We have three licenses for Intel Parallel Studio XE 2017 Update 1 Composer Edition for Fortran Windows. These are named licenses.
I need to move one of the licenses from an older computer which failed to a newer computer. However, the Intel Software Manager no longer can connect to its server. I read here that these servers are down permanently.
How do I move this named license now?
Hi Jens, kindly note that now there is no need to use the Intel® Software Manager to install any Intel® Products. We recommend you to directly install the Intel® Parallel Studio XE 2017 Update 1 Composer Edition for Fortran Windows in your newer system and make sure compatible system requirements is matching to your newer system.
You may refer to link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-parallel-studio-xe-release-notes-and-new-features.html#inpage-nav-3, and check the Intel® Parallel Studio XE 2017 Update 1 release notes then confirm the compatible hardware & software requirements for your Intel® Product.
I think there is a misunderstanding here:
Installing the compiler and integrating it with VisualStudio in the new computer is not the problem.
The problem is that I can not compile any Fortran files, as the compiler is complaining about a missing license, something about FlexLM not finding a suitable license file.
As far as I know the Software Manager is needed to attach/import/get/... a license for that new computer, right? The "Add Serial Number" button on the "Licenses"-tab does not work.
Hi Jens, we have sent you a private message and asked for some confidential information related to your query. Kindly share the details via a private message.
Hi Jens, please note that the Intel® Software Manager servers recently went down permanently.
You may use your Intel® Registration Center account for the same purpose as the Intel® Software Manager. The information & features that were found on the Intel® Software Manager were available via the Intel® Registration Center's server.
Intel® Registration Center Link: https://lemcenter.intel.com
Thanks for the information, it turns out that if you do not have a currently active support subscription it is no longer possible to move a named license from one computer to another. Disappointing, but that apparently is the current situation.
So the license in question is no longer usable, I have to look for alternatives such a a different compiler.
Hi Jens, we understand your concern. We would recommend you to use latest Intel® oneAPI Base & HPC Toolkit, which is free available for every users.
Please note that Intel® has decided that Intel® oneAPI Toolkits Versions: 2023.1.0 and earlier are not supported anymore. We urge users to upgrade to the latest version of Intel® developer tools. The unsupported versions do not include the latest functional and security updates. These versions are targeted to be removed after a period.
For more information refer to the link: https://www.intel.com/content/www/us/en/developer/articles/release-notes/oneapi-supported-product-versions.htm, and scroll down to the Unsupported Product Versions.
Hi Jens, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
