oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1696 Discussions
Intel oneAPI Base Toolkit installing failed 2021.2
yanxxcug
Hi Team,
I was trying to install OneAPI base toolkit but failed with an error.
  Operating System:Windows 10 Professional 21H2;
  OneAPI base toolkit version:w_BaseKit_p_2021.2.0.2871_offline;
  VS version:Visual Studio 2019
I have attached the screenshot for your reference.  Please check and advise.
Thank you,
yan
ArpanB_Intel
Hi Junjie, please follow the below steps:
  1. Close Intel® installers if any.
  2. Uninstall all Microsoft Visual Studio instances and Visual Studio Installer.
  3. Important: check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
  4. REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
  5. command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
  6. Uninstall older Intel® Parallel Studio XE and Intel® oneAPI products.
  7. Install required versions of Microsoft Visual Studio supported by the Intel® Parallel Studio XE. See the full list here. For the Intel® Parallel Studio XE 2020 Update 4, the supported versions are Visual Studio 2017 15.9 and Visual Studio 2019 16.7.2.
yanxxcug
Hi, ArpanB_Intel,
   Thank you very much for your information. I followed your suggestions but the OneAPI base toolkit installation still failed. Maybe it is related to the version of the Visual Studio? I use the vs_community__2019 16.11.16 installer . I don't knot how to find the Visual Studio 2019 16.7.2 installer.
Thank you very much.
Junjie
ArpanB_Intel
Junjie, do you have any older version of the Intel® software installed with you? If so, could you share the versions of the software installed?
Also, please share if you have any other version of Visual Studio installed or not.
yanxxcug
Hi, ArpanB_Intel,
   Thank you  for your reply. I have checked that there is no other  Intel® software installed, also no other version of Visual Studio installed except for Visual Studio 2019 16.11.16.
the error info is as follows.
ArpanB_Intel
Junjie, we have contacted you internally and shared few downloadable files with you. Please check your inbox for further updates.
ArpanB_Intel
Junjie, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
