I have been using the Base Toolkit and the HPC toolkit without problems but when the installer offered updates today I tried to install them but I encountered a number of errors. So I decided to uninstall both Toolkits and reinstall them from scratch. But uninstall fails to remove the toolkits and raises an error window that quickly disappears but which I have managed to capture in the attached image.
Now none of the installer options work and all come up with this same image so I cannot even run the repair options.
So my two toolkit installs are now in an unusable state and I have no way of either removing or repairing them.
Is there any way I can completely remove them and start again? Any advice would be much appreciated.
Hi Brian, we have sent you a private message. Kindly check your community inbox.
![](/skins/images/62F5F803C638BF2554D48A7D62AEDECA/responsive_peak/images/icon_anonymous_message.png)
