oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1639 Discussions
Clean up and reinstall oneAPI on Linux workstation
Feng__Jesse
New Contributor II
I had an issue with the Fortran installed on the Linux workstation outlined in a different post.
The decision is now to do a clean re-install of oneAPI on the machine. When I navigated to /opt/intel, I see so many old versions are still there, including parallel studio and others:
I searched online and saw that I should uninstall everything found with rpm -qa | grep intel, and then delete the /opt/intel folder. I also saw that there should be an uninstaller inside /opt/intel/oneapi/installer, but the installer directory doesn't exist. I also saw there should be an uninstaller in /bin/ and there isn't one.
So I am slightly confused at how the oneapi was installed before, and if the rpm -> delete is still the best approach. Any suggestions on how I can cleanly remove all previous instances of Fortran from the Centos7 LInux system then reinstall it would be much appreciated!
Jesse
RahulC_Intel
Hi Zhangxi, we would recommend you few steps to uninstall the programs from your system. Follow the below steps:
  • yum remove [package_name] i.e. "Composer, Professional or Cluster edition"
  • rpm -> delete is a good approach to uninstall the program.
Also, you can use the shell scripts uninstall.sh or uninstall_GUI.sh located at: /parallel_studio_xe_201x.x.xxx. After invoking this script, follow the prompts for the uninstall process.
Feng__Jesse
New Contributor II
Hi Rahul,
Thanks for getting back tome.
After uninstalling sudo yum remove intel-oneapi*, I believe there are still more packages left, can you take a look and let me know which other ones I need to remove for a clean reinstall?
intel-conda-mkl-include-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-openmp-ifort-32bit-19.0.4-243-19.0.4-243.x86_64
intel-openmp-32bit-19.0.4-243-19.0.4-243.x86_64
intel-mkl-gnu-rt-2019.4-243-2019.4-243.x86_64
intel-mpi-rt-2019.4-243-2019.4-243.x86_64
intel-tbb-devel-2019.6-243-2019.6-243.x86_64
intel-comp-19.0.4-243-19.0.4-243.x86_64
intel-psxe-licensing-2019.4-070-2019.4-070.noarch
intel-psxe-licensing-doc-2019-2019.4-070.noarch
intel-clck-pset-2019.4.0-20190416-2019.4.0-20190416.noarch
intel-gdb-common-ps-2019-2019.4-243.noarch
intel-inspector-2019-gui-2019.4-597413.x86_64
intel-vtune-amplifier-2019-collector-64linux-2019.4-597835.x86_64
intel-ifort-32bit-19.0.4-243-19.0.4-243.x86_64
intel-conda-ipp-static-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-icc-common-ps-19.0.4-243-19.0.4-243.noarch
intel-advisor-2019-cli-common-2019.4-597843.noarch
intel-mkl-core-c-32bit-2019.4-243-2019.4-243.x86_64
intel-icc-common-ps-ss-bec-19.0.4-243-19.0.4-243.noarch
intel-mkl-f95-common-2019.4-243-2019.4-243.noarch
intel-conda-impi-devel-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-comp-nomcu-vars-19.0.4-243-19.0.4-243.noarch
intel-ifort-common-19.0.4-243-19.0.4-243.noarch
intel-vtune-amplifier-2019-doc-2019.4-597835.noarch
intel-vtune-amplifier-2019-vpp-server-2019.4-597835.x86_64
intel-inspector-2019-cli-2019.4-597413.x86_64
intel-c-comp-common-19.0.4-243-19.0.4-243.noarch
intel-mkl-common-ps-2019.4-243-2019.4-243.noarch
intel-gdb-2019-2019.4-243.x86_64
intel-mkl-f95-32bit-2019.4-243-2019.4-243.x86_64
intel-itac-common-2019.4-036-2019.4-036.noarch
intel-conda-tbb-linux-32-shadow-package-2019.6-243-2019.6-243.x86_64
intel-mkl-gnu-f-2019.4-243-2019.4-243.x86_64
intel-mkl-core-rt-32bit-2019.4-243-2019.4-243.x86_64
intel-icc-doc-19.0-19.0.4-243.noarch
intel-conda-ipp-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-ipp-st-devel-2019.4-243-2019.4-243.x86_64
intel-icc-doc-ps-19.0-19.0.4-243.noarch
intel-conda-tbb-devel-linux-64-shadow-package-2019.6-243-2019.6-243.x86_64
intel-comp-32bit-19.0.4-243-19.0.4-243.x86_64
intel-conda-impi_rt-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-cluster-f-2019.4-243-2019.4-243.noarch
intel-basekit-getting-started-2023.2.0-49384.noarch
intel-mkl-tbb-32bit-2019.4-243-2019.4-243.x86_64
intel-advisor-2019-doc-2019.4-597843.noarch
intel-conda-intel-openmp-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-ipp-st-devel-ps-2019.4-243-2019.4-243.x86_64
intel-vtune-amplifier-2019-collector-32linux-2019.4-597835.i486
intel-inspector-2019-cli-32bit-2019.4-597413.i486
intel-comp-doc-19.0-19.0.4-243.noarch
intel-mkl-gnu-f-rt-32bit-2019.4-243-2019.4-243.x86_64
intel-gdb-common-2019-2019.4-243.noarch
intel-advisor-2019-cli-common-pset-2019.4-597843.noarch
intel-mkl-f95-2019.4-243-2019.4-243.x86_64
intel-mkl-tbb-rt-32bit-2019.4-243-2019.4-243.x86_64
intel-ipp-st-devel-32bit-2019.4-243-2019.4-243.x86_64
intel-vtune-amplifier-2019-sep-2019.4-597835.noarch
intel-conda-daal-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-clck-2019.4.0-20190416-2019.4.0-20190416.x86_64
intel-conda-ipp-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-inspector-2019-gui-common-2019.4-597413.noarch
intel-conda-mkl-include-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-core-2019.4-243-2019.4-243.x86_64
intel-python3-psxe-2019-2019.4-070.noarch
intel-vtune-amplifier-2019-target-2019.4-597835.noarch
intel-icsxe-doc-2019-2019.4-070.noarch
intel-vtune-amplifier-2019-cli-common-2019.4-597835.noarch
intel-openmp-common-icc-19.0.4-243-19.0.4-243.noarch
intel-python-nopyver-2019-2019.4-070.noarch
intel-conda-icc_rt-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-openmp-common-ifort-19.0.4-243-19.0.4-243.noarch
intel-conda-tbb-linux-64-shadow-package-2019.6-243-2019.6-243.x86_64
intel-comp-ps-19.0.4-243-19.0.4-243.x86_64
intel-vtune-amplifier-2019-gui-common-2019.4-597835.noarch
intel-inspector-2019-cli-common-2019.4-597413.noarch
intel-advisor-2019-gui-common-2019.4-597843.noarch
intel-tbb-doc-2019-2019.6-243.noarch
intel-conda-mkl-devel-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-icc-32bit-19.0.4-243-19.0.4-243.x86_64
intel-mkl-gnu-32bit-2019.4-243-2019.4-243.x86_64
intel-mkl-cluster-2019.4-243-2019.4-243.x86_64
intel-conda-daal-devel-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-conda-ipp-devel-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mpi-sdk-2019.4-243-2019.4-243.x86_64
intel-mkl-core-rt-2019.4-243-2019.4-243.x86_64
intel-mkl-core-f-2019.4-243-2019.4-243.x86_64
intel-daal-core-32bit-2019.4-243-2019.4-243.x86_64
intel-conda-daal-devel-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-openmp-ifort-19.0.4-243-19.0.4-243.x86_64
intel-trace-analyzer-2019.4-036-2019.4-036.x86_64
intel-mkl-gnu-rt-32bit-2019.4-243-2019.4-243.x86_64
intel-conda-daal-include-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-core-c-2019.4-243-2019.4-243.x86_64
intel-trace-collector-2019.4-036-2019.4-036.x86_64
intel-vtune-amplifier-2019-common-2019.4-597835.noarch
intel-advisor-2019-gui-2019.4-597843.x86_64
intel-comp-ps-32bit-19.0.4-243-19.0.4-243.x86_64
intel-conda-daal-include-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-common-c-2019.4-243-2019.4-243.noarch
intel-ipp-doc-2019-2019.4-243.noarch
intel-mkl-core-f-32bit-2019.4-243-2019.4-243.x86_64
intel-imb-2019.4-243-2019.4-243.x86_64
intel-comp-ps-ss-bec-32bit-19.0.4-243-19.0.4-243.x86_64
intel-ipp-st-32bit-2019.4-243-2019.4-243.x86_64
intel-mpi-doc-2019-2019.4-243.x86_64
intel-icsxe-2019.4-070-2019.4-070.noarch
intel-conda-daal-static-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-tbb-2019.4-243-2019.4-243.x86_64
intel-conda-ipp-include-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-advisor-2019-cli-32bit-2019.4-597843.i486
intel-idesupport-icc-common-ps-19.0-19.0.4-243.noarch
intel-conda-mkl-devel-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-ipp-st-devel-ps-32bit-2019.4-243-2019.4-243.x86_64
intel-hpckit-getting-started-2023.2.0-49438.noarch
intel-conda-intel-openmp-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-conda-tbb-devel-linux-32-shadow-package-2019.6-243-2019.6-243.x86_64
intel-icc-ps-ss-bec-19.0.4-243-19.0.4-243.x86_64
intel-mkl-common-2019.4-243-2019.4-243.noarch
intel-mkl-common-c-ps-2019.4-243-2019.4-243.noarch
intel-conda-mkl-static-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-ipp-common-2019.4-243-2019.4-243.noarch
intel-daal-doc-2019-2019.4-243.noarch
intel-mkl-core-ps-2019.4-243-2019.4-243.x86_64
intel-mkl-doc-2019-2019.4-243.noarch
intel-conda-daal-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-conda-ipp-devel-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-gnu-2019.4-243-2019.4-243.x86_64
intel-conda-daal-static-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-inspector-2019-cli-common-pset-2019.4-597413.noarch
intel-advisor-2019-fga-2019.4-597843.x86_64
intel-vtune-amplifier-2019-gui-2019.4-597835.x86_64
intel-conda-index-tool-19.0.4-243-19.0.4-243.x86_64
intel-comp-ps-ss-19.0.4-243-19.0.4-243.x86_64
intel-mkl-gnu-c-32bit-2019.4-243-2019.4-243.x86_64
intel-conda-ipp-static-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-ifort-19.0.4-243-19.0.4-243.x86_64
intel-icc-ps-19.0.4-243-19.0.4-243.x86_64
intel-comp-l-all-common-19.0.4-243-19.0.4-243.noarch
intel-mkl-doc-ps-2019-2019.4-243.noarch
intel-icc-19.0.4-243-19.0.4-243.x86_64
intel-mkl-common-f-2019.4-243-2019.4-243.noarch
intel-mpi-samples-2019.4-243-2019.4-243.x86_64
intel-ipp-st-2019.4-243-2019.4-243.x86_64
intel-openmp-common-19.0.4-243-19.0.4-243.noarch
intel-psxe-common-doc-2019-2019.4-070.noarch
intel-icsxe-pset-2019.4-070-2019.4-070.noarch
intel-mkl-gnu-c-2019.4-243-2019.4-243.x86_64
intel-mkl-core-ps-32bit-2019.4-243-2019.4-243.x86_64
intel-vtune-amplifier-2019-cli-32bit-2019.4-597835.i486
intel-clck-support-2019.4.0-20190416-2019.4.0-20190416.noarch
intel-icc-ps-ss-bec-32bit-19.0.4-243-19.0.4-243.x86_64
intel-tbb-libs-2019.6-243-2019.6-243.x86_64
intel-advisor-2019-cli-2019.4-597843.x86_64
intel-tbb-devel-32bit-2019.6-243-2019.6-243.x86_64
intel-mkl-cluster-c-2019.4-243-2019.4-243.noarch
intel-psxe-doc-2019-2019.4-070.noarch
intel-conda-ipp-include-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-conda-mkl-linux-32-shadow-package-2019.4-243-2019.4-243.x86_64
intel-itac-common-pset-2019.4-036-2019.4-036.noarch
intel-tbb-common-2019.6-243-2019.6-243.noarch
intel-inspector-2019-doc-2019.4-597413.noarch
intel-tbb-libs-32bit-2019.6-243-2019.6-243.x86_64
intel-conda-mkl-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-psxe-common-2019.4-070-2019.4-070.noarch
intel-mkl-core-32bit-2019.4-243-2019.4-243.x86_64
intel-daal-doc-ps-2019-2019.4-243.noarch
intel-mkl-cluster-rt-2019.4-243-2019.4-243.x86_64
intel-mkl-gnu-f-rt-2019.4-243-2019.4-243.x86_64
intel-vtune-amplifier-2019-common-pset-2019.4-597835.noarch
intel-comp-l-all-vars-19.0.4-243-19.0.4-243.noarch
intel-ifort-doc-19.0-19.0.4-243.noarch
intel-icc-common-19.0.4-243-19.0.4-243.noarch
intel-openmp-19.0.4-243-19.0.4-243.x86_64
intel-comp-ps-ss-bec-19.0.4-243-19.0.4-243.x86_64
intel-daal-common-2019.4-243-2019.4-243.noarch
intel-vtune-amplifier-2019-cli-2019.4-597835.x86_64
intel-mkl-tbb-rt-2019.4-243-2019.4-243.x86_64
intel-ipp-common-ps-2019.4-243-2019.4-243.noarch
intel-conda-mkl-static-linux-64-shadow-package-2019.4-243-2019.4-243.x86_64
intel-mkl-gnu-f-32bit-2019.4-243-2019.4-243.x86_64
intel-daal-core-2019.4-243-2019.4-243.x86_64
Thanks!
Jesse
RahulC_Intel
Hi Zhangxi, we recommend you to perform a clean installation of older Intel® oneAPI components before installing the latest Intel® oneAPI toolkit.
Refer to the link: https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2023-2/uninstall-oneapi-toolkits-and-components.html#UNINSTALL-ONEAPI-TOOLKITS and check the uninstallation guidance from the link.
RahulC_Intel
Hi Zhangxi, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
