oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1380 Discussions
Offline installation of Python 2023.1.0 hangs on Linux RedHat 8.6
NicolasR
I am trying to install the Python 2023.1.0 product on a Linux server running RedHat 8.6.
I am using the command line as bellow:
sudo sh ./l_pythoni39_oneapi_p_2023.1.0.46399_offline.sh -a -c
It start, and hangs at some point around 87% without notice:
Installation in Progress | Intel® Distribution for Python*
Checking integrity license.htm
##################################################### 100%
Installing 15 of 16: Intel® Distribution for Python*
#######################################--------------  87%
It seems however that there is an "installer" process which runs in the background:
PID USER   PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
2688820 root  20   0 3814320  53276  32624 S  99.7   0.0  32:50.07 installer
Thank you
Nicolas
ArpanB_Intel
Hi Nicolas, please share the below information with us:
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on your system
- Is the installer an online or an offline package?
- Screenshots of the error screen
- Installation Log files.
The default path for a log file for a oneAPI installation is: opt/intel/oneapi/logs
The default path for a log file for a Parallel Studio XE installation is: /tmp/intel.pset.<user>.<machine>.<timestamp>.log
We would like to know.
NicolasR
Intel OneAPI 2021.4.0
Offline, I did install successfully the below:
l_BaseKit_p_2023.1.0.46401_offline.sh
l_fortran-compiler_p_2023.1.0.46348_offline.sh
That one is failing: l_pythoni39_oneapi_p_2023.1.0.46399_offline.sh
This is a CLI session, the error is shown in my first post, it just hangs forever (I let it ran for 24h and it didn't change anything)
They are provided in my first post.
Thank you
Nicolas
ArpanB_Intel
Nicolas, thank you for the confirmation.
Please note that installation of Intel® Distribution of Python will fail if bzip2 is not installed on a Linux machine.Bzip2 is required to extract packages, and a system without this software will result in an installation failure. This is a known issue with regards to the installation of the toolkits.
NicolasR
we do have bzip2 installed on this server:
rpm -qa | grep bzip2
bzip2-libs-1.0.6-26.el8.x86_64
libknet1-compress-bzip2-plugin-1.22-1.el8.x86_64
bzip2-1.0.6-26.el8.x86_64
bzip2 -V
bzip2, a block-sorting file compressor. Version 1.0.6, 6-Sept-2010.
So there might be something else ?
Nicolas
ArpanB_Intel
Nicolas, we have been confirmed that the installer does not support terminal size less than 80x24 characters. Could you resize your terminal size to 80x24 characters or greater before launching the installer?
ArpanB_Intel
Nicolas, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
