oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
MPI Library installation issues
Naoko
When I try to install the MPI Library, I get the following screen and cannot install it.
I tried to install HPC toolkit with vidual studio, but it still does not work.
I also tried to install by command pronto, but it did not work.
Is there a solution?
Is there something wrong with the oneAPI common, version 2022.2.0-9535 that appears on the error screen?
Error screen and log file were attached.
ArpanB_Intel
Hi Naoko, could you share the below information with us>
  • The OS build on which you are installing
  • The versions of Microsoft Visual Studio installed along with their build versions
  • The versions of any other Intel® Parallel Studio XE or Intel® oneAPI already installed on your system
We would like to know.
Naoko
Hi!
Here is the answer to your question. Sorry for late reply.
OS: Windows 10 Enterprise 21H2
The versions of Microsoft Visual Studio: Visual Studio Community 2022 ver 17.2
other Intel® Parallel Studio XE, Intel® oneAPI: Not installed
ArpanB_Intel
Naoko, Intel® oneAPI HPC Toolkit 2022.2 and some of it's tools are not compatible with VS2022 17.2.0. For example, VS2022 17.2.0 is NOT supported for IFORT and IFX. We would suggest you to use the latest oneAPI 2022.3 version of the compiler. Also, we suggest you to install Intel® oneAPI Base Toolkit first followed by Intel® oneAPI HPC Toolkit for optimum performance.
For more information, visit here: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
Naoko
Hi
I installed Visual Studio Community 2022 ver 17.3.6 which is latest version and tried installing onAPI base toolkit first. But it failed and also displayed same error.
Umm, I'm trying to install it on a secured PC, is this likely to be related to this problem?
ArpanB_Intel
Naoko, when you are installing the oneAPI Base Toolkit, could you share the screenshot of the error screen and the installation log file with us? The log file of the should be present in the below path> C:\Program Files (x86)\Intel\oneAPI\logs
Naoko
Hi
OK. Screenshot of error screen and log file is attached.
ArpanB_Intel
Naoko, we have contacted you internally with some information. Please check the inbox for further updates.
ArpanB_Intel
Naoko, we tried out the installation with Microsoft Visual Studio 17.3.6 Community Edition with the latest 2022.3 version of the Intel® oneAPI Base Toolkit & HPC Toolkit. The installation and subsequent integration was successful on our end.
Thus, we would suggest you to use the 2022.3 version of the compiler.
ArpanB_Intel
Naoko, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
