Try the following dockerfile:
```dockerfile
FROM fedora:40
COPY <<EOF /etc/yum.repos.d/oneAPI.repo
[oneAPI]
name=Intel(R) oneAPI repository
baseurl=https://yum.repos.intel.com/oneapi
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
EOF
RUN dnf install -y \
g++
intel-oneapi-compiler-dpcpp-cpp
openmpi-devel
RUN <<EOF
set -e
source /etc/profile.d/modules.sh
module load mpi/openmpi
mpicxx --version
EOF
This gives the error
mpicxx: error while loading shared libraries: libhwloc.so.15: cannot open shared object file: No such file or directory
even though it should be using `g++` and `openmpi` there. If we switch the installation of `openmpi-devel` to be above the intel packages than it works fine again. This issue is most likely in the scriplets that are executed.
Hi Crisian, Could you please share the below details with us?
- Exact name of the Intel® Toolkit along with its build version.
- Build version of Operating System (Fedora) on which you're installing the product.
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
- Is the installer an online or an offline package?
- Screenshot (if any)
To assist you further, we would require these details.
I have already provided you with a reproducable environment. Please build the dockerfile as instructed. If you pay atention, all of the answers to your questions are there:
- latest version available in https://yum.repos.intel.com/oneapi. Try playing around with the dockerfile and you would see it is reproducible with any version
- fedora:40
- it's a clean container, so of course not
- rpm repo
- just build the dockerfile and take whatever screenshots you want
I have put the effort to minimize the reproducable environment to a simple containerfile, the least you could do is return the courtesy of not replying with a copy-pasted request for more information, when all of the information is evidently in the first comment.
Hi Cristian,
Thank you so much for your efforts in minimizing the reproducible environment to a simple container file. However, we would like to inform you that we are unable to open the Docker file, as it results in an error. This is why we requested that you share the details.
We appreciate your continued cooperation and look forward to assisting you further.
Thanks! Have a great day ahead!
Again, please read and take my issue seriously. The error in the build process *IS* the issue that I am reporting on. The issue is that depending on the order of installations, intel packages affect system packages, in this case, after installing `intel-oneapi-compiler-dpcpp-cpp` (in step 3), system packages like`openmpi` are affected (in step 4), as shown in step 5 where we try to load the openmpi, but fail with cannot open `libhwloc.so.15`.
And again, I've said from the beginning that this is order dependent and you can simply swap step 3 and step 4 to get a working environment to debug, i.e.:
```dockerfile
FROM fedora:40
[oneAPI]
enabled=1
gpgcheck=1
repo_gpgcheck=1
EOF
g++
openmpi-devel
RUN <<EOF
set -e
mpicxx --version
EOF
