New to Linux wondering if anyone knows how to fix my issue, I have seen other posts but I was unable to resolve this on my own.
Ubuntu 24.04.01
A750
i5-11400
I started off with trying to install the Client GPUs Level 0 and OpenCL graphics drivers from https://dgpu-docs.intel.com/driver/client/overview.html under the header Installing Client GPUs on Ubuntu Desktop 24.04 LTS.
This resulted in
W: GPG error: https://apt.repos.intel.com/oneapi all InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BAC6F0C353D04109
E: The repository 'https://apt.repos.intel.com/oneapi all InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
Then if I try installing the oneAPI Base ToolKit using apt it says no PUBKEY or that it cant find the package.
I want to use sycl to accelerate LLMs and learn how to train and deploy my own models. I was also interested in just having a environment for me to practice and learn C++ , and Python. Should I just run baremetal linux? Is WSL even able to work for my use case. I just want to have best performance while using windows as my main OS, I thought WSL would maybe be better than a VM. I would prefer to have access to windows to run other apps at the same time.
Hi Luke,
Could you please share the following details with us?
- The exact version of the Intel® Toolkit you're trying to install.
- Any other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
- A screenshot of the error message (if applicable).
Additionally, you can refer to the link below if you're encountering difficulties during the installation process:
To assist you further, we would require these details.
Hi Vipin,
Thank you for the reply, as of right now the client gpu drivers for linux ubuntu 24.04 have installed successfully. I am now starting to install the oneapi basetookit from the link you have provided, It is seemingly working so far now however I will keep you updated.
Hi Luke, we have sent you a private message. Kindly check your inbox.
Hi Luke, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
