oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
1133 Discussions
OneAPI Base Toolkit erroneously reports "Another program is being installed"
TomV
While installing the latest ./l_BaseKit_p_2022.3.0.8767_offline.sh I get the following error:
Another program is being installed.
Wait until that installation is complete, and then try installing this software again.
A previous attempt at installing aborted, so there is no installation being performed. The installer does not provide a suggestion on how to override this check. The graphical installer also seems more reliable than the CLI installer which often hangs if graphics are not available (CentOS 7). A solid CLI installer would be much appreciated, as it is much simpler to admin via a CLI installer in many environments.
ArpanB_Intel
Thomas, one workaround would be to check the list of running processes currently active in the background. Once that is done, you would need to find the running process of installation and kill them. You could kill a process using the process ID. The command would be: kill -9 #PID
Only then will you be able to install the current Intel® oneAPI Base Toolkit.
ArpanB_Intel
Hi Thomas, we would suggest you should try the steps given in the below link to uninstall the product properly and you will also find the steps to install them back again correctly.
Link - https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/uninstall-oneapi-toolkits-and-components.html
Note - Post uninstallation, make sure to restart your system.
Please try the above steps and let us know if your issue persists.
TomV
Is there a way to avoid scheduling a reboot? It is a shared system with many users.
TomV
The /opt/intel/oneapi/installer directory doesn't exist, so I am unable to run the "Uninstall using GUI" and "Uninstall Using Silent CLI" instructions in the provided URL.
TomV
Do you know how it is checking to bypass? I think its simply erroneous. Running the installer with "-a -c --ignore-errors" flags does not bypass this error, might be bug with "--ignore-errors" flag. The "-c" flag fixes the hangs after unpacked if I'm SSHed into a server via Cygwin...there might be an issue with autodetecting GUI support for Cygwin clients and falling back to CLI.
ArpanB_Intel
TomV
There was a process "installer" consuming 100% CPU that was stuck for days. Killing it (-9 / SIGKILL didn't end up being necessary) allowed for me to restart the Intel BaseKit installer.
ArpanB_Intel
Thomas, thank you for accepting our solution. We are glad that the issue was resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
