oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1328 Discussions
Errors while installing intel-aikit on debian 12
AndrewGardner
I have the intel-basekit and intel-hpckit packages installed. When I attempt to install intel-aikit, this is what I see. There appear to be two problems.
First, there appears to be a package in the manifest that isn't available on the server:
Err:1 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 104.106.49.222 443]
Second, there appears to be a conflict between two packages included in intel-aikit:
trying to overwrite '/opt/intel/oneapi/conda_channel/linux-64/lz4-c-1.9.4-h6a678d5_0.tar.bz2', which is also in package intel-oneapi-python 2023.1.0-46399
Here's the full output:
apt install -y --fix-missing intel-aikit
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
intel-aikit-getting-started intel-oneapi-common-licensing-2023.0.0 intel-oneapi-dal-daal4py-2023.1.0
intel-oneapi-dal-scikit-learn-intelex-2023.1.0 intel-oneapi-model-zoo intel-oneapi-modin intel-oneapi-mpi-2021.8.0
intel-oneapi-mpi-devel-2021.8.0 intel-oneapi-neural-compressor intel-oneapi-python intel-oneapi-pytorch intel-oneapi-tensorflow
The following NEW packages will be installed:
intel-aikit intel-aikit-getting-started intel-oneapi-common-licensing-2023.0.0 intel-oneapi-dal-daal4py-2023.1.0
0 upgraded, 13 newly installed, 0 to remove and 0 not upgraded.
Need to get 462 MB/2,065 MB of archives.
After this operation, 2,479 MB of additional disk space will be used.
Selecting previously unselected package intel-aikit-getting-started.
(Reading database ... 335759 files and directories currently installed.)
Preparing to unpack .../00-intel-aikit-getting-started_2023.1.0-31760_all.deb ...
Unpacking intel-aikit-getting-started (2023.1.0-31760) ...
Selecting previously unselected package intel-oneapi-common-licensing-2023.0.0.
Preparing to unpack .../01-intel-oneapi-common-licensing-2023.0.0_2023.0.0-25325_all.deb ...
Unpacking intel-oneapi-common-licensing-2023.0.0 (2023.0.0-25325) ...
Selecting previously unselected package intel-oneapi-model-zoo.
Preparing to unpack .../02-intel-oneapi-model-zoo_2.9.0-29666_amd64.deb ...
Unpacking intel-oneapi-model-zoo (2.9.0-29666) ...
Selecting previously unselected package intel-oneapi-dal-daal4py-2023.1.0.
Preparing to unpack .../03-intel-oneapi-dal-daal4py-2023.1.0_2023.1.0-46349_amd64.deb ...
Unpacking intel-oneapi-dal-daal4py-2023.1.0 (2023.1.0-46349) ...
Selecting previously unselected package intel-oneapi-dal-scikit-learn-intelex-2023.1.0.
Preparing to unpack .../04-intel-oneapi-dal-scikit-learn-intelex-2023.1.0_2023.1.0-46349_amd64.deb ...
Unpacking intel-oneapi-dal-scikit-learn-intelex-2023.1.0 (2023.1.0-46349) ...
Selecting previously unselected package intel-oneapi-python.
Preparing to unpack .../05-intel-oneapi-python_2023.1.0-46399_amd64.deb ...
Unpacking intel-oneapi-python (2023.1.0-46399) ...
Selecting previously unselected package intel-oneapi-mpi-2021.8.0.
Preparing to unpack .../06-intel-oneapi-mpi-2021.8.0_2021.8.0-25329_amd64.deb ...
Unpacking intel-oneapi-mpi-2021.8.0 (2021.8.0-25329) ...
Selecting previously unselected package intel-oneapi-mpi-devel-2021.8.0.
Preparing to unpack .../07-intel-oneapi-mpi-devel-2021.8.0_2021.8.0-25329_amd64.deb ...
Unpacking intel-oneapi-mpi-devel-2021.8.0 (2021.8.0-25329) ...
Selecting previously unselected package intel-oneapi-tensorflow.
Preparing to unpack .../08-intel-oneapi-tensorflow_2.10.0.0-31758_amd64.deb ...
Unpacking intel-oneapi-tensorflow (2.10.0.0-31758) ...
Selecting previously unselected package intel-oneapi-neural-compressor.
Preparing to unpack .../09-intel-oneapi-neural-compressor_1.14.2.0-31757_amd64.deb ...
Unpacking intel-oneapi-neural-compressor (1.14.2.0-31757) ...
Preparing to unpack .../10-intel-oneapi-modin_0.17.0.1-31755_amd64.deb ...
Unpacking intel-oneapi-modin (0.17.0.1-31755) ...
dpkg: error processing archive /tmp/apt-dpkg-install-XTnHeT/10-intel-oneapi-modin_0.17.0.1-31755_amd64.deb (--unpack):
Selecting previously unselected package intel-aikit.
Preparing to unpack .../11-intel-aikit_2023.1.0-31760_amd64.deb ...
Unpacking intel-aikit (2023.1.0-31760) ...
Errors were encountered while processing:
needrestart is being skipped since dpkg has failed
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 104.106.49.222 443]
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@debian:/opt/intel/oneapi#
ArpanB_Intel
Hi Andrew, Intel® AI Analytics Toolkit is not supported on Debian 12.
To know more, visit here: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-ai-analytics-toolkit-system-requirements.html
AndrewGardner
Understood. However, the 2022 update packages worked just fine with the apt repositories. In any case, I will just switch to using it with the non-package-manager installer.
ArpanB_Intel
Andrew, the toolkits are tested on a selected list of platforms prior to their release which make up the list of supported platforms.
It may or may work on other platforms as well. However, if it does not work, Intel® will not be able to support those issues.
AndrewGardner
I get the exact same error in Ubuntu 20.04, which is on the supported list.
sudo apt install intel-aikit
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 104.106.49.22 443]
whatheway
Intel is looking into it according to what they said on my post.
Someone goofed and forgot to upload the link to the .deb file most likely.
Quant-Geek
See https://community.intel.com/t5/oneAPI-Registration-Download/Intel-oneAPI-Debian-Repo-Broken/m-p/1473782 for a resolution. This fixed my installation problem on Ubuntu.  Short story.  Uninstall oneAPI python and reinstall:
sudo apt remove intel-oneapi-python
sudo apt autoremove
and reinstalling with :
sudo apt install intel-oneapi-python
whatheway
workhorse@workhorse-MS-7D91:~$ sudo apt remove intel-aikit
[sudo] password for workhorse:
Package 'intel-aikit' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
workhorse@workhorse-MS-7D91:~$ sudo apt autoremove
workhorse@workhorse-MS-7D91:~$ sudo apt install intel-oneapi-python
intel-oneapi-dal-scikit-learn-intelex-2023.1.0 intel-oneapi-python
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/281 MB of archives.
After this operation, 283 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 261437 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-dal-daal4py-2023.1.0_2023.1.0-46349_amd64.d
eb ...
23.1.0.
Preparing to unpack .../intel-oneapi-dal-scikit-learn-intelex-2023.1.0_2023.1.0-
46349_amd64.deb ...
Preparing to unpack .../intel-oneapi-python_2023.1.0-46399_amd64.deb ...
Setting up intel-oneapi-dal-scikit-learn-intelex-2023.1.0 (2023.1.0-46349) ...
Setting up intel-oneapi-dal-daal4py-2023.1.0 (2023.1.0-46349) ...
Setting up intel-oneapi-python (2023.1.0-46399) ...
workhorse@workhorse-MS-7D91:~$ sudo apt install intel-aikit
intel-oneapi-common-licensing-2023.0.0 intel-oneapi-model-zoo
intel-oneapi-modin intel-oneapi-mpi-2021.8.0 intel-oneapi-mpi-devel-2021.8.0
intel-oneapi-neural-compressor intel-oneapi-pytorch intel-oneapi-tensorflow
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 462 MB/1,784 MB of archives.
After this operation, 2,197 MB of additional disk space will be used.
404 Not Found [IP: 104.69.89.197 443]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 104.69.89.197 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Still doesn't fix the pytorch issue.
whatheway
This doesn't seem to work if you don't have aikit installed yet
ArpanB_Intel
Andrew, we have been intimated that Intel® AI Analytics Toolkit is not supported on Debian 12. The supported OS platforms are Ubuntu* LTS v20.04, v22.04, Red Hat* Enterprise Linux* 8 ( only GPU Max Series), SUSE* Linux Enterprise Server* 15 SP3 ( only GPU Max Series).
For more information, visit here: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-ai-analytics-toolkit-system-requirements.html
ArpanB_Intel
Andrew, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
