oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
Installing on Ubuntu 20.04
RJMNOLA
I am attempting to install the OneAPI base toolkit on Ubuntu 20.04.  There appears to be some errors in the repos that Ubuntu is trying to use.  From the command "sudo add-apt-repository "deb https://apt.repos.intel.com/oneapi all main", there is the following set of errors:
E: The method driver /usr/lib/apt/methods/htps could not be found.
N: Is the package apt-transport-htps installed?
E: Failed to fetch htps://apt.repos/intel.com/oneapi/dists/all/InRelease
E: Some index files failed o download.  They have been ignored, or old ones used instead.
I have attached a screen shot of the command used and errors encountered for reference.
There is no package "apt-transport-htps", but there is "apt-transport-https" that *is* installed.  The website "htps://apt.repos/intel.com/oneapi/dists/all/InRelease" does not exist.  However, "https://apt.repos.intel.com/oneapi/dists/all/InRelease does exist.  Is there a fix for this, or a workaround?
ArpanB_Intel
Hi Robert, please use the following command on your terminal-
apt-get install apt-transport-https ca-certificates
If your apt-get is too broken to do this, you can download the package directly and install it with dpkg -i
Please share your findings with us.
RaeesaM_Intel
Hi ,
We are forwarding this query to  Registration, Download, Licensing and Installation forum for much faster and correct solution.
Raeesa
GouthamK_Intel
Could you please try running “apt-get install -f “ on the terminal to fix broken packages if any. And let us know if your issue still persists.
Goutham
ArpanB_Intel
RJMNOLA
