oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1640 Discussions
Intel vtune 2025 Does not work on Rocky 8 Linux
Gregor240
The documentation suggests that Intel vtune 2025 will run on Rocky linux 8 and 9
When we install it on Rocky 8 it requires a GLIBc version that is only available on Rocky 9.
Where can I download a version that will install on Rocky 8 please or/AND Will this be fixed ?
thankyou
Deeksha_S_Intel
Hi Greg, we have sent you a private message. Kindly check your inbox.
Gregor240
Thanks Deeksha
Deeksha_S_Intel
Hi Greg,
Kindly follow below workarounds for Intel® VTune™ Profiler :
  1. Clear LD_PRELOAD before launching VTune and configure LD_PRELOAD as an environment for the target application if it is required.
  2. Add libstdc++.so.6 either from VTune installation or from system location to LD_PRELOAD (see https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2023-0/error-message-cannot-collect-gpu-hardware-metrics.html that has a similar workaround)
  3. Do 'export LD_PROFILE=none' before launching collection (this could cause an insignificant performance hit for the loader, does not work in security hardened environment)
For more information kindly go through below link :
Link : Intel® VTune™ Profiler Release Notes
If you still face any issue after trying the above workarounds then kindly let us know.
Have a great day ahead!
Deeksha_S_Intel
Hello Greg, we've sent you a private message. Please take a moment to check your inbox.
Gregor240
Hi, This solution does not work. Do you have a version that works on rocky 8 please? Can I get the previous version from somewhere?
thanks
Greg
Deeksha_S_Intel
Hi Greg, we would like to inform you that we are routing your query to the engineering team for further assistance.
roy5
Thanks for your patience.
Only Rocky 8.10 and Rocky 9.5 are actively supported. All the other versions are EOLed: https://wiki.rockylinux.org/rocky/version/#__tabbed_1_1
Can you please upgrade to any of these OS versions?
