oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1675 Discussions
Error when installing intel-oneapi-mkl-devel on CentOS 7
guillaumekln
The following commands terminate with an error on CentOS 7:
yum install -y yum-utils
yum-config-manager --add-repo https://yum.repos.intel.com/oneapi
rpm --import https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
yum install -y intel-oneapi-mkl-devel
 Here's the output:
Loaded plugins: fastestmirror, ovl
Loading mirror speeds from cached hostfile
 * base: mirrors.ircam.fr
 * extras: mirrors.ircam.fr
 * updates: ftp.pasteur.fr
yum.repos.intel.com_oneapi        | 1.5 kB  00:00:00
yum.repos.intel.com_oneapi/primary        | 807 kB  00:00:00
yum.repos.intel.com_oneapi        301/301
Resolving Dependencies
--> Running transaction check
---> Package intel-oneapi-mkl-devel.x86_64 0:2021.1.1-52 will be installed
--> Processing Dependency: intel-oneapi-mkl-devel-2021.1.1 for package: intel-oneapi-mkl-devel-2021.1.1-52.x86_64
---> Package intel-oneapi-mkl-devel-2021.1.1.x86_64 0:2021.1.1-52 will be installed
--> Processing Dependency: intel-oneapi-common-licensing for package: intel-oneapi-mkl-devel-2021.1.1-2021.1.1-52.x86_64
--> Processing Dependency: intel-oneapi-common-vars for package: intel-oneapi-mkl-devel-2021.1.1-2021.1.1-52.x86_64
--> Processing Dependency: intel-oneapi-condaindex for package: intel-oneapi-mkl-devel-2021.1.1-2021.1.1-52.x86_64
--> Processing Dependency: intel-oneapi-mkl-2021.1.1 for package: intel-oneapi-mkl-devel-2021.1.1-2021.1.1-52.x86_64
--> Processing Dependency: intel-oneapi-mkl-common-devel-2021.1.1 for package: intel-oneapi-mkl-devel-2021.1.1-2021.1.1-52.x86_64
---> Package intel-oneapi-common-licensing-2021.1.1.noarch 0:2021.1.1-60 will be installed
---> Package intel-oneapi-common-vars.noarch 0:2021.2.0-195 will be installed
---> Package intel-oneapi-condaindex.x86_64 0:2021.1.1-58 will be installed
---> Package intel-oneapi-mkl-2021.1.1.x86_64 0:2021.1.1-52 will be installed
--> Processing Dependency: intel-oneapi-tbb for package: intel-oneapi-mkl-2021.1.1-2021.1.1-52.x86_64
--> Processing Dependency: intel-oneapi-compiler-dpcpp-cpp-runtime for package: intel-oneapi-mkl-2021.1.1-2021.1.1-52.x86_64
--> Processing Dependency: intel-oneapi-mkl-common-2021.1.1 for package: intel-oneapi-mkl-2021.1.1-2021.1.1-52.x86_64
---> Package intel-oneapi-mkl-common-devel-2021.1.1.noarch 0:2021.1.1-52 will be installed
---> Package intel-oneapi-compiler-dpcpp-cpp-runtime.x86_64 0:2021.1.2-266 will be installed
--> Processing Dependency: intel-oneapi-compiler-dpcpp-cpp-runtime-2021.1.2 for package: intel-oneapi-compiler-dpcpp-cpp-runtime-2021.1.2-266.x86_64
---> Package intel-oneapi-mkl-common-2021.1.1.noarch 0:2021.1.1-52 will be installed
---> Package intel-oneapi-tbb.x86_64 0:2021.1.1-119 will be installed
--> Processing Dependency: intel-oneapi-tbb-2021.1.1 for package: intel-oneapi-tbb-2021.1.1-119.x86_64
---> Package intel-oneapi-compiler-dpcpp-cpp-runtime-2021.1.2.x86_64 0:2021.1.2-266 will be installed
--> Processing Dependency: intel-oneapi-compiler-shared-runtime-2021.1.2 for package: intel-oneapi-compiler-dpcpp-cpp-runtime-2021.1.2-2021.1.2-266.x86_64
---> Package intel-oneapi-tbb-2021.1.1.x86_64 0:2021.1.1-119 will be installed
--> Processing Dependency: intel-oneapi-tbb-common-2021.1.1 for package: intel-oneapi-tbb-2021.1.1-2021.1.1-119.x86_64
---> Package intel-oneapi-compiler-shared-runtime-2021.1.2.x86_64 0:2021.1.2-266 will be installed
--> Processing Dependency: intel-oneapi-openmp-2021.1.2 for package: intel-oneapi-compiler-shared-runtime-2021.1.2-2021.1.2-266.x86_64
--> Processing Dependency: intel-oneapi-compiler-shared-common-runtime-2021.1.2 for package: intel-oneapi-compiler-shared-runtime-2021.1.2-2021.1.2-266.x86_64
---> Package intel-oneapi-tbb-common-2021.1.1.noarch 0:2021.1.1-119 will be installed
---> Package intel-oneapi-compiler-shared-common-runtime-2021.1.2.noarch 0:2021.1.2-266 will be installed
---> Package intel-oneapi-openmp-2021.1.2.x86_64 0:2021.1.2-266 will be installed
--> Processing Dependency: intel-oneapi-openmp-common-2021.1.2 for package: intel-oneapi-openmp-2021.1.2-2021.1.2-266.x86_64
---> Package intel-oneapi-openmp-common-2021.1.2.noarch 0:2021.1.2-266 will be installed
--> Processing Conflict: intel-oneapi-common-vars-2021.2.0-195.noarch conflicts intel-oneapi-common-licensing < 2021.2.0
--> Finished Dependency Resolution
Error: intel-oneapi-common-vars conflicts with intel-oneapi-common-licensing-2021.1.1-2021.1.1-60.noarch
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
ArpanB_Intel
Hi Guillaume, please note that some of the tools of Intel® oneAPI Base Toolkit are not supported on CentOS 7. Tools such as oneCCL, oneDNN, and Intel oneAPI DPC++/C++ Compiler are not supported on CentOS 7. Thus we suggest you to upgrade your OS to CentOS 8.
ArpanB_Intel
