Since a Intel Distribution for Python 2024.2 came out, the intel python package repos on anaconda are not to be found anymore and the new package repo suggested by intel is also down (see image below).
Any advice on how to install additional python packages and create new conda environments?
Hi Stef,
Sorry, this time from me for the late reply.
It finally worked, but not until I set "allow_non_channel_urls" to true, as suggested here.
This work needed since conda still seems to search for the old intel repo hosted on anaconda servers even though the .condarc file doesn't show 'intel'.
Thanks for your help!
Best
Srihari
Hi Srihari,
Please note that we are working on a solution and will provide you with an answer as soon as possible.
Stef
Hi Srihari,
Please execute the following command to install packages:
conda install -c https://software.repos.intel.com/python/conda/ -c conda-forge <package_name>
For a specific version:
conda install -c https://software.repos.intel.com/python/conda/ -c conda-forge <package_name>==<version>
If you encounter any issues, let me know.
Best,
Stef
Hi Stef,
Thanks for the advice. But this also gives the same old error, "HTTP 403 FORBIDDEN for channel intel " & " Channel is not accessible or is invalid".
I've posted a screenshot.
Best,
Srihari
Could you please try running
conda config --remove channels intel
and re-try the previous command?
Stef
Hi Stef,
I did "config --remove" the intel channel & I manually checked the .condarc file & it does not have the "intel" channel listed but it still
Despite that it still shows exactly the output i.e. the intel channel in the list.
Could that channel be causing the problem? Because the https://software.repos.intel.com/python/conda/ website is still down.
Best,
Srihari
Hi Srihari,
Sorry for the late reply. Please note that https://software.repos.intel.com/python/conda/ is not a website and you should be able to use it as a conda channel. Could you please install miniforge and let us know if you're encountering the same issue?
Thank you,
Stef
Hi Stef,
Best
Srihari
Hi Srihari,
Thank you for sharing the solution with the community!
Have a great day,
Stef
