oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1578 Discussions
Compiler RPM packages need proper requires
Orion_P_
When installing the Intel compiler packages into a mock chroot I get the following errors:
Installing : intel-oneapi-common-licensing-2023.0.0-2023.0.0-25325.noarch 29/228
Running scriptlet: intel-oneapi-common-licensing-2023.0.0-2023.0.0-25325.noarch 29/228
/var/tmp/rpm-tmp.DrxIPc: line 12: ls: command not found
/var/tmp/rpm-tmp.DrxIPc: line 12: grep: command not found
/var/tmp/rpm-tmp.DrxIPc: line 12: sort: command not found
/var/tmp/rpm-tmp.DrxIPc: line 12: tail: command not found
Installing : intel-oneapi-compiler-shared-common-2023.0.0-2023.0.0-25370.noarch 46/228
Running scriptlet: intel-oneapi-compiler-shared-common-2023.0.0-2023.0.0-25370.noarch 46/228
/var/tmp/rpm-tmp.AoXRaz: line 12: ls: command not found
/var/tmp/rpm-tmp.AoXRaz: line 12: grep: command not found
/var/tmp/rpm-tmp.AoXRaz: line 12: sort: command not found
/var/tmp/rpm-tmp.AoXRaz: line 12: tail: command not found
Installing : intel-oneapi-tbb-common-2021.8.0-2021.8.0-25334.noarch 57/228
Running scriptlet: intel-oneapi-tbb-common-2021.8.0-2021.8.0-25334.noarch 57/228
/var/tmp/rpm-tmp.wQ9gu9: line 12: ls: command not found
/var/tmp/rpm-tmp.wQ9gu9: line 12: grep: command not found
/var/tmp/rpm-tmp.wQ9gu9: line 12: sort: command not found
/var/tmp/rpm-tmp.wQ9gu9: line 12: tail: command not found
Installing : intel-oneapi-tbb-2021.8.0-2021.8.0-25334.x86_64 58/228
Running scriptlet: intel-oneapi-tbb-2021.8.0-2021.8.0-25334.x86_64 58/228
/var/tmp/rpm-tmp.O0ZGAF: line 13: id: command not found
/var/tmp/rpm-tmp.O0ZGAF: line 13: [: -eq: unary operator expected
/var/tmp/rpm-tmp.O0ZGAF: line 22: sha256sum: command not found
/var/tmp/rpm-tmp.O0ZGAF: line 22: cut: command not found
/var/tmp/rpm-tmp.O0ZGAF: line 26: mkdir: command not found
/var/tmp/rpm-tmp.O0ZGAF: line 27: chmod: command not found
/var/tmp/rpm-tmp.O0ZGAF: line 32: ln: command not found
Installing : intel-oneapi-tbb-common-devel-2021.8.0-2021.8.0-25334.noarch 68/228
Running scriptlet: intel-oneapi-tbb-common-devel-2021.8.0-2021.8.0-25334.noarch 68/228
/var/tmp/rpm-tmp.KgjSeD: line 7: basename: command not found
/var/tmp/rpm-tmp.KgjSeD: line 13: mkdir: command not found
/var/tmp/rpm-tmp.KgjSeD: line 14: ln: command not found
Installing : intel-oneapi-tbb-devel-2021.8.0-2021.8.0-25334.x86_64 69/228
Running scriptlet: intel-oneapi-tbb-devel-2021.8.0-2021.8.0-25334.x86_64 69/228
/var/tmp/rpm-tmp.iqbfMu: line 13: id: command not found
/var/tmp/rpm-tmp.iqbfMu: line 13: [: -eq: unary operator expected
/var/tmp/rpm-tmp.iqbfMu: line 22: sha256sum: command not found
/var/tmp/rpm-tmp.iqbfMu: line 22: cut: command not found
/var/tmp/rpm-tmp.iqbfMu: line 26: mkdir: command not found
/var/tmp/rpm-tmp.iqbfMu: line 27: chmod: command not found
/var/tmp/rpm-tmp.iqbfMu: line 32: ln: command not found
/var/tmp/rpm-tmp.iqbfMu: line 41: mkdir: command not found
/var/tmp/rpm-tmp.iqbfMu: line 45: find: command not found
Installing : intel-oneapi-mpi-2021.8.0-2021.8.0-25329.x86_64 74/228
Running scriptlet: intel-oneapi-mpi-2021.8.0-2021.8.0-25329.x86_64 74/228
/var/tmp/rpm-tmp.ewcN8C: line 11: ln: command not found
/var/tmp/rpm-tmp.ewcN8C: line 29: id: command not found
/var/tmp/rpm-tmp.ewcN8C: line 29: [: -eq: unary operator expected
/var/tmp/rpm-tmp.ewcN8C: line 38: sha256sum: command not found
/var/tmp/rpm-tmp.ewcN8C: line 38: cut: command not found
/var/tmp/rpm-tmp.ewcN8C: line 42: mkdir: command not found
/var/tmp/rpm-tmp.ewcN8C: line 43: chmod: command not found
/var/tmp/rpm-tmp.ewcN8C: line 48: ln: command not found
Installing : intel-oneapi-dev-utilities-2021.8.0-2021.8.0-25328.x86_64 89/228
Running scriptlet: intel-oneapi-dev-utilities-2021.8.0-2021.8.0-25328.x86_64 89/228
/var/tmp/rpm-tmp.nKatQl: line 12: ls: command not found
/var/tmp/rpm-tmp.nKatQl: line 12: grep: command not found
/var/tmp/rpm-tmp.nKatQl: line 12: sort: command not found
/var/tmp/rpm-tmp.nKatQl: line 12: tail: command not found
/var/tmp/rpm-tmp.nKatQl: line 32: basename: command not found
/var/tmp/rpm-tmp.nKatQl: line 44: ln: command not found
Installing : intel-oneapi-dpcpp-debugger-eclipse-cfg-2023.0.0-25336.noarch 90/228
Installing : intel-oneapi-dpcpp-debugger-2023.0.0-2023.0.0-25336.x86_64 91/228
Running scriptlet: intel-oneapi-dpcpp-debugger-2023.0.0-2023.0.0-25336.x86_64 91/228
/var/tmp/rpm-tmp.QVO1XC: line 12: ls: command not found
/var/tmp/rpm-tmp.QVO1XC: line 12: grep: command not found
/var/tmp/rpm-tmp.QVO1XC: line 12: sort: command not found
/var/tmp/rpm-tmp.QVO1XC: line 12: tail: command not found
/var/tmp/rpm-tmp.QVO1XC: line 32: basename: command not found
/var/tmp/rpm-tmp.QVO1XC: line 44: ln: command not found
Installing : intel-oneapi-openmp-common-2023.0.0-2023.0.0-25370.noarch 92/228
Running scriptlet: intel-oneapi-openmp-common-2023.0.0-2023.0.0-25370.noarch 92/228
/var/tmp/rpm-tmp.plSFTq: line 12: ls: command not found
/var/tmp/rpm-tmp.plSFTq: line 12: grep: command not found
/var/tmp/rpm-tmp.plSFTq: line 12: sort: command not found
/var/tmp/rpm-tmp.plSFTq: line 12: tail: command not found
Installing : intel-oneapi-openmp-2023.0.0-2023.0.0-25370.x86_64 93/228
Running scriptlet: intel-oneapi-openmp-2023.0.0-2023.0.0-25370.x86_64 93/228
/var/tmp/rpm-tmp.1EGneX: line 13: id: command not found
/var/tmp/rpm-tmp.1EGneX: line 13: [: -eq: unary operator expected
/var/tmp/rpm-tmp.1EGneX: line 22: sha256sum: command not found
/var/tmp/rpm-tmp.1EGneX: line 22: cut: command not found
/var/tmp/rpm-tmp.1EGneX: line 26: mkdir: command not found
/var/tmp/rpm-tmp.1EGneX: line 27: chmod: command not found
/var/tmp/rpm-tmp.1EGneX: line 32: ln: command not found
/var/tmp/rpm-tmp.1EGneX: line 41: mkdir: command not found
/var/tmp/rpm-tmp.1EGneX: line 45: find: command not found
Installing : intel-oneapi-compiler-shared-runtime-2023.0.0-2023.0.0-25370.x86_64 94/228
Running scriptlet: intel-oneapi-compiler-shared-runtime-2023.0.0-2023.0.0-25370.x86_64 94/228
/var/tmp/rpm-tmp.SvzLnd: line 17: ln: command not found
/var/tmp/rpm-tmp.SvzLnd: line 35: find: command not found
Installing : intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2023.0.0-2023.0.0-25370.x86_64 95/228
Installing : intel-oneapi-compiler-dpcpp-cpp-runtime-2023.0.0-2023.0.0-25370.x86_64 96/228
Running scriptlet: intel-oneapi-compiler-dpcpp-cpp-runtime-2023.0.0-2023.0.0-25370.x86_64 96/228
/var/tmp/rpm-tmp.BTB6wr: line 12: ls: command not found
/var/tmp/rpm-tmp.BTB6wr: line 12: grep: command not found
/var/tmp/rpm-tmp.BTB6wr: line 12: sort: command not found
/var/tmp/rpm-tmp.BTB6wr: line 12: tail: command not found
Installing : intel-oneapi-compiler-shared-2023.0.0-2023.0.0-25370.x86_64 97/228
Installing : intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2023.0.0-2023.0.0-25370.x86_64 98/228
Installing : intel-oneapi-compiler-fortran-runtime-2023.0.0-2023.0.0-25370.x86_64 99/228
Installing : intel-oneapi-compiler-fortran-2023.0.0-2023.0.0-25370.x86_64 100/228
Installing : elfutils-default-yama-scope-0.187-5.el9.noarch 101/228
Running scriptlet: elfutils-default-yama-scope-0.187-5.el9.noarch 101/228
Installing : elfutils-libs-0.187-5.el9.x86_64 102/228
Installing : intel-oneapi-icc-eclipse-plugin-cpp-2023.0.0-2023.0.0-25370.noarch 103/228
Running scriptlet: intel-oneapi-icc-eclipse-plugin-cpp-2023.0.0-2023.0.0-25370.noarch 103/228
/var/tmp/rpm-tmp.rB7ysC: line 6: basename: command not found
/var/tmp/rpm-tmp.rB7ysC: line 18: ln: command not found
Installing : intel-oneapi-compiler-dpcpp-cpp-common-2023.0.0-2023.0.0-25370.noarch 104/228
Running scriptlet: intel-oneapi-compiler-dpcpp-cpp-common-2023.0.0-2023.0.0-25370.noarch 104/228
/var/tmp/rpm-tmp.u7QXBz: line 6: basename: command not found
/var/tmp/rpm-tmp.u7QXBz: line 18: ln: command not found
Installing : intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2023.0.0-2023.0.0-25370.noarch 105/228
Installing : intel-oneapi-dpcpp-cpp-2023.0.0-2023.0.0-25370.x86_64 106/228
Running scriptlet: intel-oneapi-dpcpp-cpp-2023.0.0-2023.0.0-25370.x86_64 106/228
/var/tmp/rpm-tmp.SeN2Pj: line 17: ln: command not found
/var/tmp/rpm-tmp.SeN2Pj: line 35: find: command not found
/var/tmp/rpm-tmp.SeN2Pj: line 35: head: command not found
/var/tmp/rpm-tmp.SeN2Pj: line 36: find: command not found
/var/tmp/rpm-tmp.SeN2Pj: line 36: head: command not found
This is because the packages lack the needed 'Requires(post)' dependencies.  For example, intel-oneapi-common-licensing-2023.0.0-2023.0.0-25325.noarch should have:
Requires(post): coreutils
Requires(post): grep
or
Requires(post): /usr/bin/ls
Requires(post): /usr/bin/grep
Requires(post): /usr/bin/sort
Requires(post): /usr/bin/tail
in order to ensure that those commands are installed prior to its %post scriptlet running.
For mock I'm able to work around this by installing the compiler packages later:
config_opts['chroot_additional_packages'] = 'intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic intel-oneapi-compiler-fortran'
Soumya_M_Intel
Hi Orion,
Thanks for posting your concern on the forum. We are checking on the issue with our resources. Please wait for 2-3 business days. We will get back to you as soon as possible.
Soumya
Soumya_M_Intel
Hi Orion,
Appreciate your patience. We wanted to keep you updated that we are currently looking into the issue with our higher team. Please wait for 2-3 business days. We will get back to you as soon as we have an update on the matter.
Soumya
