oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1489 Discussions
Error code 6 when installing Sampling driver for Intel Vtune profiler
Cun
I have tried Installing sampling driver of Intel Vtune Profiler however I am encountering error code"6" while installing .
My OS version: Windows 11 version 23H2 (OS Build 22631.3296)
VTune version 2024.1.0.595
After disable Windows Defender Real-time Virus Protection and Windows Defender ,issue still happen.
Thank you in advance for the answers.
Following is the screenshot:
Vipin_S_Intel
Hi Jiajun, we have sent you a private message. Kindly check your community inbox.
Jennifer_D_Intel
I see the same issue on 23H2, although it does not prevent me from running analysis types such as hardware-based hotspots with stack collection. I'll do more investigation.
Jennifer_D_Intel
This is a known issue with Windows 11 23H2. VTune will still work with the sep and other drivers, but you will see a message about LBR-based stack type that has a depth limitation when running hardware-based sampling analyses (such as hotspots) with stack collection enabled. This problem will be fixed in the next release.
