Here is the log file.
10/12/2023 15:57:17:875 : 8400 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/Marko/AppData/Local/Temp/intel_oneapi_installer/2023.10.12.15.56.59.013 --product-id intel.oneapi.win.basekit.product --product-ver 2023.2.0-49385 --package-path C:\Users\Marko\AppData\Local\Temp\w_BaseKit_p_2023.2.0.49396_2023-10-12_15-56-57\packages
10/12/2023 15:57:17:875 : 8400 : MESSAGE : Installer is started in GUI mode
10/12/2023 15:57:17:875 : 8400 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.3.2.892
10/12/2023 15:57:17:875 : 8400 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.3.2-892
10/12/2023 15:57:17:875 : 8400 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2023.2.0-49385. Mode is set to install.
10/12/2023 15:57:18:514 : 18312 : MESSAGE : PreRequisite for other install successfully checked
10/12/2023 15:57:18:531 : 18312 : MESSAGE : PreRequisite for other Intel install successfully checked
10/12/2023 15:57:18:535 : 18312 : MESSAGE : All checks for preRequisite for supported operation system are passed
10/12/2023 15:57:20:587 : 18312 : MESSAGE : PreRequisite for admin rights successfully checked
10/12/2023 15:57:20:587 : 18312 : MESSAGE : PreRequisite for temporary folder successfully checked
10/12/2023 15:57:20:588 : 18312 : MESSAGE : PreRequisite for host architecture successfully checked
10/12/2023 15:58:39:122 : 8768 : MESSAGE : Check for id = [vsCUnsupported2022] failed
10/12/2023 15:58:39:122 : 8768 : MESSAGE : Title [Microsoft Visual Studio* 2022 does not have "Desktop development with C++" components installed.]
10/12/2023 15:58:39:122 : 8768 : MESSAGE : Description [Installation can continue; however, Intel® oneAPI DPC++/C++ Compiler & Intel® C++ Compiler Classic, Intel® oneAPI DPC++/C++ Compiler will not build using Microsoft Visual Studio* 2022. Please see <a href="https://www.intel.com/content/www/us/en/developer/articles/guide/installing-microsoft-visual-studio-2019-for-use-with-intel-compilers.html">https://www.intel.com/content/www/us/en/developer/articles/guide/installing-microsoft-visual-studio-2019-for-use-with-intel-compilers.html</a> for information on configuring Microsoft Visual Studio* 2022 for Visual C++ development.]
10/12/2023 15:58:39:704 : 8768 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
10/12/2023 15:58:39:704 : 8768 : MESSAGE : Title [Intel® Graphics Driver for Windows not found.]
10/12/2023 15:58:39:704 : 8768 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/prerequisites/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
10/12/2023 15:58:39:704 : 8768 : MESSAGE : PreRequisite for Instance Msi successfully checked
10/12/2023 15:59:00:959 : 8768 : MESSAGE : Changed installation directory from 'C:\Program Files (x86)\Intel\oneAPI' to 'E:\oneAPI'.
10/12/2023 15:59:14:006 : 8768 : MESSAGE : Check for id = [vsCUnsupported2022] failed
10/12/2023 15:59:14:006 : 8768 : MESSAGE : Title [Microsoft Visual Studio* 2022 does not have "Desktop development with C++" components installed.]
10/12/2023 15:59:14:007 : 8768 : MESSAGE : Description [Installation can continue; however, Intel® oneAPI DPC++/C++ Compiler & Intel® C++ Compiler Classic, Intel® oneAPI DPC++/C++ Compiler will not build using Microsoft Visual Studio* 2022. Please see <a href="https://www.intel.com/content/www/us/en/developer/articles/guide/installing-microsoft-visual-studio-2019-for-use-with-intel-compilers.html">https://www.intel.com/content/www/us/en/developer/articles/guide/installing-microsoft-visual-studio-2019-for-use-with-intel-compilers.html</a> for information on configuring Microsoft Visual Studio* 2022 for Visual C++ development.]
10/12/2023 15:59:14:009 : 8768 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
10/12/2023 15:59:14:009 : 8768 : MESSAGE : Title [Intel® Graphics Driver for Windows not found.]
10/12/2023 15:59:14:009 : 8768 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/prerequisites/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
10/12/2023 15:59:14:009 : 8768 : MESSAGE : PreRequisite for Instance Msi successfully checked
10/12/2023 16:25:59:791 : 8768 : MESSAGE : Check for id = [oneApiGpuDriverIsNotFound] failed
10/12/2023 16:25:59:791 : 8768 : MESSAGE : Title [Intel® Graphics Driver for Windows not found.]
10/12/2023 16:25:59:791 : 8768 : MESSAGE : Description [You have no relevant GPU driver. If you are going to develop and run GPU-accelerated applications on this system, please check the <a href="https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-windows/top/prerequisites/install-intel-gpu-drivers.html">installation guide</a> for instructions on the GPU drivers.<br/>Otherwise, you can ignore the warning and continue the installation as is: the product can still be used with CPU.]
10/12/2023 16:25:59:791 : 8768 : MESSAGE : PreRequisite for Instance Msi successfully checked
10/12/2023 16:27:11:217 : 8768 : MESSAGE : PreRequisite for free disk space passed
10/12/2023 16:27:11:218 : 8768 : MESSAGE : PreRequisite for permissions passed
10/12/2023 16:27:11:218 : 8768 : MESSAGE : PreRequisite for other install successfully checked
10/12/2023 16:27:11:219 : 8768 : MESSAGE : PreRequisite for other Intel install successfully checked
10/12/2023 16:27:11:261 : 8768 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2022] passed
10/12/2023 16:27:11:261 : 8768 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
10/12/2023 16:27:11:303 : 8768 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2019] passed
10/12/2023 16:27:11:336 : 8768 : MESSAGE : Check for blocking processes passed
10/12/2023 16:27:11:367 : 8768 : MESSAGE : Check for blocking processes passed
10/12/2023 16:27:11:469 : 8400 : MESSAGE : ISIP consent status is 'Yes'
10/12/2023 16:27:11:469 : 8400 : MESSAGE : Product installation directory is E:\oneAPI
10/12/2023 16:27:11:469 : 8400 : MESSAGE : Product download size required: 3730825998 bytes
10/12/2023 16:27:11:469 : 8400 : MESSAGE : Product installation size required: 18474966445 bytes
10/12/2023 16:27:11:469 : 8400 : MESSAGE : Product will be (un)integrated with the following IDEs:
10/12/2023 16:27:11:469 : 8400 : MESSAGE : Microsoft Visual Studio* 2022
10/12/2023 16:27:11:470 : 8400 : MESSAGE : Microsoft C++ Build Tools* 2019
10/12/2023 16:27:11:470 : 8400 : MESSAGE : End of IDE list.
10/12/2023 16:27:11:491 : 8768 : MESSAGE : Graph State Dump.
intel.oneapi.win.basekit.product,v=2023.2.0-49385, Enabled, Selected, Not Installed
intel.oneapi.win.basekit.getting_started,v=2023.2.0-49385, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.common,v=2023.2.0-49331, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2019,v=2023.2.0-49331, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2022,v=2023.2.0-49331, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities,v=2021.10.0-49424, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2019,v=2021.10.0-49424, Disabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities.common,v=2021.10.0-49424, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2022,v=2021.10.0-49424, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger,v=2023.2.0-49331, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2023.2.0-49331, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2023.2.0-49331, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.2.0-49331, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.2.0-49331, Enabled, Selected, Not Installed
intel.oneapi.win.dpl,v=2022.2.0-49285, Enabled, Selected, Not Installed
intel.oneapi.win.condaindex,v=2023.2.0-49398, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.devel,v=2021.10.0-49542, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.runtime,v=2021.10.0-49542, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-dpcpp-common,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2021_VS160.vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS160.vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS160.vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2022,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2022,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS170.vs2022,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS170.vs2022,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2019,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2022,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique192_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique193_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique2023_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique2023_vsix_llvm_vs2022,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2022,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2022,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_193_vs2019,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2019,v=2023.2.0-49074, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2022,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2022,v=2023.2.0-49074, Disabled, Not Selected, Not Installed
intel.oneapi.win.dal.devel,v=2023.2.0-49573, Enabled, Selected, Not Installed
intel.oneapi.win.dal.runtime,v=2023.2.0-49573, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.devel,v=2021.9.0-49453, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.runtime,v=2021.9.0-49453, Enabled, Selected, Not Installed
intel.oneapi.win.ippcp,v=2021.8.0-49491, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2023.2.0-49496, Enabled, Selected, Not Installed
intel.oneapi.win.advisor,v=2023.2.0-49487, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vsix,v=2023.2.0-49487, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vs2019,v=2023.2.0-49487, Disabled, Not Selected, Not Installed
intel.oneapi.win.advisor.vs2022,v=2023.2.0-49487, Enabled, Selected, Not Installed
intel.oneapi.win.vtune,v=2023.2.0-49484, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vsix,v=2023.2.0-49484, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vs2019,v=2023.2.0-49484, Disabled, Not Selected, Not Installed
intel.oneapi.win.vtune.vs2022,v=2023.2.0-49484, Enabled, Selected, Not Installed
intel.oneapi.win.dnnl,v=2023.2.0-49513, Enabled, Selected, Not Installed
10/12/2023 16:27:11:500 : 8768 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Protecting installation location...
Finalizing removal. It may take up to 5 minutes...
Install intel.oneapi.win.basekit.getting_started,v=2023.2.0-49385
Install intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463
Install intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463
Install intel.oneapi.win.dpcpp_ct.vs2022,v=2023.2.0-49331
Install intel.oneapi.win.dpcpp_ct.common,v=2023.2.0-49331
Install intel.oneapi.win.dev-utilities.common,v=2021.10.0-49424
Install intel.oneapi.win.dev-utilities.vs2022,v=2021.10.0-49424
Install intel.oneapi.win.dev-utilities,v=2021.10.0-49424
Install intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.2.0-49331
Install intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.2.0-49331
Install intel.oneapi.win.dpcpp_debugger,v=2023.2.0-49331
Install intel.oneapi.win.condaindex,v=2023.2.0-49398
Install intel.oneapi.win.dpl,v=2022.2.0-49285
Install intel.oneapi.win.tbb.runtime,v=2021.10.0-49542
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074
Install intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074
Install intel.oneapi.win.tbb.devel,v=2021.10.0-49542
Install intel.oneapi.win.openmp,v=2023.2.0-49496
Install intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496
Install intel.oneapi.win.compilers-common,v=2023.2.0-49496
Install intel.oneapi.win.cpp-base-pro-common-runtime,v=2023.2.0-49496
Install intel.oneapi.win.cpp-dpcpp-common,v=2023.2.0-49496
Install intel.oneapi.win.dpcpp-compiler.ide.vs2022,v=2023.2.0-49074
Install intel.oneapi.win.dpcpp-compiler.ide_shared.vs2022,v=2023.2.0-49074
Install intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS170.vs2022,v=2023.2.0-49074
Install intel.oneapi.win.dpcpp-compiler.ide.bt_vs2019,v=2023.2.0-49074
Install intel.oneapi.win.compilers-common.ide.common,v=2023.2.0-49074
Install intel.oneapi.win.cpp-compiler.ide.unique2023_vsix_llvm_vs2022,v=2023.2.0-49074
Install intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2022,v=2023.2.0-49074
Install intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2019,v=2023.2.0-49074
Install intel.oneapi.win.dpcpp-compiler,v=2023.2.0-49496
Install intel.oneapi.win.dal.runtime,v=2023.2.0-49573
Install intel.oneapi.win.dal.devel,v=2023.2.0-49573
Install intel.oneapi.win.ipp.runtime,v=2021.9.0-49453
Install intel.oneapi.win.ipp.devel,v=2021.9.0-49453
Install intel.oneapi.win.ippcp,v=2021.8.0-49491
Install intel.oneapi.win.mkl.runtime,v=2023.2.0-49496
Install intel.oneapi.win.mkl.devel,v=2023.2.0-49496
Install intel.oneapi.win.advisor.vsix,v=2023.2.0-49487
Install intel.oneapi.win.advisor.vs2022,v=2023.2.0-49487
Install intel.oneapi.win.advisor,v=2023.2.0-49487
Install intel.oneapi.win.vtune.vsix,v=2023.2.0-49484
Install intel.oneapi.win.vtune.vs2022,v=2023.2.0-49484
Install intel.oneapi.win.vtune,v=2023.2.0-49484
Install intel.oneapi.win.dnnl,v=2023.2.0-49513
Install intel.oneapi.win.basekit.product,v=2023.2.0-49385
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
10/12/2023 16:27:12:096 : 8768 : MESSAGE : Start install/modify sequence execution.
10/12/2023 16:27:12:123 : 8768 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1697120831491523'.
10/12/2023 16:27:12:123 : 8768 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1697120831491523' execution is finished with status Success.
10/12/2023 16:27:12:123 : 8768 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1697120831491523'.
10/12/2023 16:27:12:123 : 8768 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1697120831491523' execution is finished with status Success.
10/12/2023 16:27:12:123 : 8768 : MESSAGE : Starting execution of operation 'protect.operation.intel.sessionmanifest.1697120831491523'.
10/12/2023 16:27:12:398 : 8768 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1697120831491523' execution is finished with status Success.
10/12/2023 16:27:12:398 : 8768 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1697120831491525'.
10/12/2023 16:27:12:398 : 8768 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1697120831491525' execution is finished with status Success.
10/12/2023 16:34:55:122 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.basekit.getting_started,v=2023.2.0-49385'.
10/12/2023 16:34:55:426 : 8768 : MESSAGE : Operation 'intel.oneapi.win.basekit.getting_started,v=2023.2.0-49385' execution is finished with status Success.
10/12/2023 16:35:01:773 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463'.
10/12/2023 16:35:16:437 : 8768 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463' execution is finished with status Success.
10/12/2023 16:35:16:437 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463'.
10/12/2023 16:35:17:032 : 8768 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463' execution is finished with status Success.
10/12/2023 16:35:17:032 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2022,v=2023.2.0-49331'.
10/12/2023 16:35:18:022 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.vs2022,v=2023.2.0-49331' execution is finished with status Success.
10/12/2023 16:35:58:101 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.common,v=2023.2.0-49331'.
10/12/2023 16:36:00:706 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.common,v=2023.2.0-49331' execution is finished with status Success.
10/12/2023 16:36:00:706 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities.common,v=2021.10.0-49424'.
10/12/2023 16:36:01:614 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.common,v=2021.10.0-49424' execution is finished with status Success.
10/12/2023 16:36:01:614 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.10.0-49424'.
10/12/2023 16:36:02:060 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.10.0-49424' execution is finished with status Success.
10/12/2023 16:36:02:060 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities,v=2021.10.0-49424'.
10/12/2023 16:36:02:267 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities,v=2021.10.0-49424' execution is finished with status Success.
10/12/2023 16:36:02:267 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.2.0-49331'.
10/12/2023 16:36:03:404 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.2.0-49331' execution is finished with status Success.
10/12/2023 16:36:03:404 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.2.0-49331'.
10/12/2023 16:36:05:241 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.2.0-49331' execution is finished with status Success.
10/12/2023 16:36:28:494 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger,v=2023.2.0-49331'.
10/12/2023 16:36:34:982 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger,v=2023.2.0-49331' execution is finished with status Success.
10/12/2023 16:36:34:982 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398'.
10/12/2023 16:36:35:586 : 8768 : MESSAGE : Operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398' execution is finished with status Success.
10/12/2023 16:36:35:586 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpl,v=2022.2.0-49285'.
10/12/2023 16:36:38:322 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpl,v=2022.2.0-49285' execution is finished with status Success.
10/12/2023 16:36:38:322 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542'.
10/12/2023 16:36:41:203 : 8768 : MESSAGE : Operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542' execution is finished with status Success.
10/12/2023 16:36:41:203 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074'.
10/12/2023 16:36:42:040 : 8768 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074' execution is finished with status Success.
10/12/2023 16:36:42:040 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074'.
10/12/2023 16:36:42:831 : 8768 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074' execution is finished with status Success.
10/12/2023 16:36:42:831 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074'.
10/12/2023 16:36:43:404 : 8768 : MESSAGE : Operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074' execution is finished with status Success.
10/12/2023 16:36:43:404 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542'.
10/12/2023 16:36:54:726 : 8768 : MESSAGE : Operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542' execution is finished with status Success.
10/12/2023 16:36:54:726 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.openmp,v=2023.2.0-49496'.
10/12/2023 16:37:31:205 : 8768 : MESSAGE : Operation 'intel.oneapi.win.openmp,v=2023.2.0-49496' execution is finished with status Success.
10/12/2023 16:37:31:205 : 8768 : MESSAGE : Starting execution of operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496'.
10/12/2023 16:37:51:083 : 8768 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.compilers-common-runtime, name: Intel® oneAPI Compiler 2023.2.0, version: 2023.2.0-49496.
Error: Sequence execution failed.
10/12/2023 16:37:51:083 : 8768 : MESSAGE : Operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.0-49496' execution is finished with status Fail.
10/12/2023 16:37:51:084 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.openmp,v=2023.2.0-49496'.
10/12/2023 16:37:53:520 : 8768 : MESSAGE : Operation 'intel.oneapi.win.openmp,v=2023.2.0-49496' rollback is finished with status Success.
10/12/2023 16:37:53:520 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542'.
10/12/2023 16:37:57:820 : 8768 : MESSAGE : Operation 'intel.oneapi.win.tbb.devel,v=2021.10.0-49542' rollback is finished with status Success.
10/12/2023 16:37:57:820 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074'.
10/12/2023 16:37:58:409 : 8768 : MESSAGE : Operation 'intel.oneapi.win.compilers-common.ide.regupdater,v=2023.2.0-49074' rollback is finished with status Success.
10/12/2023 16:37:58:409 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074'.
10/12/2023 16:37:59:614 : 8768 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2023.2.0-49074' rollback is finished with status Success.
10/12/2023 16:37:59:614 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074'.
10/12/2023 16:38:00:392 : 8768 : MESSAGE : Operation 'intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2023.2.0-49074' rollback is finished with status Success.
10/12/2023 16:38:00:392 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542'.
10/12/2023 16:38:01:927 : 8768 : MESSAGE : Operation 'intel.oneapi.win.tbb.runtime,v=2021.10.0-49542' rollback is finished with status Success.
10/12/2023 16:38:01:927 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dpl,v=2022.2.0-49285'.
10/12/2023 16:38:03:875 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpl,v=2022.2.0-49285' rollback is finished with status Success.
10/12/2023 16:38:03:875 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398'.
10/12/2023 16:38:04:908 : 8768 : MESSAGE : Operation 'intel.oneapi.win.condaindex,v=2023.2.0-49398' rollback is finished with status Success.
10/12/2023 16:38:04:908 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dpcpp_debugger,v=2023.2.0-49331'.
10/12/2023 16:38:06:089 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger,v=2023.2.0-49331' rollback is finished with status Success.
10/12/2023 16:38:06:089 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.2.0-49331'.
10/12/2023 16:38:07:051 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2023.2.0-49331' rollback is finished with status Success.
10/12/2023 16:38:07:051 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.2.0-49331'.
10/12/2023 16:38:08:005 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2023.2.0-49331' rollback is finished with status Success.
10/12/2023 16:38:08:005 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dev-utilities,v=2021.10.0-49424'.
10/12/2023 16:38:08:289 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities,v=2021.10.0-49424' rollback is finished with status Success.
10/12/2023 16:38:08:289 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.10.0-49424'.
10/12/2023 16:38:08:581 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.10.0-49424' rollback is finished with status Success.
10/12/2023 16:38:08:581 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dev-utilities.common,v=2021.10.0-49424'.
10/12/2023 16:38:09:545 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.common,v=2021.10.0-49424' rollback is finished with status Success.
10/12/2023 16:38:09:546 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dpcpp_ct.common,v=2023.2.0-49331'.
10/12/2023 16:38:12:233 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.common,v=2023.2.0-49331' rollback is finished with status Success.
10/12/2023 16:38:12:233 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dpcpp_ct.vs2022,v=2023.2.0-49331'.
10/12/2023 16:38:13:188 : 8768 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_ct.vs2022,v=2023.2.0-49331' rollback is finished with status Success.
10/12/2023 16:38:13:188 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463'.
10/12/2023 16:38:13:967 : 8768 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2023.2.0-49463' rollback is finished with status Success.
10/12/2023 16:38:13:967 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463'.
10/12/2023 16:38:34:009 : 8768 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2023.2.0-49463' rollback is finished with status Success.
10/12/2023 16:38:34:009 : 8768 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.basekit.getting_started,v=2023.2.0-49385'.
10/12/2023 16:38:34:317 : 8768 : MESSAGE : Operation 'intel.oneapi.win.basekit.getting_started,v=2023.2.0-49385' rollback is finished with status Success.
10/12/2023 16:38:34:317 : 8768 : MESSAGE : Starting rollback of operation 'complete.operation.intel.sessionmanifest.1697120831491525'.
10/12/2023 16:38:34:552 : 8768 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1697120831491525' rollback is finished with status Success.
10/12/2023 16:38:34:552 : 8768 : MESSAGE : Starting rollback of operation 'protect.operation.intel.sessionmanifest.1697120831491523'.
10/12/2023 16:38:34:553 : 8768 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1697120831491523' rollback is finished with status Success.
10/12/2023 16:38:34:553 : 8768 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1697120831491523'.
10/12/2023 16:38:34:553 : 8768 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1697120831491523' rollback is finished with status Success.
10/12/2023 16:38:34:553 : 8768 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1697120831491523'.
10/12/2023 16:38:34:553 : 8768 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1697120831491523' rollback is finished with status Success.
10/12/2023 16:38:34:553 : 8768 : ERROR : Install sequence execution status: Rollback
10/12/2023 16:38:34:623 : 8400 : MESSAGE : ----------------------------------------------------------------------------------------------------
10/12/2023 16:38:34:623 : 8400 : MESSAGE : Anonymous statistics fields:
10/12/2023 16:38:34:623 : 8400 : MESSAGE : EventId = 'install-min'
10/12/2023 16:38:34:623 : 8400 : MESSAGE : EventKey = 'S3UqiDQDs0egwqo7y1z17w=='
10/12/2023 16:38:34:623 : 8400 : MESSAGE : EventTime = ''
10/12/2023 16:38:34:623 : 8400 : MESSAGE : Id = 'intel.oneapi.win.basekit.product,v=2023.2.0-49385'
10/12/2023 16:38:34:623 : 8400 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Base Toolkit 2023.2\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4355\", \"product_tag\":\"\" }'
10/12/2023 16:38:34:623 : 8400 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Base Toolkit 2023.2'
Hi Marko, could you please share the below details for further investigation:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Exact version of Intel® oneAPI Toolkit
We would like to know.
- OS build on which you are installing the software? Windows 10.
- Is the installer an online or an offline package? Online, but I tried the offline one aqfterwards and managed to install it.
- Version of Microsoft Visual Studio installed along with it's build version?
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system? None.
Here is what they are based off what got installed through the offline installer. It is the July 2023 release.
In addition to the installation issue, the version I installed through the offline installer has broken integration with Visual Studio. I can compile the program through the make files, but not through the IDE by using build. Neither am I getting Intellisense support in the opened project. When I compile it through the IDE, I get thousands of different errors in the errors tab.
Hi Marko, please note that Visual Studio Community 17.5.0 has not been tested and validated on Intel® oneAPI Base Toolkit by our engineering team. It may or may not work with Visual Studio 17.5.0.
We recommend you, refer to the link: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html and check the compatible Visual Studio Version for your Intel® Product.
Hi Marko, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
