I was hoping someone could help me to better understand the Intel oneAPI package dependencies when installing through APT or DNF, as I seem to get more packages than I would expect. If all I want is C, CXX, and Fortran compilers, then the OpenMP package, some Eclipse plugin-related packages (I don't have Eclipse on my system), and Intel MPI are automatically installed. Disabling recommended/suggested packages in APT seems to have no effect. In my DNF-based installation, if I try to uninstall intel-oneapi-mpi, it will insist that I have to uninstall Fortran as well. Do I really have to have MPI installed if I want to use ifx/ifort for serial applications? I don't think that's consistent with what comes from the offline installers, but I could be misremembering. This is mainly a concern in CI contexts where we have limited disk space to install into and would like to avoid unnecessary extras.
Hi Alex, could you please share the below details with us for further investigation.
- Operating System & It's Build Number on which you are installing the product.
- Exact Product name and it's version.
- Screenshot of an error code.
- What libraries do you want to install in your system?
- Are you using offline or online installer?
- This issue happens on multiple systems, but I'll provide info based on my CentOS Stream release 8 machine.
- This issue has happened with a range of versions, but let's go with 2023.2.1. The packages I want installed are intel-oneapi-dpcpp-cpp and intel-oneapi-compiler-fortran. In short, I want icx, icpx, and ifx.
- There's no error code, but I'm attaching screenshots that show what happens when I attempt to uninstall intel-oneapi-icc-eclipse-plugin-cpp-2023.2.1 and intel-oneapi-mpi-2021.10.0. he former would result in icx/icpx being removed; the latter would result in ifx being removed.
- I want a minimal install for compiling with icx/icpx/ifx.
- In this instance I am using the RPM repo through DNF (again, same thing happens with Ubuntu/APT).
Hi Alex, please note Intel® has decided that Intel® oneAPI Toolkits Versions: 2024.1.0 and earlier are not supported anymore. We urge users to upgrade to the latest version of Intel® developer tools.
The unsupported versions do not include the latest functional and security updates. These versions are targeted to be removed after a period. For more information refer to the link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/oneapi-supported-product-versions.htm, and scroll down to the Unsupported Product Versions.
However, Intel® oneAPI users with active Intel® Priority Support can access older versions via a secure portal and gain access as part of support subscription.
Refer to the link: https://www.intel.com/content/www/us/en/developer/get-help/faq-priority-support.html and know more about priority support.
Hi Alex, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
