oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Intel Python installation failed
Rizwan1
I am getting a similar error mentioned in the following post
https://community.intel.com/t5/Intel-oneAPI-Registration/Intel-Distribution-for-Python-installation-failure-quot-Sequence/mp/1297953#M1110
Every time intel distribution for python component is failed.
I am trying to install it on CentOS 8
ArpanB_Intel
Hi Muhammad, could you share the below information with us:
  • The version of Intel® oneAPI Base Toolkit you are using
  • The installation log file
Rizwan1
Version: Intel® one API Base Toolkit 2022.1.1
Logs are attached
Andres_G_Intel1
<Message has been deleted>
ArpanB_Intel
Hi Muhammad, we had contacted you privately. Please check your inbox for further updates with regards to your query.
Rizwan1
I did not received any message in inbox
ArpanB_Intel
Muhammad, that was unfortunate. We have contacted you again privately to share an update with regards to your query.
Rizwan1
Still not received any message in inbox, please email
Rizwan1
Receive messages
ArpanB_Intel
Muhammad, we thank you for the acknowledgement.
ArpanB_Intel
Muhammad, we found this was related to compatibility of the OS build. CentOS* 8 is not supported by Intel® oneAPI Base Toolkit or Intel® Distribution for Python*. We suggest you to use a compatible OS build with the software. To check the system requirements, visit:
Andres_G_Intel1
I think the release notes need to be updated so it reflects that it supports CentOS 8. I don't see why the BaseKit would work on an older version of CentOS and not newer; it's usually the other way around (the notes do say that CentOS 7 is supported for CPU).
I'm communicating with Muhammad via email to debug this issue and help him get it working on his machine as soon as possible. Thanks!
ArpanB_Intel
Muhammad, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
