Running Windows 11 Pro 21H2 (OS build 22000.376). I installed Visual Studio Professional 2022 (64-bit) Version 17.0.4. I then installed w_BaseKit_p_2022.1.0.116_offline.exe followed by w_HPCKit_p_2022_1.0.93_offline.exe. When I launch a VS 2022 project, I see that Intel VTune is integrated into the IDE. However, Intel Advisor and Intel Inspector do not show up in the IDE. All 3 tools show up in the VS 2019 menu. I had installed the entire set of packages for the base kit and the HPC kit. I uninstalled and reinstalled the Intel packages, this time only Intel VTune, Intel Advisor and Intel Inspector. Same problem--only Intel VTune shows up in the VS 2022 menu.
Any suggestions on how I can get these to show up?
Thank you, Dave Eberly
Hi David, compiler version 2022.1 was fully tested and supported on Microsoft Visual Studio 2019 16.11.6. Microsoft Visual Studio 2022 17.0.0 only went through limited manual testing with regards to the compiler 2022.1.
If the installation was successful, visit here> https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-advisor/top/before-yo..., to check if you are able to launch Intel® Advisor.
Similarly, visit here> https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-inspector/top/windows..., to get started with Intel® Inspector.
Thank you for the response. The installers for oneAPI have an option to integrate into MSVS 2017, MSVS 2019 and/or MSVS 2022 which led me to believe the 3 tools I mentioned would be integrated. I can see in the installer directories for Inspector and Advisor only MSI files for vs2017 and vs2019, which is evidence there is no integration (yet) for these tools. I can run the tools stand-alone on my MSVS 2022 applications, and I can run the tools integrated in MSVS 2019.
David, thank you for accepting our solution. We are glad that the issue has been resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
