wi_p_2.0.0.027 , May 27 2020 15:27:53
16.03.2022 08:23:26 : 3100 : === Parse Command Line ===
16.03.2022 08:23:26 : 3100 : Command Line: "C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline.exe" -l log2.txt
16.03.2022 08:23:26 : 3100 : === Load default configuration ===
16.03.2022 08:23:26 : 3100 : InitLCID: UserDefaultLCID: 1046
16.03.2022 08:23:26 : 3100 : SetZipArchiveFileName: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline.exe
16.03.2022 08:23:26 : 3100 : SetExtractFolder: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline
16.03.2022 08:23:26 : 3100 : SetAppToLaunchAfterExtracting: bootstrapper.exe
16.03.2022 08:23:26 : 3100 : SetSupportedLCIDs: 1033
16.03.2022 08:23:26 : 3100 : SetSupportedLCIDs: current LCID: 1033
16.03.2022 08:23:26 : 3100 : SetHideExtractFolderDialog: 0
16.03.2022 08:23:26 : 3100 : SetRemoveExtractedFiles: 1
16.03.2022 08:23:26 : 3100 : SetRemoveExtractedFilesShowCheckbox: 1
16.03.2022 08:23:26 : 3100 : SetAppGUIMode: Interactive Simple GUI mode
16.03.2022 08:23:26 : 3100 : SetRemoveExtractedFilesRememberUserChoice: 1
16.03.2022 08:23:26 : 3100 : SetNetworkPathProhibited: 1
16.03.2022 08:23:26 : 3100 : WARNING : String Resource 1595 was not found for Language 1033. It will be used from English (1033)
16.03.2022 08:23:26 : 3100 : SetInstallationScopeCmdLineForSetupgPerMachine:
16.03.2022 08:23:26 : 3100 : SetProductName: Intel® oneAPI Base Toolkit
16.03.2022 08:23:26 : 3100 : Get RemoveExtractedFiles from Registry
16.03.2022 08:23:26 : 3100 : === Save Configuration from Command Line ===
16.03.2022 08:23:26 : 3100 : === Open and Verify Archive ===
16.03.2022 08:23:26 : 3100 : Archive is correct zip package
16.03.2022 08:23:26 : 3100 : Archive is not corrupted
16.03.2022 08:23:26 : 3100 : Uncompressed size of archive content is 3777762723
16.03.2022 08:23:26 : 3100 : Max path length of archive content is 142
16.03.2022 08:23:26 : 3100 : === Start Interactive Simple GUI Extracting ===
16.03.2022 08:23:27 : 3100 : Verify Extract folder: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline
16.03.2022 08:23:27 : 3100 : Create secure folder: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline
16.03.2022 08:23:27 : 3100 : Extract folder is correct
16.03.2022 08:23:27 : 3100 : Verify free disk space for: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline
16.03.2022 08:23:27 : 3100 : Free disk spase: 160318824448 ; Required disk space (size of content + buffes in 1 MB for log file): 3778811299
16.03.2022 08:23:27 : 3100 : Free disk space is enough
16.03.2022 08:23:27 : 3100 : SetExtractFolder: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline
16.03.2022 08:23:27 : 7624 : Extracting started
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-1024x1024.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-128x128.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-16x16.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-20x20.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-24x24.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-256x256.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-32x32.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-40x40.png
16.03.2022 08:23:27 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-48x48.png
16.03.2022 08:23:51 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Gui.dll
16.03.2022 08:23:52 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Network.dll
16.03.2022 08:23:52 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Widgets.dll
16.03.2022 08:23:52 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\qt_source_code.txt
16.03.2022 08:23:52 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\README.md
16.03.2022 08:23:52 : 7624 : Extracting: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\third-party-programs.txt
16.03.2022 08:23:52 : 7624 : Extracting finished successfully
16.03.2022 08:23:52 : 3100 : Set RemoveExtractedFiles to Registry
16.03.2022 08:23:52 : 3100 : === Launch Setup.exe ===
16.03.2022 08:23:52 : 3100 : Setup.exe : C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\bootstrapper.exe
16.03.2022 08:23:52 : 3100 : Command line :
16.03.2022 08:23:52 : 3100 : Working Dir : C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline
16.03.2022 08:23:52 : 3100 : C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\bootstrapper.exe was launched
16.03.2022 08:23:52 : 3100 : Child window was NOT found
16.03.2022 08:23:53 : 3100 : Child window was NOT found
16.03.2022 08:23:54 : 3100 : The following child window found: Intel® oneAPI Base Toolkit
16.03.2022 08:23:54 : 3100 : Child window was found
16.03.2022 08:23:54 : 3100 : Waiting end of child process...
16.03.2022 08:24:13 : 3100 : Return Code of child process: 1
16.03.2022 08:24:13 : 3100 : Setup.exe was launched
16.03.2022 08:24:16 : 3100 : === Remove extracted content after installation ===
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\third-party-programs.txt
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\README.md
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\qt_source_code.txt
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Widgets.dll
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Network.dll
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Gui.dll
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Core5Compat.dll
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\Qt6Core.dll
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\platforms\qwindows.dll
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-20x20.png
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-16x16.png
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-128x128.png
16.03.2022 08:24:16 : 3100 : Remove file: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon\oneapi-1024x1024.png
16.03.2022 08:24:16 : 3100 : Remove directory: C:\Users\Usuario\Downloads\w_BaseKit_p_2022.1.3.210_offline\app-icon
16.03.2022 08:24:16 : 3100 : Finish
16.03.2022 08:24:16 : 3100 : WARNING : Return Code is overwrited by Setup.exe return code. [ret code] = 1000 + [setup.exe ret code]
16.03.2022 08:24:16 : 3100 : Return Code: 1001
