oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1643 Discussions
Intel oneAPI base toolkit 2021 fails to install on windows 11.
blvb
Hi
I am trying to install oneAPI base toolkit 2021 on windows 11. I tried running the following installation files.
w_BaseKit_p_2021.4.0.3421_offline.exe and
w_BaseKit_p_2021.2.0.2871.exe
I run the files as administrator. I press  "Continue" on the first dialog box saying "Installer will check your system requirements and launch automatically. Click Continue to begin".
The result is that it downloads something very fast, a logo appears, and then the installer shuts down with out any messages.
I need to use that version because it needs to run with Abaqus 2023 and that is the version that is supported. I have installed Microsoft Visual Studio 2019 community.
Does anyone have a suggestion for what I should do to fix it?
BR Brian
ArpanB_Intel
Hi Brian, please share the below information to us:
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
blvb
Hi ArpanB
Thanks for getting back to me. I have provided the information below. Besides that I have tried installing oneAPI base toolkit 2023 which it can do. This is not the version I need but it can install with out errors.
The version of Visual studio is:
Microsoft Visual Studio Community 2019
Version 16.11.28
VisualStudio.16.Release/16.11.28+33920.266
Microsoft .NET Framework
Version 4.8.09032
Installed Version: Community
Visual C++ 2019 00435-00000-00000-AA277
Microsoft Visual C++ 2019
ASP.NET and Web Tools 2019 16.11.115.10959
C# Tools 3.11.0-4.22108.8+d9bef045c4362fbcab27ef35daec4e95c8ff47e1
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
IntelliCode Extension 1.0
IntelliCode Visual Studio Extension Detailed Info
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft MI-Based Debugger 1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards 1.0
Microsoft Visual Studio VC Package 1.0
NuGet Package Manager 5.11.4
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension 1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
TypeScript Tools 16.0.30526.2002
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 3.11.0-4.22108.8+d9bef045c4362fbcab27ef35daec4e95c8ff47e1
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual Studio Code Debug Adapter Host Package 1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Tools for CMake 1.0
There is no other version of  Intel® Parallel Studio XE or Intel® oneAPI on the system.
There is no error messages to take a copy of.
There is no log file. The folder C:\Program Files (x86)\Intel\oneAPI\ exists but not C:\Program Files (x86)\Intel\oneAPI\logs.
ArpanB_Intel
Brian, please click here: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html, to check the compatibility of the IDE with our toolkits.
We found out that Microsoft had pushed updates for older Visual Studio releases which corrupted the older integration setups with our compilers. Please note that prior to the release of Intel® compilers, it is tested with a certain set of Microsoft Visual Studio IDE for compatibility testing. Now with this update, the compatibility has been lost. Considering these are older versions of our product which are currently out of support, Intel® will not be able to push updates for them. We believe that the issue is caused to a .DLL file located here: C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
If you can replace this new .dll file with an older .dll file, it should fix the issue. For this, we suggest you to contact Microsoft support by clicking here: Get help with Visual Studio.
ArpanB_Intel
Brian, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
