oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1431 Discussions
Intel classic Fortran compile license not found
Tom18
We have the Intel compilers (vintage 2019) installed on the university compute cluster.  In the last week the users have begun to complain that the compilers are not working due to a license issue.
The exact error is:
[root@vegahn ~]# icc
Error: A license for Comp-CL is not available now (-15,570,115).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
** 1. /cm/shared/licenses/intel/COM_L___xxxx-yyyyyy3J.lic
** 2. /cm/shared/licenses/intel/COM____xxxx-yyyyyy6K.lic
** 3. /cm/shared/licenses/intel/COM____xxxx-yyyyyySB.lic
** 4. /cm/shared/apps/intel/2019.5.075/compilers_and_libraries_2019.5.281/linux/bin/intel64/../../Licenses
** 5. /root/Licenses
** 6. /root/intel/licenses
** 7. /opt/intel/licenses/COM_L__CPPFOR_GB4N-SG76XRW5.lic
** 8. /opt/intel/licenses/USE_SERVER.lic
** 9. /Users/Shared/Library/Application Support/Intel/Licenses
** 10. /cm/shared/apps/intel/2019.5.075/compilers_and_libraries_2019.5.281/linux/bin/intel64/*.lic
Please refer http://software.intel.com/sites/support/ for more information..
icc: error #10052: could not checkout FLEXlm license
The problem is that all three of the license files (...3J, ...6K and ...SB) do exist and are valid (permanent and uncounted).  The compilers were working up to about a week ago then the users started seeing this message.  The environment variable INTEL_LICENSE_FILE points to "/cm/shared/licenses/intel".  Is there anything else that could cause the compilers not to find the licenses?
Tom18
RahulC_Intel
Hi Tom, we have sent you a private message and ask some confidential information. Kindly share the details with us via private message.
Tom181
RahulC,
I have looked through my email and cannot find a message from Intel.  Can you please resend it?
Tom18
RahulC_Intel
Hi Tom, we have sent you a private message again and ask some confidential information. Kindly check your Intel® Community inbox and share the details with us via private message.
RahulC_Intel
Hi Tom, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
