oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1700 Discussions
OneAPI 2025.1.1.34 + A certificate chain could not be built to a trusted root authority
Doug_2025
We are working on a project to install the above mentioned version of OneAPI and keep running into the same error. "A certificate chain could not be built to a trusted root authority."
This is a new install and Visual Studio 2022 17.10 is successfully installed offline, as the target computers for this installation are all air gapped. And yes the Desktop development with C++ was installed without any errors.
When attempting to do the OneAPI offline install it keeps failing with the cert authority message above, and we utilize the command intel-oneapi-base-toolkit-2025.1.1.34_offline.exe -a --silent --eula accept but again it fails with the cert message?
In previous attempts I did install a new cert chain from the internal CA authority, but it still fails.
We are installing on windows 10 21h2.
Visual studio was installed successfully and the system rebooted, but we can not get OneAPI to install.
I have searched the community and found other posts, but none of them listed any kind of resolution or fix.
Any ideas/help would be appreciated.
Doug
Deeksha_S_Intel
Hi Doug, thank you for bringing your concern to our attention.
  • Are there any other versions of Intel® Parallel Studio XE or Intel® oneAPI installed on your system? If so, please let us know the exact version of Microsoft Visual Studio integrated with Intel® Parallel Studio XE or Intel® oneAPI Toolkit on your current system.
  • A screenshot of the error.
  • Installation Log files.
    • The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
To assist you further, we would require these details.
Doug_2025
Deeksha,
Thanks for the response.
There are no other intel products installed on the computer.
Here is the log file, but it's from the installation in appdata\local\temp as the directory you specified doesn't exist yet.
I've also included a screen shot of the error.
06/10/2025 09:49:21:751 : 2816 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --silent --eula accept --log-dir C:/Users/userid/AppData/Local/Temp/intel_oneapi_installer/2025.06.10.09.49.16.293 --product-id intel.oneapi.win.basekit.product --product-ver 2025.1.1+32 --package-path C:\Users\userid\Downloads\intel-oneapi-base-toolkit-2025.1.1.34_offline\packages
06/10/2025 09:49:21:752 : 2816 : MESSAGE : Installer is started in silent mode
06/10/2025 09:49:21:752 : 2816 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.4.1.2099
06/10/2025 09:49:21:752 : 2816 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.4.1-2099
06/10/2025 09:49:21:752 : 2816 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2025.1.1+32. Mode is set to install.
06/10/2025 09:49:22:499 : 4232 : MESSAGE : PreRequisite for other install successfully checked
06/10/2025 09:49:22:508 : 4232 : MESSAGE : PreRequisite for other Intel install successfully checked
06/10/2025 09:49:22:519 : 4232 : MESSAGE : All checks for preRequisite for supported operation system are passed
06/10/2025 09:49:26:636 : 4232 : WARNING : Custom preRequisite finished with unsuccessful exit code '1'.
06/10/2025 09:49:26:644 : 4232 : MESSAGE : PreRequisite for admin rights successfully checked
06/10/2025 09:49:26:644 : 4232 : MESSAGE : PreRequisite for temporary folder successfully checked
06/10/2025 09:49:26:645 : 4232 : MESSAGE : PreRequisite for host architecture successfully checked
06/10/2025 09:49:26:816 : 8392 : MESSAGE : PreRequisite for Instance Msi successfully checked
06/10/2025 09:49:27:036 : 8392 : MESSAGE : PreRequisite for free disk space passed
06/10/2025 09:49:27:042 : 8392 : MESSAGE : PreRequisite for permissions passed
06/10/2025 09:49:27:043 : 8392 : MESSAGE : PreRequisite for empty dir is passed
06/10/2025 09:49:27:043 : 8392 : MESSAGE : PreRequisite for other install successfully checked
06/10/2025 09:49:27:043 : 8392 : MESSAGE : PreRequisite for other Intel install successfully checked
06/10/2025 09:49:27:083 : 8392 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2022] passed
06/10/2025 09:49:27:083 : 8392 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
06/10/2025 09:49:27:115 : 8392 : MESSAGE : Check for blocking processes passed
06/10/2025 09:49:27:142 : 8392 : MESSAGE : Check for blocking processes passed
06/10/2025 09:49:27:186 : 2816 : MESSAGE : Product installation directory is C:\Program Files (x86)\Intel\oneAPI
06/10/2025 09:49:27:186 : 2816 : MESSAGE : Product installation size required: 18507671598 bytes
06/10/2025 09:49:27:186 : 2816 : MESSAGE : Product will be (un)integrated with the following IDEs:
06/10/2025 09:49:27:187 : 2816 : MESSAGE : Microsoft Visual Studio* 2022.
06/10/2025 09:49:27:187 : 2816 : MESSAGE : End of IDE list.
06/10/2025 09:49:27:218 : 8392 : MESSAGE : Graph State Dump.
intel.oneapi.win.basekit.product,v=2025.1.1+32, Enabled, Selected, Not Installed
intel.oneapi.win.basekit.getting_started,v=2025.1.1+32, Enabled, Selected, Not Installed
intel.oneapi.win.tlt,v=2025.1.0+291, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2025.1.0+360, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vs2019_links,v=2025.1.0+360, Disabled, Not Selected, Not Installed
intel.oneapi.win.oneapi-common.vs2022_links,v=2025.1.0+360, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2025.1.0+360, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.oneapi-vars,v=2025.1.0+360, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.common,v=2025.1.0+453, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2019,v=2025.1.0+453, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2022,v=2025.1.0+453, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger,v=2025.1.1+7, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2025.1.1+7, Disabled, Not Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-fee-vs2019,v=2025.1.1+7, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2025.1.1+7, Disabled, Not Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-vsmi-vs2019,v=2025.1.1+7, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2025.1.1+7, Enabled, Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-fee-vs2022,v=2025.1.1+7, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2025.1.1+7, Enabled, Selected, Not Installed
intel-oneapi-win-dpcpp_debugger-vsix-vsmi-vs2022,v=2025.1.1+7, Enabled, Selected, Not Installed
intel.oneapi.win.dpl,v=2022.8.0+338, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.devel,v=2022.1.0+426, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.runtime,v=2022.1.0+426, Enabled, Selected, Not Installed
intel.oneapi.win.tcm,v=1.3.0+310, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.regupdater_nl,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-dpcpp-common,v=2025.1.1+9, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common,v=2025.1.1+9, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2025.1.1+9, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2025.1.1+9, Enabled, Selected, Not Installed
intel.oneapi.win.umf,v=0.10.0+356, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2025.1.1+9, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities,v=2025.1.0+369, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.common,v=2025.1.0+369, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2019,v=2025.1.0+369, Disabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2022,v=2025.1.0+369, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common_converter_nl_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common_converter_nl_vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.docs,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.docs-cpp,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique2023_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common_vs_2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.utils_vs_2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique2024_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique2025_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique2023_vsix_llvm_vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common_vs_2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.compilers-common.ide.utils_vs_2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique2024_vsix_llvm_vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique2025_vsix_llvm_vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2024_VS160.vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2025_VS160.vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS160.vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2023_VS170.vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2024_VS170.vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2025_VS170.vs2022,v=2025.1.0+164, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2019,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2022,v=2025.1.0+164, Disabled, Not Selected, Not Installed
intel.oneapi.win.ocloc,v=2025.1.4+3, Enabled, Selected, Not Installed
intel.oneapi.win.dal.devel,v=2025.5.0+7, Enabled, Selected, Not Installed
intel.oneapi.win.dal.runtime,v=2025.5.0+7, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2025.1.0+798, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2025.1.0+798, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.devel,v=2022.1.0+636, Enabled, Selected, Not Installed
intel.oneapi.win.ipp.runtime,v=2022.1.0+636, Enabled, Selected, Not Installed
intel.oneapi.win.ippcp,v=2025.1.0+388, Enabled, Selected, Not Installed
intel.oneapi.win.advisor,v=2025.1.1+20, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vsix,v=2025.1.1+20, Enabled, Selected, Not Installed
intel.oneapi.win.advisor.vs2019,v=2025.1.1+20, Disabled, Not Selected, Not Installed
intel.oneapi.win.advisor.vs2022,v=2025.1.1+20, Enabled, Selected, Not Installed
intel.oneapi.win.vtune,v=2025.3.0+16, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vsix,v=2025.3.0+16, Enabled, Selected, Not Installed
intel.oneapi.win.vtune.vs2019,v=2025.3.0+16, Disabled, Not Selected, Not Installed
intel.oneapi.win.vtune.vs2022,v=2025.3.0+16, Enabled, Selected, Not Installed
intel.oneapi.win.dnnl,v=2025.1.1+6, Enabled, Selected, Not Installed
intel.oneapi.win.intel-pti-dev,v=0.12.0+232, Enabled, Selected, Not Installed
06/10/2025 09:49:27:233 : 8392 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Protecting installation location...
Finalizing removal. It may take up to 5 minutes...
Install intel.oneapi.win.tlt,v=2025.1.0+291
Install intel.oneapi.win.basekit.getting_started,v=2025.1.1+32
Install intel.oneapi.win.oneapi-common.vs2022_links,v=2025.1.0+360
Install intel.oneapi.win.oneapi-common.vars,v=2025.1.0+360
Install intel.oneapi.win.oneapi-common.licensing,v=2025.1.0+360
Install intel.oneapi.win.oneapi-common.oneapi-vars,v=2025.1.0+360
Install intel.oneapi.win.dpcpp_ct.vs2022,v=2025.1.0+453
Install intel.oneapi.win.dpcpp_ct.common,v=2025.1.0+453
Install intel-oneapi-win-dpcpp_debugger-vsix-fee-vs2022,v=2025.1.1+7
Install intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2025.1.1+7
Install intel-oneapi-win-dpcpp_debugger-vsix-vsmi-vs2022,v=2025.1.1+7
Install intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2025.1.1+7
Install intel.oneapi.win.dpcpp_debugger,v=2025.1.1+7
Install intel.oneapi.win.dpl,v=2022.8.0+338
Install intel.oneapi.win.tcm,v=1.3.0+310
Install intel.oneapi.win.tbb.runtime,v=2022.1.0+426
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2025.1.0+164
Install intel.oneapi.win.compilers-common.ide.regupdater_nl,v=2025.1.0+164
Install intel.oneapi.win.tbb.devel,v=2022.1.0+426
Install intel.oneapi.win.umf,v=0.10.0+356
Install intel.oneapi.win.openmp,v=2025.1.1+9
Install intel.oneapi.win.compilers-common-runtime,v=2025.1.1+9
Install intel.oneapi.win.compilers-common,v=2025.1.1+9
Install intel.oneapi.win.cpp-base-pro-common-runtime,v=2025.1.1+9
Install intel.oneapi.win.dev-utilities.vs2022,v=2025.1.0+369
Install intel.oneapi.win.dev-utilities.common,v=2025.1.0+369
Install intel.oneapi.win.dev-utilities,v=2025.1.0+369
Install intel.oneapi.win.compilers-common.ide.common_converter_nl_vs2022,v=2025.1.0+164
Install intel.oneapi.win.compilers-common.ide.docs,v=2025.1.0+164
Install intel.oneapi.win.compilers-common.ide.docs-cpp,v=2025.1.0+164
Install intel.oneapi.win.compilers-common.ide.common,v=2025.1.0+164
Install intel.oneapi.win.compilers-common.ide.utils_vs_2022,v=2025.1.0+164
Install intel.oneapi.win.compilers-common.ide.common_vs_2022,v=2025.1.0+164
Install intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2022,v=2025.1.0+164
Install intel.oneapi.win.cpp-compiler.ide.unique2025_vsix_llvm_vs2022,v=2025.1.0+164
Install intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2022,v=2025.1.0+164
Install intel.oneapi.win.dpcpp-compiler.ide.vs2022,v=2025.1.0+164
Install intel.oneapi.win.dpcpp-compiler.ide_shared.vs2022,v=2025.1.0+164
Install intel.oneapi.win.dpcpp-compiler.ide_unique2025_VS170.vs2022,v=2025.1.0+164
Install intel.oneapi.win.ocloc,v=2025.1.4+3
Install intel.oneapi.win.cpp-dpcpp-common,v=2025.1.1+9
Install intel.oneapi.win.dal.runtime,v=2025.5.0+7
Install intel.oneapi.win.mkl.runtime,v=2025.1.0+798
Install intel.oneapi.win.mkl.devel,v=2025.1.0+798
Install intel.oneapi.win.dal.devel,v=2025.5.0+7
Install intel.oneapi.win.ipp.runtime,v=2022.1.0+636
Install intel.oneapi.win.ipp.devel,v=2022.1.0+636
Install intel.oneapi.win.ippcp,v=2025.1.0+388
Install intel.oneapi.win.advisor.vsix,v=2025.1.1+20
Install intel.oneapi.win.advisor.vs2022,v=2025.1.1+20
Install intel.oneapi.win.advisor,v=2025.1.1+20
Install intel.oneapi.win.vtune.vsix,v=2025.3.0+16
Install intel.oneapi.win.vtune.vs2022,v=2025.3.0+16
Install intel.oneapi.win.vtune,v=2025.3.0+16
Install intel.oneapi.win.dnnl,v=2025.1.1+6
Install intel.oneapi.win.intel-pti-dev,v=0.12.0+232
Install intel.oneapi.win.basekit.product,v=2025.1.1+32
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
06/10/2025 09:49:29:755 : 8392 : MESSAGE : Start install/modify sequence execution.
06/10/2025 09:49:29:823 : 8392 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1749563367218205'.
06/10/2025 09:49:29:823 : 8392 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1749563367218205' execution is finished with status Success.
06/10/2025 09:49:29:823 : 8392 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1749563367218205'.
06/10/2025 09:49:29:823 : 8392 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1749563367218205' execution is finished with status Success.
06/10/2025 09:49:29:823 : 8392 : MESSAGE : Starting execution of operation 'protect.operation.intel.sessionmanifest.1749563367218205'.
06/10/2025 09:49:30:540 : 8392 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1749563367218205' execution is finished with status Success.
06/10/2025 09:49:30:540 : 8392 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1749563367218206'.
06/10/2025 09:49:30:540 : 8392 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1749563367218206' execution is finished with status Success.
06/10/2025 09:49:30:540 : 8392 : MESSAGE : Starting execution of operation 'intel.oneapi.win.tlt,v=2025.1.0+291'.
06/10/2025 09:49:38:463 : 8392 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.tlt
Name: Toolkit Linking Tool
Version: 2025.1.0+291.
During the execution of the application 'C:\windows\system32\WindowsPowerShell\v1.0\powershell.exe' with arguments '-NoLogo -NoProfile -NonInteractive -ExecutionPolicy AllSigned -File C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.tlt,v=2025.1.0+291\latest_symlink_post_install.ps1 -installDir C:\Program Files (x86)\Intel\oneAPI -linkTargetVersion 2025.1 -latestLinkDir toolkit_linking_tool' errors were received:
File
cannot be loaded. A certificate chain could not be built to a trusted root authority.
+ CategoryInfo : SecurityError: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : UnauthorizedAccess
During the execution of the application 'C:\windows\system32\WindowsPowerShell\v1.0\powershell.exe' with arguments '-NoLogo -NoProfile -NonInteractive -ExecutionPolicy AllSigned -File C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.tlt,v=2025.1.0+291\latest_symlink_pre_remove.ps1 -installDir C:\Program Files (x86)\Intel\oneAPI -linkTargetVersion 2025.1 -latestLinkDir toolkit_linking_tool' errors were received:
File
During the execution of the application 'C:\windows\system32\WindowsPowerShell\v1.0\powershell.exe' with arguments '-NoLogo -NoProfile -NonInteractive -ExecutionPolicy AllSigned -File C:\ProgramData\Intel\InstallerCache\DownloadCache\intel.oneapi.win.tlt,v=2025.1.0+291\latest_symlink_post_remove.ps1 -installDir C:\Program Files (x86)\Intel\oneAPI -linkTargetVersion 2025.1 -latestLinkDir toolkit_linking_tool' errors were received:
File
Error: Sequence execution failed.
06/10/2025 09:49:38:463 : 8392 : MESSAGE : Operation 'intel.oneapi.win.tlt,v=2025.1.0+291' execution is finished with status Fail.
06/10/2025 09:49:38:464 : 8392 : MESSAGE : Starting rollback of operation 'complete.operation.intel.sessionmanifest.1749563367218206'.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1749563367218206' rollback is finished with status Success.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Starting rollback of operation 'protect.operation.intel.sessionmanifest.1749563367218205'.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1749563367218205' rollback is finished with status Success.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1749563367218205'.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1749563367218205' rollback is finished with status Success.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1749563367218205'.
06/10/2025 09:49:38:847 : 8392 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1749563367218205' rollback is finished with status Success.
06/10/2025 09:49:38:847 : 8392 : ERROR : Install sequence execution status: Rollback
06/10/2025 09:49:38:850 : 2816 : MESSAGE : ----------------------------------------------------------------------------------------------------
06/10/2025 09:49:38:850 : 2816 : MESSAGE : Anonymous statistics fields:
06/10/2025 09:49:38:850 : 2816 : MESSAGE : EventId = 'install-min'
06/10/2025 09:49:38:850 : 2816 : MESSAGE : EventKey = 'S3UqiDQDs0egwqo7y1z17w=='
06/10/2025 09:49:38:850 : 2816 : MESSAGE : EventTime = ''
06/10/2025 09:49:38:850 : 2816 : MESSAGE : Id = 'intel.oneapi.win.basekit.product,v=2025.1.1+32'
06/10/2025 09:49:38:850 : 2816 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Base Toolkit 2025.1\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4627\", \"product_tag\":\"\" }'
06/10/2025 09:49:38:850 : 2816 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Base Toolkit 2025.1'
Doug_2025
I've tried to reply 4 times, using 3 different browsers....nothing seems to post?
Doug_2025
no other intel products installed.
Visual studio 2022 17.10
Doug_2025
File
File
File
Doug_2025
I'll try again this time I'll attach the log file, which comes from appdata\temp since the product isn't installed the program files x86 directory for intel does not exist.
Doug_2025
Deeksha,
There are no other versions of intel software on the computer.
Visual Studio 2022 17.10. I've attached the screen shot of the error.
The log directory does not exist as it hasn't complete the installation.
This is from the installation log in the %userid%\appdata\local\temp\ and is the latest attempt.
File
File
File
Doug_2025
Deeksha,
Visual studio is 2022 17.10.
The log file is not located there as it hasn't installed, but there is one in the temp directory from the install attempt. Here is the end of it.
File
File
File
Doug_2025
Guess I couldn't post the whole reply in one post, but finally got it there.
Deeksha_S_Intel
Hi Doug, we have sent you a private message. Kindly check your community inbox.
Vipin_S_Intel
Doug_2025
How do I review the reply again, when I go to my inbox it doesn't show any messages?
Doug
Vipin_S_Intel
Hi Doug, no need to worry. I have resent our previous reply. Please follow the steps outlined and let us know the outcome. You can reply here with any updates as well.
Thanks!
Doug_2025
Vipin,
I've installed the version you specified and still get the same result after running the command.
./intel-oneapi-base-toolkit-2025.1.1.34_offline.exe -s -a --silent --eula accept
I've attached the screen shot.
Doug
Vipin_S_Intel
Hi Doug,
Thank you so much for your response — really appreciate your time and support.
To help us investigate this further, could you please share a clear screenshot or image of the complete script or commands you executed? This includes everything from uninstalling Visual Studio and the toolkits, to reinstalling Visual Studio and then the toolkits — either as per the steps we suggested, or kindly let us know if you followed a different approach.
We’ve also attached our screenshots showing a successful installation. Having your exact steps will help us compare and troubleshoot more effectively.
Thanks again for your cooperation — it truly helps us move ahead with clarity.
Doug_2025
Vipin,
I used the add/remove applet in Windows to uninstall the Visual Studio 17.10 version from the computer, deleted anything in the program files (x86) directory that was left.  Rebooted, cleaned up the %userid&\appdata\temp directory.
I then installed the visual studio version you specified using the, G:\Vis1712\vs_setup.exe --noWeb --channelURI G:\Vis1712\ChannelManifest.json. Again this is in an air gapped environment so I had to build the offline package, per microsoft's instructions, and then install it on the target computer using the above command.
Once that was completed and the system rebooted again, I executed the command from the instructions you sent,  ./intel-oneapi-base-toolkit-2025.1.1.34_offline.exe -s -a --silent --eula accept , which is where I get the certificate chain error messages.
I have manually installed the certificate chain from the domain's certificate authority and the certificate for the domain certificate authority also. But still this error persists.
Is there an option to install with it building it's own certificate chain since the latest from the domain has already been installed?
Not sure why it has to build a new certificate chain if one already exists?
Doug
Deeksha_S_Intel
Hi Doug, we would like to inform you that we are escalating your query to the engineering team for further assistance.
Doug_2025
Deeksha,
Any idea on time frame of when we may hear something back?
Doug
Deeksha_S_Intel
Dear Doug_2025,
Thank you for your patience. We apologize for the inconvenience this may have caused to you. Our engineering team is currently working diligently to resolve your case. We understand the importance of this matter and will ensure to get back to you as soon as possible.
Your understanding is greatly appreciated.
Haarika
Hello Doug,
Thank you for your patience. The engineering team has analyzed the logs that you shared and got some idea about the issue here.
Generally installer has an option to ignore errors related to scripts, but probably installation of toolkit will be not fully workable as a lot of stuff is created through scripts right now. so we need to understand the environment properly so that we can provide some information about how to install the required certificates.
The log file installer.install.intel.oneapi.win.basekit.product,v=2025.1.1+32.2025.06.10.09.49.21.496816.log that you shared has some information which was helpful. The other log from "latest_install_attempt.txt" is related to installer self removal.
We need some more information to make the right recommendation to resolve your issue.
Can you please send all the logs from the temp folder location?
The path to log location is %temp%\intel_oneapi_installer\<timestamp>
There will be more than one log in the path for example: C:/Users/userid/AppData/Local/Temp/intel_oneapi_installer/2025.06.10.09.49.16.293
We request you to make another run to collect fresh logs and full set of logs from the similar path and share the full set of logs with us for further analysis.
Also can you please provide some information on how is your air-gap environment prepared and are you using any scripts that run the installers etc.?
Haarika M
