oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1695 Discussions
Installation of Intel DPC++/C++ Compiler for Windows fails on Windows 11 Pro
Polarbear61
Installation fails. Checking the log file
C:\Users\Mike\AppData\Local\Temp\intel_oneapi_installer\2023.08.03.09.16.39.460installer.2023.08.03.09.16.54.060340.log
I see the following error:
08/03/2023 09:19:19:427 : 18080 : MESSAGE : Install process finished with status 0 and exit code 1.
08/03/2023 09:19:19:427 : 18080 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.compilers-common-runtime, name: Intel® oneAPI Compiler 2023.2.1, version: 2023.2.1-17.
Error: Sequence execution failed.
08/03/2023 09:19:19:427 : 18080 : MESSAGE : Operation 'intel.oneapi.win.compilers-common-runtime,v=2023.2.1-17' execution is finished with status Fail.
08/03/2023 09:19:19:427 : 18080 : ERROR : <StandardSequenceExecutor>: 'intel.oneapi.win.compilers-common-runtime,v=2023.2.1-17' execution is failed. Rolling back all previous operations.
Any suggestions?
0 Solutions
Polarbear61
Running the installer as administrator did the trick!
ArpanB_Intel
Hi Michele, please share the below information with us:
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files apart from the one you shared
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
Polarbear61
Hi ArpanB_Intel, here are my answers:
Offline package: w_dpcpp-cpp-compiler_p_2023.2.1.7_offline.exe
Microsoft Visual Studio Community 2022 (64-bit) - Current Version 17.6.5
None
Sorry, I didn't think of taking a screenshot.
It was simply the installer stating installation had failed and suggested to check the logs.
I'm attaching the log file contained in C:\Program Files (x86)\Intel\oneAPI\logs.
As I said, I don't have Parallel Studio XE installed.
I hope this helps!
ArpanB_Intel
Michele, thank you for sharing the resolution with us. We are glad that the issue is resolved.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
