System:
Fedora Linux 38
Kernel 6.3.12-200.x86_64
ifort: 2021.9.0
ifx: 2023.1.0
icx: 2023.1.0
Unsuccessful attempt to upgrade OneAPI to version 2023.2.
I am using dnf packages and the command
$>sudo dnf upgrade
returns the following error messages:
error: rpmdbNextIterator: skipping h# 25203
Header RSA signature: BAD (header tag 268: invalid OpenPGP signature: Parsing an OpenPGP packet:
Failed to parse Signature Packet
because: Signature appears to be created by a non-conformant OpenPGP implementation, see <https://git
hub.com/rpm-software-management/rpm/issues/2351>.
because: Malformed MPI: leading bit is not set: expected bit 8 to be set in 1101101 (6d))
Header SHA256 digest: OK
Header SHA1 digest: OK
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: An rpm exception occurred: package not installed
The team has informed me that they have fixed this issue and you should be able to use the 2024.0 release with Fedora 38.
Can you please test and let me know if you can still see this issue?
This is an installation question. I'll move this post to the Intel Forum that specializes in installation issues.
I still get this same error when trying to update OneAPI with dnf system on the current Fedora Core versions (the default, 38).
As stated in another post: It can be fixed easily by Intel, just a matter of putting the correct key online.
A month later, are there any news on this?
Still waiting for someone from Intel to acknowledge and give some reply to this problem.
I have exactly same problem. It seems that they key for OneAPI repository is expired. Does Intel have any plan to update the key or any other key should be used?
Got tired and looked into the problem myself. Here's a solution that worked for me.
Starting with Fedora 38, SHA-1 signed packages are not accepted anymore. And even when using with "dnf upgrade --nogpgcheck ...", if the old packages are still present on the system, the --nogpgcheck will fail.
So... After deleting all the old packages.rpm and the old key, I was then able to install the new versions without any problem. (I didn't care for the old versions.):
# list the installed keys
rpm -q gpg-pubkey --qf '%{NAME}-%{VERSION}-%{RELEASE}\t%{SUMMARY}\n'
# delete the Intel key
rpm -e gpg-pubkey-7e6c5dbe-5d91bb57
# delete all the previously installed intel-oneapi packages
rpm -e --nosignature $(dnf list intel-oneapi* | grep intel-oneapi | cut -d' ' -f1`)
# install the new current versions
dnf install intel-basekit.x86_64
Great!
I'll wait a couple of days. If no one from Intel decides to jump in and offer this or another solution, I'll try that myself.
what do you do on step 3 after running the command?
sorry I don't really understand rpm and dnf that well
Perhaps I could have better commented my previous intervention ...
- The goal of the steps 1 and 2 is to remove the already installed packages that are signed with the old SHA-1 key.
- The dnf command on step 3 is to install fresh versions of the oneAPI packages signed with a new key.
The procedure for installing using yum/dnf/zypper is described at
but you may also install the packages using other various installation possibilities: https://www.intel.com/content/www/us/en/developer/articles/guide/installation-guide-for-oneapi-toolkits.html
After installation (and to answer @catvm question), how to use the the oneAPI Toolkit is described at https://www.intel.com/content/www/us/en/docs/oneapi-base-toolkit/get-started-guide-linux/2023-2/overview.html
when I am running "rpm -e --nosignature $(dnf list intel-basekit* | grep intel-basekit | cut -d' ' -f1`)"
I am getting this promt window. what do I do here?
Apologies... There's a superfluous backtick (`) that should not have been there ("-f1`" should simply be "-f1").
Here's the correct line for step 3:
rpm -e --nosignature $(dnf list intel-oneapi* | grep intel-oneapi | cut -d' ' -f1)
sorry for annoying you so much...
I keep getting this error:
error: package intel-oneapi-ccl.x86_64 is not installed
error: package intel-oneapi-ccl-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ccl-2021.10.0.x86_64 is not installed
error: package intel-oneapi-ccl-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ccl-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ccl-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ccl-2021.5.0.x86_64 is not installed
error: package intel-oneapi-ccl-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ccl-devel-2021.10.0.x86_64 is not installed
error: package intel-oneapi-ccl-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ccl-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ccl-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ccl-devel-2021.5.0.x86_64 is not installed
error: package intel-oneapi-clck-2021.1.1.x86_64 is not installed
error: package intel-oneapi-clck-2021.2.0.x86_64 is not installed
error: package intel-oneapi-clck-2021.2.2.x86_64 is not installed
error: package intel-oneapi-clck-2021.3.0.x86_64 is not installed
error: package intel-oneapi-clck-2021.4.0.x86_64 is not installed
error: package intel-oneapi-clck-2021.5.0.x86_64 is not installed
error: package intel-oneapi-common-licensing-2021.1.1.noarch is not installed
error: package intel-oneapi-common-licensing-2021.3.0.noarch is not installed
error: package intel-oneapi-common-licensing-2021.4.0.noarch is not installed
error: package intel-oneapi-common-licensing-2023.2.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2022.0.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2022.1.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2022.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2022.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2023.0.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2023.1.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-32bit-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2021.1.1.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2021.1.2.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2021.2.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2021.3.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2021.4.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2022.0.1.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2023.2.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-common-2023.2.1.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2021.1.2.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-and-cpp-classic-runtime-32bit-2023.2.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2021.1.2.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-classic-fortran-shared-runtime-32bit-2023.2.1.i686 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2021.1.1.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2021.1.2.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2021.2.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2021.3.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2021.4.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2022.0.1.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2023.2.0.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-common-2023.2.1.noarch is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-dpcpp-cpp-runtime-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2022.0.2.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2022.1.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2022.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2022.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2023.0.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2023.1.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-32bit-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-common-2021.1.1.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2021.1.2.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2021.2.0.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2021.3.0.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2021.4.0.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2022.0.1.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2023.2.0.noarch is not installed
error: package intel-oneapi-compiler-fortran-common-2023.2.1.noarch is not installed
error: package intel-oneapi-compiler-fortran-runtime.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2021.1.2.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-compiler-fortran-runtime-32bit-2023.2.1.i686 is not installed
error: package intel-oneapi-compiler-shared-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-shared-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2021.1.2.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-compiler-shared-32bit-2023.2.1.i686 is not installed
error: package intel-oneapi-compiler-shared-common-2021.1.1.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2021.1.2.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2021.2.0.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2021.3.0.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2021.4.0.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2022.0.1.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2023.2.0.noarch is not installed
error: package intel-oneapi-compiler-shared-common-2023.2.1.noarch is not installed
error: package intel-oneapi-compiler-shared-common-runtime-2021.1.1.noarch is not installed
error: package intel-oneapi-compiler-shared-common-runtime-2021.1.2.noarch is not installed
error: package intel-oneapi-compiler-shared-common-runtime-2021.2.0.noarch is not installed
error: package intel-oneapi-compiler-shared-common-runtime-2021.3.0.noarch is not installed
error: package intel-oneapi-compiler-shared-runtime-2021.1.1.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2021.1.2.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2021.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2021.3.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2021.4.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2022.0.1.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2023.2.0.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-2023.2.1.x86_64 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2021.1.2.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-compiler-shared-runtime-32bit-2023.2.1.i686 is not installed
error: package intel-oneapi-daal.x86_64 is not installed
error: package intel-oneapi-daal-devel.x86_64 is not installed
error: package intel-oneapi-dal.x86_64 is not installed
error: package intel-oneapi-dal-2021.1.1.x86_64 is not installed
error: package intel-oneapi-dal-2021.2.0.x86_64 is not installed
error: package intel-oneapi-dal-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dal-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dal-2021.5.1.x86_64 is not installed
error: package intel-oneapi-dal-2023.2.0.x86_64 is not installed
error: package intel-oneapi-dal-common-2021.1.1.noarch is not installed
error: package intel-oneapi-dal-common-2021.2.0.noarch is not installed
error: package intel-oneapi-dal-common-2021.3.0.noarch is not installed
error: package intel-oneapi-dal-common-2021.4.0.noarch is not installed
error: package intel-oneapi-dal-common-2021.5.1.noarch is not installed
error: package intel-oneapi-dal-common-2023.2.0.noarch is not installed
error: package intel-oneapi-dal-common-devel-2021.1.1.noarch is not installed
error: package intel-oneapi-dal-common-devel-2021.2.0.noarch is not installed
error: package intel-oneapi-dal-common-devel-2021.3.0.noarch is not installed
error: package intel-oneapi-dal-common-devel-2021.4.0.noarch is not installed
error: package intel-oneapi-dal-common-devel-2021.5.1.noarch is not installed
error: package intel-oneapi-dal-common-devel-2023.2.0.noarch is not installed
error: package intel-oneapi-dal-daal4py-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dal-daal4py-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dal-daal4py-2021.5.1.x86_64 is not installed
error: package intel-oneapi-dal-daal4py-2023.2.0.x86_64 is not installed
error: package intel-oneapi-dal-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-dal-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-dal-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dal-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dal-devel-2021.5.1.x86_64 is not installed
error: package intel-oneapi-dal-devel-2023.2.0.x86_64 is not installed
error: package intel-oneapi-dal-scikit-learn-intelex-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dal-scikit-learn-intelex-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dal-scikit-learn-intelex-2021.5.1.x86_64 is not installed
error: package intel-oneapi-dal-scikit-learn-intelex-2023.2.0.x86_64 is not installed
error: package intel-oneapi-dev-utilities-2021.1.1.x86_64 is not installed
error: package intel-oneapi-dev-utilities-2021.10.0.x86_64 is not installed
error: package intel-oneapi-dev-utilities-2021.2.0.x86_64 is not installed
error: package intel-oneapi-dev-utilities-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dev-utilities-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dev-utilities-2021.5.1.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2021.1.1.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2021.1.2.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2021.2.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2022.0.1.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2023.2.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-cpp-2023.2.1.x86_64 is not installed
error: package intel-oneapi-dpcpp-ct-2021.1.1.x86_64 is not installed
error: package intel-oneapi-dpcpp-ct-2021.2.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-ct-2021.3.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-ct-2021.4.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-ct-2023.2.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-debugger-10.0.0.x86_64 is not installed
error: package intel-oneapi-dpcpp-debugger-10.1.1.x86_64 is not installed
error: package intel-oneapi-dpcpp-debugger-10.1.2.x86_64 is not installed
error: package intel-oneapi-dpcpp-debugger-10.2.4.x86_64 is not installed
error: package intel-oneapi-dpcpp-debugger-2023.2.0.x86_64 is not installed
error: package intel-oneapi-eclipse-ide.x86_64 is not installed
error: package intel-oneapi-eclipse-ide-2021.1.1.x86_64 is not installed
error: package intel-oneapi-eclipse-ide-2021.2.0.x86_64 is not installed
error: package intel-oneapi-embree.x86_64 is not installed
error: package intel-oneapi-embree-3.12.0.x86_64 is not installed
error: package intel-oneapi-embree-3.12.2.x86_64 is not installed
error: package intel-oneapi-embree-3.13.0.x86_64 is not installed
error: package intel-oneapi-embree-3.13.1.x86_64 is not installed
error: package intel-oneapi-embree-3.13.2.x86_64 is not installed
error: package intel-oneapi-embree-3.13.3.x86_64 is not installed
error: package intel-oneapi-embree-3.13.4.x86_64 is not installed
error: package intel-oneapi-embree-3.13.5.x86_64 is not installed
error: package intel-oneapi-embree-4.0.1.x86_64 is not installed
error: package intel-oneapi-embree-4.1.0.x86_64 is not installed
error: package intel-oneapi-icc-eclipse-plugin-cpp-2022.0.1.noarch is not installed
error: package intel-oneapi-icc-eclipse-plugin-cpp-2023.2.0.noarch is not installed
error: package intel-oneapi-icc-eclipse-plugin-cpp-2023.2.1.noarch is not installed
error: package intel-oneapi-ilit.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-a10gx-s10sx.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus19.4.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus19.4-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.2-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.4.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.4-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.1.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.1-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.2-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.3.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.3-part2.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.4.x86_64 is not installed
error: package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus21.4-part2.x86_64 is not installed
error: package intel-oneapi-iot-eclipse-plugins.noarch is not installed
error: package intel-oneapi-iot-eclipse-plugins-2021.1.1.noarch is not installed
error: package intel-oneapi-iot-eclipse-plugins-2021.2.0.noarch is not installed
error: package intel-oneapi-iot-eclipse-plugins-2021.3.0.noarch is not installed
error: package intel-oneapi-iot-eclipse-plugins-2021.4.0.noarch is not installed
error: package intel-oneapi-iot-eclipse-plugins-cfg.noarch is not installed
error: package intel-oneapi-ipp.x86_64 is not installed
error: package intel-oneapi-ipp-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ipp-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ipp-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ipp-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ipp-2021.5.1.x86_64 is not installed
error: package intel-oneapi-ipp-2021.9.0.x86_64 is not installed
error: package intel-oneapi-ipp-32bit.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.5.1.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.5.2.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.6.0.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.6.1.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.6.2.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.7.0.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.8.0.i686 is not installed
error: package intel-oneapi-ipp-32bit-2021.9.0.i686 is not installed
error: package intel-oneapi-ipp-common-2021.1.1.noarch is not installed
error: package intel-oneapi-ipp-common-2021.2.0.noarch is not installed
error: package intel-oneapi-ipp-common-2021.3.0.noarch is not installed
error: package intel-oneapi-ipp-common-2021.4.0.noarch is not installed
error: package intel-oneapi-ipp-common-2021.5.1.noarch is not installed
error: package intel-oneapi-ipp-common-2021.9.0.noarch is not installed
error: package intel-oneapi-ipp-common-devel-2021.1.1.noarch is not installed
error: package intel-oneapi-ipp-common-devel-2021.2.0.noarch is not installed
error: package intel-oneapi-ipp-common-devel-2021.3.0.noarch is not installed
error: package intel-oneapi-ipp-common-devel-2021.4.0.noarch is not installed
error: package intel-oneapi-ipp-common-devel-2021.5.1.noarch is not installed
error: package intel-oneapi-ipp-common-devel-2021.9.0.noarch is not installed
error: package intel-oneapi-ipp-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ipp-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-2021.5.1.x86_64 is not installed
error: package intel-oneapi-ipp-devel-2021.9.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.5.1.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.5.2.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.6.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.6.1.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.6.2.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.7.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.8.0.x86_64 is not installed
error: package intel-oneapi-ipp-devel-32bit-2021.9.0.x86_64 is not installed
error: package intel-oneapi-ippcp.x86_64 is not installed
error: package intel-oneapi-ippcp-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ippcp-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ippcp-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ippcp-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ippcp-2021.5.0.x86_64 is not installed
error: package intel-oneapi-ippcp-2021.8.0.x86_64 is not installed
error: package intel-oneapi-ippcp-32bit.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.5.0.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.5.1.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.6.0.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.6.1.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.6.2.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.6.3.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.7.0.i686 is not installed
error: package intel-oneapi-ippcp-32bit-2021.8.0.i686 is not installed
error: package intel-oneapi-ippcp-common-2021.1.1.noarch is not installed
error: package intel-oneapi-ippcp-common-2021.2.0.noarch is not installed
error: package intel-oneapi-ippcp-common-2021.3.0.noarch is not installed
error: package intel-oneapi-ippcp-common-2021.4.0.noarch is not installed
error: package intel-oneapi-ippcp-common-2021.5.0.noarch is not installed
error: package intel-oneapi-ippcp-common-2021.8.0.noarch is not installed
error: package intel-oneapi-ippcp-common-devel-2021.1.1.noarch is not installed
error: package intel-oneapi-ippcp-common-devel-2021.2.0.noarch is not installed
error: package intel-oneapi-ippcp-common-devel-2021.3.0.noarch is not installed
error: package intel-oneapi-ippcp-common-devel-2021.4.0.noarch is not installed
error: package intel-oneapi-ippcp-common-devel-2021.5.0.noarch is not installed
error: package intel-oneapi-ippcp-common-devel-2021.8.0.noarch is not installed
error: package intel-oneapi-ippcp-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-2021.5.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-2021.8.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.1.1.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.2.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.3.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.4.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.5.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.5.1.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.6.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.6.1.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.6.2.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.6.3.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.7.0.x86_64 is not installed
error: package intel-oneapi-ippcp-devel-32bit-2021.8.0.x86_64 is not installed
error: package intel-oneapi-ispc.x86_64 is not installed
error: package intel-oneapi-ispc-1.16.1.x86_64 is not installed
error: package intel-oneapi-ispc-1.17.0.x86_64 is not installed
error: package intel-oneapi-ispc-1.18.0.x86_64 is not installed
error: package intel-oneapi-ispc-1.18.1.x86_64 is not installed
error: package intel-oneapi-ispc-1.19.0.x86_64 is not installed
error: package intel-oneapi-ispc-1.20.0.x86_64 is not installed
error: package intel-oneapi-itac-2021.1.1.x86_64 is not installed
error: package intel-oneapi-itac-2021.10.0.x86_64 is not installed
error: package intel-oneapi-itac-2021.2.0.x86_64 is not installed
error: package intel-oneapi-itac-2021.3.0.x86_64 is not installed
error: package intel-oneapi-itac-2021.4.0.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2021.1.2.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2021.5.0.x86_64 is not installed
error: package intel-oneapi-libdpstd-devel-2022.2.0.x86_64 is not installed
error: package intel-oneapi-lpot.x86_64 is not installed
error: package intel-oneapi-mkl.x86_64 is not installed
error: package intel-oneapi-mkl-2021.1.1.x86_64 is not installed
error: package intel-oneapi-mkl-2021.2.0.x86_64 is not installed
error: package intel-oneapi-mkl-2021.3.0.x86_64 is not installed
error: package intel-oneapi-mkl-2021.4.0.x86_64 is not installed
error: package intel-oneapi-mkl-2022.0.1.x86_64 is not installed
error: package intel-oneapi-mkl-2023.2.0.x86_64 is not installed
error: package intel-oneapi-mkl-32bit.i686 is not installed
error: package intel-oneapi-mkl-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-mkl-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-mkl-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-mkl-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-mkl-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-mkl-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-mkl-common-2021.1.1.noarch is not installed
error: package intel-oneapi-mkl-common-2021.2.0.noarch is not installed
error: package intel-oneapi-mkl-common-2021.3.0.noarch is not installed
error: package intel-oneapi-mkl-common-2021.4.0.noarch is not installed
error: package intel-oneapi-mkl-common-2022.0.1.noarch is not installed
error: package intel-oneapi-mkl-common-2023.2.0.noarch is not installed
error: package intel-oneapi-mkl-common-devel-2021.1.1.noarch is not installed
error: package intel-oneapi-mkl-common-devel-2021.2.0.noarch is not installed
error: package intel-oneapi-mkl-common-devel-2021.3.0.noarch is not installed
error: package intel-oneapi-mkl-common-devel-2021.4.0.noarch is not installed
error: package intel-oneapi-mkl-common-devel-2022.0.1.noarch is not installed
error: package intel-oneapi-mkl-common-devel-2023.2.0.noarch is not installed
error: package intel-oneapi-mkl-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-mkl-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-2022.0.1.x86_64 is not installed
error: package intel-oneapi-mkl-devel-2023.2.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2021.1.1.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2021.2.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2021.3.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2021.4.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2022.0.1.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2022.0.2.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2022.1.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2022.2.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2022.2.1.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2023.0.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2023.1.0.x86_64 is not installed
error: package intel-oneapi-mkl-devel-32bit-2023.2.0.x86_64 is not installed
error: package intel-oneapi-model-zoo.x86_64 is not installed
error: package intel-oneapi-modin.x86_64 is not installed
error: package intel-oneapi-mpi.x86_64 is not installed
error: package intel-oneapi-mpi-2021.1.1.x86_64 is not installed
error: package intel-oneapi-mpi-2021.10.0.x86_64 is not installed
error: package intel-oneapi-mpi-2021.2.0.x86_64 is not installed
error: package intel-oneapi-mpi-2021.3.0.x86_64 is not installed
error: package intel-oneapi-mpi-2021.3.1.x86_64 is not installed
error: package intel-oneapi-mpi-2021.4.0.x86_64 is not installed
error: package intel-oneapi-mpi-2021.5.0.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.10.0.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.3.1.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-mpi-devel-2021.5.0.x86_64 is not installed
error: package intel-oneapi-neural-compressor.x86_64 is not installed
error: package intel-oneapi-oidn.x86_64 is not installed
error: package intel-oneapi-oidn-1.2.4.x86_64 is not installed
error: package intel-oneapi-oidn-1.3.0.x86_64 is not installed
error: package intel-oneapi-oidn-1.4.0.x86_64 is not installed
error: package intel-oneapi-oidn-1.4.1.x86_64 is not installed
error: package intel-oneapi-oidn-1.4.2.x86_64 is not installed
error: package intel-oneapi-oidn-1.4.3.x86_64 is not installed
error: package intel-oneapi-oidn-2.0.0.x86_64 is not installed
error: package intel-oneapi-onevpl.x86_64 is not installed
error: package intel-oneapi-onevpl-2021.1.1.x86_64 is not installed
error: package intel-oneapi-onevpl-2021.2.2.x86_64 is not installed
error: package intel-oneapi-onevpl-2021.4.0.x86_64 is not installed
error: package intel-oneapi-onevpl-2021.6.0.x86_64 is not installed
error: package intel-oneapi-onevpl-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-onevpl-devel-2021.2.2.x86_64 is not installed
error: package intel-oneapi-onevpl-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-onevpl-devel-2021.6.0.x86_64 is not installed
error: package intel-oneapi-openmp.x86_64 is not installed
error: package intel-oneapi-openmp-2021.1.1.x86_64 is not installed
error: package intel-oneapi-openmp-2021.1.2.x86_64 is not installed
error: package intel-oneapi-openmp-2021.2.0.x86_64 is not installed
error: package intel-oneapi-openmp-2021.3.0.x86_64 is not installed
error: package intel-oneapi-openmp-2021.4.0.x86_64 is not installed
error: package intel-oneapi-openmp-2022.0.1.x86_64 is not installed
error: package intel-oneapi-openmp-2023.2.0.x86_64 is not installed
error: package intel-oneapi-openmp-2023.2.1.x86_64 is not installed
error: package intel-oneapi-openmp-32bit.i686 is not installed
error: package intel-oneapi-openmp-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-openmp-32bit-2021.1.2.i686 is not installed
error: package intel-oneapi-openmp-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2022.0.1.i686 is not installed
error: package intel-oneapi-openmp-32bit-2022.0.2.i686 is not installed
error: package intel-oneapi-openmp-32bit-2022.1.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2022.2.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2022.2.1.i686 is not installed
error: package intel-oneapi-openmp-32bit-2023.0.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2023.1.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2023.2.0.i686 is not installed
error: package intel-oneapi-openmp-32bit-2023.2.1.i686 is not installed
error: package intel-oneapi-openmp-common-2021.1.1.noarch is not installed
error: package intel-oneapi-openmp-common-2021.1.2.noarch is not installed
error: package intel-oneapi-openmp-common-2021.2.0.noarch is not installed
error: package intel-oneapi-openmp-common-2021.3.0.noarch is not installed
error: package intel-oneapi-openmp-common-2021.4.0.noarch is not installed
error: package intel-oneapi-openmp-common-2022.0.1.noarch is not installed
error: package intel-oneapi-openmp-common-2023.2.0.noarch is not installed
error: package intel-oneapi-openmp-common-2023.2.1.noarch is not installed
error: package intel-oneapi-openpgl.x86_64 is not installed
error: package intel-oneapi-openpgl-0.5.0.x86_64 is not installed
error: package intel-oneapi-openvkl.x86_64 is not installed
error: package intel-oneapi-openvkl-0.11.0.x86_64 is not installed
error: package intel-oneapi-openvkl-0.12.0.x86_64 is not installed
error: package intel-oneapi-openvkl-0.13.0.x86_64 is not installed
error: package intel-oneapi-openvkl-1.0.0.x86_64 is not installed
error: package intel-oneapi-openvkl-1.1.0.x86_64 is not installed
error: package intel-oneapi-openvkl-1.2.0.x86_64 is not installed
error: package intel-oneapi-openvkl-1.3.0.x86_64 is not installed
error: package intel-oneapi-openvkl-1.3.1.x86_64 is not installed
error: package intel-oneapi-openvkl-1.3.2.x86_64 is not installed
error: package intel-oneapi-ospray.x86_64 is not installed
error: package intel-oneapi-ospray-2.10.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.11.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.12.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.4.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.5.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.6.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.7.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.8.0.x86_64 is not installed
error: package intel-oneapi-ospray-2.9.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.10.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.11.1.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.12.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.12.1.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.5.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.6.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.7.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.8.0.x86_64 is not installed
error: package intel-oneapi-ospray-studio-0.9.0.x86_64 is not installed
error: package intel-oneapi-pytorch.x86_64 is not installed
error: package intel-oneapi-rkcommon.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.10.0.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.11.0.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.5.0.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.6.0.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.6.1.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.7.0.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.8.0.x86_64 is not installed
error: package intel-oneapi-rkcommon-1.9.0.x86_64 is not installed
error: package intel-oneapi-rkutil.x86_64 is not installed
error: package intel-oneapi-rkutil-1.0.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.1.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.2.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.3.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.4.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.5.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.6.1.x86_64 is not installed
error: package intel-oneapi-rkutil-1.6.2.x86_64 is not installed
error: package intel-oneapi-rkutil-1.7.0.x86_64 is not installed
error: package intel-oneapi-rkutil-1.8.1.x86_64 is not installed
error: package intel-oneapi-runtime-ccl.x86_64 is not installed
error: package intel-oneapi-runtime-compilers.x86_64 is not installed
error: package intel-oneapi-runtime-compilers-32bit.i686 is not installed
error: package intel-oneapi-runtime-compilers-common.noarch is not installed
error: package intel-oneapi-runtime-dal.x86_64 is not installed
error: package intel-oneapi-runtime-dnnl.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-cpp.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-cpp-32bit.i686 is not installed
error: package intel-oneapi-runtime-dpcpp-cpp-common.noarch is not installed
error: package intel-oneapi-runtime-dpcpp-library.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-library-32bit.i686 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-core.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-cpu-rt.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-fpga-emul.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-fpga-rt.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-gpu-rt.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-opencl-cpu.x86_64 is not installed
error: package intel-oneapi-runtime-dpcpp-sycl-rt.x86_64 is not installed
error: package intel-oneapi-runtime-fortran.x86_64 is not installed
error: package intel-oneapi-runtime-fortran-32bit.i686 is not installed
error: package intel-oneapi-runtime-fortran-common.noarch is not installed
error: package intel-oneapi-runtime-ipp.x86_64 is not installed
error: package intel-oneapi-runtime-ipp-32bit.i686 is not installed
error: package intel-oneapi-runtime-ipp-common.noarch is not installed
error: package intel-oneapi-runtime-ipp-crypto.x86_64 is not installed
error: package intel-oneapi-runtime-ipp-crypto-32bit.i686 is not installed
error: package intel-oneapi-runtime-ipp-crypto-common.noarch is not installed
error: package intel-oneapi-runtime-libs.x86_64 is not installed
error: package intel-oneapi-runtime-libs-32bit.i686 is not installed
error: package intel-oneapi-runtime-mkl.x86_64 is not installed
error: package intel-oneapi-runtime-mkl-32bit.i686 is not installed
error: package intel-oneapi-runtime-mkl-common.noarch is not installed
error: package intel-oneapi-runtime-mpi.x86_64 is not installed
error: package intel-oneapi-runtime-opencl.x86_64 is not installed
error: package intel-oneapi-runtime-openmp.x86_64 is not installed
error: package intel-oneapi-runtime-openmp-32bit.i686 is not installed
error: package intel-oneapi-runtime-openmp-common.noarch is not installed
error: package intel-oneapi-runtime-tbb.x86_64 is not installed
error: package intel-oneapi-runtime-tbb-32bit.i686 is not installed
error: package intel-oneapi-runtime-tbb-common.noarch is not installed
error: package intel-oneapi-runtime-vpl.x86_64 is not installed
error: package intel-oneapi-tbb.x86_64 is not installed
error: package intel-oneapi-tbb-2021.1.1.x86_64 is not installed
error: package intel-oneapi-tbb-2021.10.0.x86_64 is not installed
error: package intel-oneapi-tbb-2021.3.0.x86_64 is not installed
error: package intel-oneapi-tbb-2021.4.0.x86_64 is not installed
error: package intel-oneapi-tbb-2021.5.0.x86_64 is not installed
error: package intel-oneapi-tbb-32bit.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.1.1.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.10.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.2.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.3.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.4.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.5.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.5.1.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.6.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.7.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.7.1.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.8.0.i686 is not installed
error: package intel-oneapi-tbb-32bit-2021.9.0.i686 is not installed
error: package intel-oneapi-tbb-common-2021.1.1.noarch is not installed
error: package intel-oneapi-tbb-common-2021.10.0.noarch is not installed
error: package intel-oneapi-tbb-common-2021.3.0.noarch is not installed
error: package intel-oneapi-tbb-common-2021.4.0.noarch is not installed
error: package intel-oneapi-tbb-common-2021.5.0.noarch is not installed
error: package intel-oneapi-tbb-common-devel-2021.1.1.noarch is not installed
error: package intel-oneapi-tbb-common-devel-2021.10.0.noarch is not installed
error: package intel-oneapi-tbb-common-devel-2021.2.0.noarch is not installed
error: package intel-oneapi-tbb-common-devel-2021.3.0.noarch is not installed
error: package intel-oneapi-tbb-common-devel-2021.4.0.noarch is not installed
error: package intel-oneapi-tbb-common-devel-2021.5.0.noarch is not installed
error: package intel-oneapi-tbb-devel-2021.1.1.x86_64 is not installed
error: package intel-oneapi-tbb-devel-2021.10.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-2021.2.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-2021.3.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-2021.4.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-2021.5.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.1.1.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.10.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.2.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.3.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.4.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.5.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.5.1.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.6.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.7.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.7.1.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.8.0.x86_64 is not installed
error: package intel-oneapi-tbb-devel-32bit-2021.9.0.x86_64 is not installed
error: package intel-oneapi-tensorflow.x86_64 is not installed
Hi Everyone
I would like to apologize for late reply on this thread, due to some system issues, this issue did not get escalated.
I would like to tell you that we are looking at this issue and working on fixing it ASAP. I will update once the issue is fixed.
Thanks for the reply. I was still waiting for an official fix, keeping the suite at the latest successful version.
You should be able to now install the supported release version of 2023.2 with a clean Fedora 38 system. Can you tell if this resolves your issue? or Was it something else you were looking for?
Note that Fedora 38 is only supported on 2023.2 release and compiler 2023.2.1 Patch.
I would also suggest running run yum clean all/dnf clean all command before trying to make sure there are no caching issues.
Negative. In my case is not a fresh installation, but an update.
Doing:
$>sudo dnf clean all
$> sudo dnf upgrade
Imported the new key:
Importing GPG key 0x53D04109:
Userid : "CN=Intel(R) Software Development Products"
Fingerprint: E9BF 0AFC 46D6 E8B7 DA58 82F1 BAC6 F0C3 53D0 4109
From : https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
Is this ok [y/N]: y
Key imported successfully
But still got an error:
Running transaction check
error: rpmdbNextIterator: skipping h# 24660
Header RSA signature: BAD (header tag 268: invalid OpenPGP signature: Parsing an OpenPGP packet:
Failed to parse Signature Packet
because: Signature appears to be created by a non-conformant OpenPGP implementation, see <h
ttps://github.com/rpm-software-management/rpm/issues/2351>.
because: Malformed MPI: leading bit is not set: expected bit 8 to be set in 1101101 (6d))
Header SHA256 digest: OK
Header SHA1 digest: OK
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: An rpm exception occurred: package not installed
Thanks, let me follow up with my team and get back to you.
None. The error reports a bad header signature, before any package is installed. I guess it means the header of the first rpm package it tries to install...
I also get same problem:
error: rpmdbNextIterator: skipping h# 12104
because: Signature appears to be created by a non-conformant OpenPGP implementation, see <https://github.com/rpm-software-management/rpm/issues/2351>.
because: Malformed MPI: leading bit is not set: expected bit 8 to be set in 1000110 (46))
Nothing is installed in my case.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
