oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
Intel Parallel Studio XE silent uninstall
bmp_
@Ying_H_Intel wrote an excellent documentation on silent uninstallation for Parallel Studio on macOS, but there is no corresponding documentation seemingly on silent uninstallation for Windows
Silent installation is documented and straightforward. The same CLI parameters as install, but instead replacing "install" with "uninstall," does not work, and still renders a GUI prompt to modify/repair/remove.
Thanks for any help figuring this out!
ArpanB_Intel
Hi Brandon, to silently remove the product run Command Prompt with administrative privileges and type the command:
For self-extracted archive: parallel_studio_xe_<20xx>_<update number>_<edition name>_edition_<online/offline>_setup.exe -s -a remove --output=output.txt(if you are using the customizable package)
For already unpacked package: install.exe remove --output=output.txt
ArpanB_Intel
Brandon, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
