oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
Error in installation
Version001
I get this error when I try to install oneapi;
I have successfully installed it before. Last week I uninstalled Visual Studio 2022 and Oneapi. When I want to install it again I started getting this error.
To resolve the error, I tried the following;
I uninstalled Visual Studio 2022 (i dont have another versions) and reinstalled.
I tried offline oneapi installation
I deleted oneapi installer cache
These didn't work.
Can somebody help me? thanks...
NOTE : sorry for my english, i using google translator.
ArpanB_Intel
Hi Yasin, please follow the below steps>
  1. Close Intel® installers if any.
  2. Uninstall all Microsoft Visual Studio instances and Visual Studio Installer.
  3. Important: check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
  4. REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
  5. command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
  6. Uninstall older Intel® Parallel Studio XE and Intel® oneAPI products.
Install required versions of Microsoft Visual Studio supported by the Intel® Parallel Studio XE or Intel® oneAPI. See the full list here> Intel® Compilers Compatibility with Microsoft Visual Studio* and Xcode*.
ArpanB_Intel
Version001
Hello, thank you for reply.
I did what you said and I keep getting errors. I removed all instances of visual studio and intel onepi and it didn't work.
But instead of deleting this file i changed its name and tried again;
and it worked. Deleting it didn't work, renaming it did. This is really weird.
My problem is solved, thread can be closed. Thanks for be interested.
ArpanB_Intel
Yasin, thank you for sharing the solution with us. We are glad that the issue is resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
