I would like to mirror (sync) Intel oneAPI repo to create a local mirror for Cobbler. I have added Intel oneAPI repo in Cobbler, but when I run "reposync", repo created and mirrored is too big (more than 100 GB...). What is the size of the Intel oneAPI repo? Is it possible to mirror only some packages discarding old versions and, only, mirror newest version of each package?
Hi Daniel, could you share the OS Platform on which you are using the software? Also, please share the toolkit or tool you are using?
We would like to know.
I have installed Intel-oneAPI in some machines from my students lab. That machines are Intel i7 and Intel Xeon. OS is, in all machines, CentOS-7, but in a few weeks, all nodes are going to be upgraded to Rocky Linux.
I'm the lab sysadmin, so I can't specify the tools that are being used by teachers and students, but, for example, I know that "icc" compiler is one of the tools more frequently used.
Daniel, thank you for the information.
We will move your thread to the relevant forum for further support.
>>Is it possible to mirror only some packages...
You can install the required packages(latest version) using the standalone version of the components.
You can use the "--newest-only" flag so that it will download the newest version of each package in the repository by discarding older versions.
Please refer to the below link to get standalone components:
https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html
Thanks & Regards,
Noorjahan.
I have added "-n" flag to Cobbler reposync options (reposync_flags: "-l -n -d") to allow option "--newest-only" but, when I run "cobbler reposync --only=Intel-oneAPI", I get this:
[root@puppet Intel-oneAPI]# ls -lhart
total 196K
-rw-r--r-- 1 root root 2,6K ene 30 20:36 intel-aikit-32bit-2022.1.2-2022.1.2-135.i686.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:36 intel-aikit-32bit-2022.1.1-2022.1.1-106.i686.rpm
-rw-r--r-- 1 root root 3,1K ene 30 20:36 intel-aikit-2021.1.0-2021.1.0-935.x86_64.rpm
-rw-r--r-- 1 root root 6,9K ene 30 20:36 intel-aikit-32bit-2023.0.0-2023.0.0-26100.i686.rpm
-rw-r--r-- 1 root root 6,9K ene 30 20:36 intel-aikit-32bit-2022.3.1-2022.3.1-20890.i686.rpm
-rw-r--r-- 1 root root 6,9K ene 30 20:36 intel-aikit-32bit-2022.3.0-2022.3.0-8775.i686.rpm
-rw-r--r-- 1 root root 6,8K ene 30 20:36 intel-aikit-32bit-2022.2.0-2022.2.0-231.i686.rpm
-rw-r--r-- 1 root root 2,4K ene 30 20:36 intel-aikit-runtime-2021.1.0-2021.1.0-935.x86_64.rpm
-rw-r--r-- 1 root root 9,1K ene 30 20:36 intel-aikit-getting-started-2023.1.0-31760.noarch.rpm
-rw-r--r-- 1 root root 6,9K ene 30 20:36 intel-aikit-32bit-2023.1.0-31760.i686.rpm
-rw-r--r-- 1 root root 6,9K ene 30 20:36 intel-aikit-32bit-2023.1.0-2023.1.0-31760.i686.rpm
-rw-r--r-- 1 root root 3,4K ene 30 20:36 intel-aikit-2022.1.1-2022.1.1-106.x86_64.rpm
-rw-r--r-- 1 root root 3,4K ene 30 20:36 intel-aikit-2021.4.0-2021.4.0-1460.x86_64.rpm
-rw-r--r-- 1 root root 6,9K ene 30 20:37 intel-aikit-runtime-2023.1.0-31760.x86_64.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-runtime-2022.1.2-2022.1.2-135.x86_64.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-runtime-2022.1.1-2022.1.1-106.x86_64.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-runtime-2021.4.0-2021.4.0-1460.x86_64.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-runtime-2021.3.0-2021.3.0-1370.x86_64.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-runtime-2021.2.0-2021.2.0-1101.x86_64.rpm
-rw-r--r-- 1 root root 3,4K ene 30 20:37 intel-aikit-2022.1.2-2022.1.2-135.x86_64.rpm
-rw-r--r-- 1 root root 3,4K ene 30 20:37 intel-aikit-2021.2.0-2021.2.0-1101.x86_64.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-32bit-2021.4.0-2021.4.0-1460.i686.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-32bit-2021.3.0-2021.3.0-1370.i686.rpm
-rw-r--r-- 1 root root 2,6K ene 30 20:37 intel-aikit-32bit-2021.2.0-2021.2.0-1101.i686.rpm
-rw-r--r-- 1 root root 2,5K ene 30 20:37 intel-aikit-32bit-2021.1.0-2021.1.0-935.i686.rpm
-rw-r--r-- 1 root root 7,7K ene 30 20:37 intel-aikit-2023.1.0-31760.x86_64.rpm
-rw-r--r-- 1 root root 7,7K ene 30 20:37 intel-aikit-2023.1.0-2023.1.0-31760.x86_64.rpm
-rw-r--r-- 1 root root 7,7K ene 30 20:37 intel-aikit-2023.0.0-2023.0.0-26100.x86_64.rpm
-rw-r--r-- 1 root root 7,7K ene 30 20:37 intel-aikit-2022.3.1-2022.3.1-20890.x86_64.rpm
-rw-r--r-- 1 root root 7,7K ene 30 20:37 intel-aikit-2022.3.0-2022.3.0-8775.x86_64.rpm
-rw-r--r-- 1 root root 7,7K ene 30 20:37 intel-aikit-2022.2.0-2022.2.0-231.x86_64.rpm
-rw-r--r-- 1 root root 3,4K ene 30 20:37 intel-aikit-2021.3.0-2021.3.0-1370.x86_64.rpm
drwxr-xr-x 3 root root 26 feb 20 08:49 ..
drwxr-xr-x 2 root root 31 feb 20 08:49 .origin
-rw-r--r-- 1 root root 129 feb 20 08:49 config.repo
-rw-r--r-- 1 root root 0 feb 20 08:49 intel-aikit-runtime-2022.2.0-2022.2.0-231.x86_64.rpm
-rw-r--r-- 1 root root 0 feb 20 08:49 intel-aikit-runtime-2022.3.0-2022.3.0-8775.x86_64.rpm
drwxr-xr-x 3 root root 4,0K feb 20 08:49 .
Here, you can see that, for example, for package "intel-aikit", cobbler reposync has downloaded some versions, not only newest.
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
Pendyala Sesha Srinivas
I have answered above. I think "--newest-only" doesn't solve my problem... or I'm doing some wrong...
Hi Daniel,
Thanks for getting back to us with the information. We are checking on the issue with our resources. Please wait for 2-3 business days. We will get back to you as soon as possible.
Hope you have a nice day ahead!
Soumya
Daniel, the oneAPI repository also contains standalone components, which are packages that provide a specific tool for cases where you do not need an entire toolkit which might take up more space than it is required for our users.
To know more on this, visit here: https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2023-0/list-available-toolkits-components-and-runtime.html#LIST-AVAILABLE-PACKAGES
Daniel, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
![](/skins/images/2F496A9BF2E73260E2FDFDBCABF91248/responsive_peak/images/icon_anonymous_message.png)
