oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
How to move OneAPI to another drive?
AndrewRain
I installed OneAPI to HDD and wanted to move to another SSD drive. By default Intel doesn't allow to do this even if I delete folder manually. It forces user to reinstall it to the first place you installed it, which is incredibly dumb decision. I hope you add options to install to another drive and uninstall.
So I returned deleted OneAPI from the trash and move from HDD to SSD manually. It launched but now I get those errors. How bad are they? How to relink those "missing" files to a new drive?
E:\sdnext>E:\Intel\oneAPI\2025.0\oneapi-vars.bat
:: initializing oneAPI environment...
Initializing Visual Studio command-line environment...
Visual Studio version 17.12.3 environment configured.
"C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\"
Visual Studio command-line environment initialized for: 'x64'
:: advisor -- processing etc\advisor\vars.bat
Error: Product installation not found.
Please launch script within product installation directory
:: compiler -- processing etc\compiler\vars.bat
:: dal -- processing etc\dal\vars.bat
:: debugger -- processing etc\debugger\vars.bat
:: dnnl -- processing etc\dnnl\vars.bat
:: dpct -- processing etc\dpct\vars.bat
:: dpl -- processing etc\dpl\vars.bat
:: ipp -- processing etc\ipp\vars.bat
:: ippcp -- processing etc\ippcp\vars.bat
:: mkl -- processing etc\mkl\vars.bat
:: pti -- processing etc\pti\vars.bat
:: tbb -- processing etc\tbb\vars.bat
:: vtune -- processing etc\vtune\vars.bat
:: oneAPI environment initialized ::
Deeksha_S_Intel
Hi Andrew, we have sent you a private message. Kindly check your inbox.
Deeksha_S_Intel
Hi Andrew,
We would like to inform you that Intel® oneAPI Toolkit will be installed in the default directory: C:\Program Files(x86)\Intel\oneAPI, unless a different location is selected during the installation. As per Intel® Documentation you have the option to customize the installation directory. We recommend performing a fresh installation of Intel® oneAPI Toolkit on an SSD.
For more info, kindly go through below link :
Link : Intel® oneAPI Toolkits Installation Guide
Feel free to let us know if you have any other concern.
Have a great day ahead!
AndrewRain
No, as I said before, if you accidently installed OneAPI to the wrong drive you're done for.
There are no non-programmer way to move it to another drive.
Deeksha_S_Intel
Hi Andrew,
Could you please share the below details with us?
  • Before moving the Intel® oneAPI Base toolkit, was it working correctly on the HDD without any errors?
  • Have you tried reinstalling Intel® oneAPI Base toolkit on SSD instead of moving it manually? If not, is there any reason you prefer to move it rather than reinstall?
  • We Previously recommended performing a fresh installation on the SSD. Could you confirm if you have done so?
  • To better understand your query and provide an effective resolution, could you please share more details about the issue?
To assist you further, we would require these details.
AndrewRain
Are you kidding me? It's not a preference, I just can't find a way.
1. I can't find a way to uninstall OneAPI completely.
2. I can't find a way to move OneAPI to another drive in a better way than I already did.
3. That's why I can't make a fresh install, it always installs itself to the wrong drive and I can't change the drive or even folder.
No I can't, guess I'll just use it on HDD.
Deeksha_S_Intel
Deeksha_S_Intel
Deeksha_S_Intel
Deeksha_S_Intel
Hi Andrew, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
