I am getting a similar error mentioned in the following post
Every time intel distribution for python component is failed.
I am trying to install it on CentOS 8
Hi Muhammad, could you share the below information with us:
- The version of Intel® oneAPI Base Toolkit you are using
- The installation log file
Version: Intel® one API Base Toolkit 2022.1.1
Logs are attached
Hi Muhammad, we had contacted you privately. Please check your inbox for further updates with regards to your query.
Muhammad, that was unfortunate. We have contacted you again privately to share an update with regards to your query.
Still not received any message in inbox, please email
Receive messages
Muhammad, we thank you for the acknowledgement.
Muhammad, we found this was related to compatibility of the OS build. CentOS* 8 is not supported by Intel® oneAPI Base Toolkit or Intel® Distribution for Python*. We suggest you to use a compatible OS build with the software. To check the system requirements, visit:
- https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html
- https://www.intel.com/content/dam/develop/external/us/en/documents/2022_Python_Release_Notes_Intel(R)_Distribution_for_Python-Release1.pdf
I think the release notes need to be updated so it reflects that it supports CentOS 8. I don't see why the BaseKit would work on an older version of CentOS and not newer; it's usually the other way around (the notes do say that CentOS 7 is supported for CPU).
I'm communicating with Muhammad via email to debug this issue and help him get it working on his machine as soon as possible. Thanks!
Muhammad, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
