oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1429 Discussions
Install conflicts for /opt/intel/oneapi/lib/intel64/bin/tune 2021.9/2021.10
Orion_P_
When trying to update my intel-oneapi packages:
Error: Transaction test error:
 file /opt/intel/oneapi/lib/intel64/bin/tune from install of intel-oneapi-runtime-mpi-2021.10.0-4
9371.x86_64 conflicts with file from package intel-oneapi-runtime-mpi-2021.9.0-43482.x86_64
Orion_P_
So, we are going from a directory:
# ls -l  /opt/intel/oneapi/lib/intel64/bin/tune
total 12608
-rwxr-xr-x. 1 root root 12906728 Mar  7 15:48 mpitune*
To a symbolic link:
lrwxrwxrwx. 1 root root 9 Jun 30 04:42 /opt/intel/oneapi/lib/intel64/bin/tune -> tune_fast/
RPM cannot support this.  See https://docs.fedoraproject.org/en-US/packaging-guidelines/Directory_Replacement/ for more information and a workaround.
ArpanB_Intel
Hi Orion, please share the below information with us:
- Linux distribution on which you are installing the software
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on your system
- Is the installer an online or an offline package?
- Installation Log files
The default path for a log file for a oneAPI installation is: opt/intel/oneapi/logs
The default path for a log file for a Parallel Studio XE installation is: /tmp/intel.pset.<user>.<machine>.<timestamp>.log
We would like to know.
Orion_P_
This is on AlmaLinux 8.  We are simply doing yum installs of the desired packages from the oneAPI yum repo https://yum.repos.intel.com
/oneapi.
ArpanB_Intel
Orion, thank you for the information. Do you have older runtime installations in your current installation directory?
Orion_P_
The issue comes when you try to upgrade from intel-oneapi-runtime-mpi-2021.9.0-43482.x86_64 to intel-oneapi-runtime-mpi-2021.10.0-49371.x86_64.  So to reproduce:
yum install intel-oneapi-runtime-mpi-2021.9.0-43482.x86_64
yum upgrade intel-oneapi-runtime-mpi
Last metadata expiration check: 2:26:38 ago on Thu 20 Jul 2023 10:59:46 AM MDT.
Dependencies resolved.
Package                           Architecture    Version                  Repository       Size
Upgrading:
intel-oneapi-runtime-mpi          x86_64          2021.10.0-49371          oneAPI           22 M
Transaction Summary
Upgrade  1 Package
Total download size: 22 M
Is this ok [y/N]: y
Downloading Packages:
intel-oneapi-runtime-mpi-2021.10.0-49371.x86_64.rpm               6.1 MB/s |  22 MB     00:03
Total                                                             6.0 MB/s |  22 MB     00:03
Running transaction check
Transaction check succeeded.
Running transaction test
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'yum clean packages'.
ArpanB_Intel
Orion, could you try installing the new version of packages in a different directory or uninstall the older packages and then install the new one?
Orion_P_
That works fine, it's only the upgrade path that fails.  I suggest reading the Fedora Packaging docs page I linked initially - it describes the issue and possible fixes.
ArpanB_Intel
Orion, we have contacted you internally with some information. Please check your inbox for further updates.
ArpanB_Intel
Orion, you can try using the below commands:
$ sudo yum remove rpmforge-release
$ sudo yum update -y
Please note AlmaLinux 8 is not supported by Intel® oneAPI Base Toolkit. To know more, please visit: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html#inpage-nav-2-undefined-undefined
ArpanB_Intel
Orion, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
