oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Intel Driver and support Assistant Error
Bogie
I had an issue that caused me to uninstall IDSA a bit ago.
I have tried to reinstall but keep getting and unknown error 0x80070005.
I tried the uninstall utility several times same result. Log file attached.
Speccy system info file attach in txt format as well.
Any help would be appreciated. Thank you.
AlHill
Any information from speccy should be taken with a grain of salt.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Bogie
i was hoping for more replies on this issue.
isuke56
I'm getting an error also. I tried reinstalling but didn't fix it.
