oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1673 Discussions
Broken: intel-oneapi-neural-compressor package Version 2.1.0-48866
uwmthdpt
At the end of installing this package this is printed:
done
/opt/intel/oneapi/pytorch/1.13.10.2/../../neural-compressor/latest/install_neural-compressor.sh: 3: /opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/etc/conda/deactivate.d/deactivate-opencl-rt.sh: [[: not found
/opt/intel/oneapi/pytorch/1.13.10.2/../../neural-compressor/latest/install_neural-compressor.sh: 10: /opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/etc/conda/deactivate.d/deactivate-opencl-rt.sh: [[: not found
/opt/intel/oneapi/pytorch/1.13.10.2/../../neural-compressor/latest/install_neural-compressor.sh: 24: /opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/etc/conda/deactivate.d/deactivate-libstdcxx-patch.sh: [[: not found
/opt/intel/oneapi/pytorch/1.13.10.2/../../neural-compressor/latest/install_neural-compressor.sh: 24: /opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/etc/conda/activate.d/activate-libstdcxx-patch.sh: [[: not found
0
Success to install neural-compressor in pytorch-gpu.
Those scripts have a shebang of #!/bin/sh.  On my Ubuntu 22.04 machines that points to the Dash shell which does not support the Bash [[ ]] compound command syntax. Even if /bin/sh were to be symlinked to /bin/bash, Bash would see this and act like a POSIX compliant shell and behave the same. The scripts need fixing.
This version of this package is getting reinstalled over and over again(many times per day) on all our machines due  - I assume - these package issues.
Is anybody else seeing this?
ArpanB_Intel
Hi Erik, thank you for sharing this with us. Please let us now if you are still facing this issue now.
We would like to know.
uwmthdpt
Yes, this is still an issue on multiple machines.
The metadata differences between the current and previous package versions are generally only relating to versioning(Depends,Provides,Replaces,Breaks fields).
intel-oneapi-neural-compressor-2.1.0-47239_amd64.deb
intel-oneapi-neural-compressor-2.1.0-48866_amd64.deb
The new bundled installer script only changes the version of the package installed by Conda and omits the packaging package:
diff 47239/opt/intel/oneapi/neural-compressor/2.1.0/install_neural-compressor.sh 48866/opt/intel/oneapi/neural-compressor/2.1.0/install_neural-compressor.sh
53c53
<         conda install -c "${ONEAPI_PATH}/conda_channel" -y -q neural-compressor-full=1.14.2 packaging --offline
>         conda install -c "${ONEAPI_PATH}/conda_channel" -y -q neural-compressor-full=2.1 --offline
ArpanB_Intel
Erik, we have been intimated that this issue might be addressed now. Please let us know if you are still encountering the issue.
uwmthdpt
This is still a problem. Not sure if it is related but there are 14 errors due to incorrect shell script syntax. See attached log.
ArpanB_Intel
Erik, thank you for the update. We will share a workaround on this issue very soon.
We appreciate your patience.
ArpanB_Intel
Erik, could you try using the following commands:
sudo apt remove neural-compressor
sudo apt autoremove
and reinstalling with :
sudo apt install neural-compressor
ArpanB_Intel
Erik, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
