I installed the Fortran Compiler Classic 2022 and integrated it with Studio 2022 and everything worked fine.
I have other development tools that require Studio 2019. I installed Studio 2019 and attempted to integrate the Fortran compiler by uninstalling it and reinstalling.
During the reinstall, I get the error Unable to complete installation. Removal of component has failed intel.oneapi.win.ifort-compiler.ide.vs2019.
Attached is the installation log and a screen capture of the install screen.
Any assistance would be appreciated.
Thank you!
Hi BruceB,
Thanks for the information. We would suggest you to kindly go through the below steps.
- Please note, our engineering team has tested and validated a list of supported Visual Studio versions for the Intel® oneAPI Base Toolkit versions. We would recommend you choose from them.
- Make sure to install the version of Visual studio with "Desktop Development with C++" component selection.
- Repair the installed Intel® Fortran compiler with the same installer.
Kindly proceed with the steps only when the previous step has been completed. However, do let us know if you come across any queries or concerns.
Soumya
I'm moving this thread over to the Installation Forum. They can help you best there.
Can you provide a link to the Installation Forum where the answer to this issue is hopefully located?
I'm still unable to install or uninstall the compiler.
Hi BruceB,
Thanks for posting your concern on the forum. Please let us know the below details.
- The build number of the Visual Studio 2022.
- A copy of the current Visual Studio 2019 Info (using 'Copy Info') from 'About' of the Help section of the Visual Studio version.
- Is Visual Studio 2022 still on the system, alongside Visual Studio 2019? If yes, kindly provide a copy of its info as well.
- The version of the Windows operating system.
- Is there an update of version 2017 or any other version of the Intel® Fortran compiler Classic (other than 2022) installed on the system?
The above information would provide us with a better understanding of the concern.
Soumya
Hi Soumya,
See my responses below.
The build number of the Visual Studio 2022. - Uninstalled from my system
Microsoft Visual Studio Professional 2019
Version 16.11.11
VisualStudio.16.Release/16.11.11+32228.343
Microsoft .NET Framework
Version 4.8.04084
Installed Version: Professional
Visual C++ 2019 00435-60000-00000-AA218
Microsoft Visual C++ 2019
ADL Tools Service Provider 1.0
This package contains services used by Data Lake tools
ASA Service Provider 1.0
ASP.NET and Web Tools 2019 16.11.106.23128
ASP.NET Web Frameworks and Tools 2019 16.11.106.23128
For additional information, visit https://www.asp.net/
Azure App Service Tools v3.0.0 16.11.106.23128
Azure Data Lake Node 1.0
This package contains the Data Lake integration nodes for Server Explorer.
Azure Data Lake Tools for Visual Studio 2.6.1000.0
Microsoft Azure Data Lake Tools for Visual Studio
Azure Functions and Web Jobs Tools 16.11.106.23128
Azure Stream Analytics Tools for Visual Studio 2.6.1000.0
Microsoft Azure Stream Analytics Tools for Visual Studio
C# Tools 3.11.0-4.22108.8+d9bef045c4362fbcab27ef35daec4e95c8ff47e1
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools 1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Fabric.DiagnosticEvents 1.0
Fabric Diagnostic Events
IntelliCode Extension 1.0
IntelliCode Visual Studio Extension Detailed Info
Microsoft Azure HDInsight Azure Node 2.6.1000.0
HDInsight Node under Azure Node
Microsoft Azure Hive Query Language Service 2.6.1000.0
Language service for Hive query
Microsoft Azure Service Fabric Tools for Visual Studio 16.10
Microsoft Azure Stream Analytics Language Service 2.6.1000.0
Language service for Azure Stream Analytics
Microsoft Azure Stream Analytics Node 1.0
Azure Stream Analytics Node under Azure Node
Microsoft Azure Tools for Visual Studio 2.9
Support for Azure Cloud Services projects
Microsoft Continuous Delivery Tools for Visual Studio 0.4
Simplifying the configuration of Azure DevOps pipelines from within the Visual Studio IDE.
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft Library Manager 2.1.113+g422d40002e.RR
Install client-side libraries easily to any web project
Microsoft MI-Based Debugger 1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards 1.0
Microsoft Visual Studio Tools for Containers 1.2
Develop, run, validate your ASP.NET Core applications in the target environment. F5 your application directly into a container with debugging, or CTRL + F5 to edit & refresh your app without having to rebuild the container.
Microsoft Visual Studio VC Package 1.0
NuGet Package Manager 5.11.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension 1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Razor (ASP.NET Core) 16.1.0.2122504+13c05c96ea6bdbe550bd88b0bf6cdddf8cde1725
Provides languages services for ASP.NET Core Razor.
SQL Server Data Tools 16.0.62201.17150
Microsoft SQL Server Data Tools
Syncfusion Reference Manager 19.4.0.48
A useful add-in for adding and migrating Syncfusion Assembly References for Windows Forms, WPF, and Silverlight projects.
Syncfusion.VSExtension.Troubleshooter 19.4.0.48
Add-in for Troubleshooting the Syncfusion projects.
Syncfusion.WindowsForms.Package 19.4.0.48
Provides Item/Project Templates to add Syncfusion Windows Forms Item/Project along with corresponding configurations.
SyncfusionMenu Extension 1.0
SyncfusionMenu Visual Studio Extension Detailed Info
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
ToolWindowHostedEditor 1.0
Hosting json editor into a tool window
TypeScript Tools 16.0.30526.2002
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 3.11.0-4.22108.8+d9bef045c4362fbcab27ef35daec4e95c8ff47e1
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual F# Tools 16.11.0-beta.21514.6+b6c2c4f53ea3a08fa603ea93d6d2f808a62a21d1
Microsoft Visual F# Tools
Visual Studio Code Debug Adapter Host Package 1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Container Tools Extensions 1.0
View, manage, and diagnose containers within Visual Studio.
Visual Studio Tools for CMake 1.0
Visual Studio Tools for Containers 1.0
Visual Studio Tools for Kubernetes 1.0
No longer on the system.
Edition Windows 10 Pro
Version 21H2
Installed on 1/25/2021
OS build 19044.1586
Experience Windows Feature Experience Pack 120.2212.4170.0
Here's a listing of the Intel products on my machine.
Hi BruceB,
Soumya
Hi BruceB,
Please let us know if you come across any queries or concerns.
Soumya
I tried the steps in your previous response and I still cannot install or uninstall the compiler.
Hi BruceB,
Thanks for the update, Please try the below workaround steps. They may seem quite similar to the set of steps provided previously, however, these are for complete uninstallation and clean installation. Please proceed with the steps only when the previous step has been completed.
- Uninstall Visual Studio and any remaining traces of all the versions installed. Kindly visit the below link to find Microsoft's recommended ways to uninstall and remove Visual Studio completely.
- Use the installer for the currently installed Intel® oneAPI Base Toolkit and try repairing it now through the installer.
- Uninstall the repaired version through the same Intel® oneAPI Base Toolkit installer
- Install a validated Visual Studio version with the Desktop development with C++ component selected.
- Try installing the Intel® oneAPI Base Toolkit.
However, please let us know the below details, if the issue persists.
- A copy of the installed Visual Studio info.
- The logs from the oneapi %TEMP% directory
Soumya
Hi BruceB,
We understand that you might be testing the workaround with respect to our last response on the thread. However, we figured it would be worth checking in.
Kindly update us if your issue has been resolved. Please let us know if you come across any queries or concerns regarding the same. Looking forward to your update.
Soumya
Hi BruceB,
We understand that you might be looking into the issue. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this thread active.
Soumya
