When trying to install on a new Windows 11 HOME new machine, my Parallel Studio 2018, the installer stops without any message after unpacking the files (offline installation). It does not reach the point of asking for a license file.
Is it possible to install it on Windows 11 HOME 64 bits? Is Windows PRO mandatory?
My new notebook has an i7 12650H, 16 Gbytes DDR4, and 500 GBytes SSD. Brand new.
Armando
Hi Armando, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files.
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
Hi ArpanB.
Do you have any solution for me?
Hi Arpan,
Windows 11 HOME. Version 22H2, OS build: 22621.1702 . Experience: Windows Features Experience Pack 1000.22641.1000.0
Visual Studio Community 2017, version 15.9.54
Parallel Installer offline
It is a new notebook; I am trying to install my Parallel Studio 2018 update 4.
There is no error message!! The installer, after unpacking, closes the window and stops working without notice. So, no screenshot is available.
Installation log attached.
Thanks!
Armando
I already send the requested information.
Armando
Armando, thank you for confirming the information with us. Please note that Intel® Parallel Studio XE 2018 is not supported on Windows 11.
Please click here: https://www.intel.com/content/dam/develop/external/us/en/documents/ipsxe-2018-release-notes-en.pdf, and check the Operating System Requirements section for more information.
Dear ArpanB.
I had the SAME Parallel Studio XE 2018 (C++) installed on my previous PC with Windows 11 PRO.
So, IT IS POSSIBLE to use Windows 11 PRO; that is an experimental FACT.
I invite you to check the screenshot attached. I used several updates of version 2018 on the old PC with Windows 11 PRO, and never had a problem with that.
Armando
Armando, prior to the release of an Intel® product, it is tested on various platforms that make up the list of Supported OS versions for the product. For any OS platforms apart from the ones listed, it may or may not work. However, if it doesn't work, Intel® will not be able to support you.
We suggest you to install the software on a supported OS version.
Armando, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
