oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1429 Discussions
Intel OneAPI Bask Toolkit V. 2022 uninstall
pik1432
Hello there,
Is there any chance to ask how to uninstall the software from my computer?
I tried multiple times, with different methods (e.g., installing update/repair), but none of them worked. The attached screen capture image shows the details.
Meanwhile, this is my 3rd posting (if my recollection is correct) here with the same subject. This time, I might be lucky enough to catch a certain attention.
ArpanB_Intel
pik1432
Thank you for the information.
1. No exe file with the name start with 'w_' was found.
In other words, the following instruction given in the link above could not be attempted.
w_[Toolkit Name]Kit_[version].exe
2. In the case of my installation,
C:\Program Files\Intel\oneAPI\Installer
was found to be  'C:\Program Files (x86)\Intel\oneAPI'.
Regarding the point #1 above, any suggestion would be appreciated.
ArpanB_Intel
Hi, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Installation Log files
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
pik1432
- OS build on which you are installing the software: Windows 11 Pro (10.0.22621)
- Probably it was online one.
- Microsoft Visual Studio Professional 2022 (64-bit) - Current Version 17.3.3
- Microsoft Visual Studio Community 2019 Version 16.11.8
- No such installation
- Attached below.
ArpanB_Intel
Hi, thank you for sharing the information.
We will check the files and share our findings on this issue soon.
ArpanB_Intel
Hi, we suggest you to follow the below steps:
  • Close Intel® installers if any
  • Uninstall all Microsoft Visual Studio instances and Visual Studio Installer
  • Important: Check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
Also, please check the release notes prior to the installation of new toolkit by clicking here: https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-oneapi-toolkit-release-notes-2022.html
We await your findings.
ArpanB_Intel
In Kwon, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
