Last month, I was able to install multiple Intel kits with the following command:
yum install -y intel-basekit-2021.1.0.x86_64 intel-hpckit-2021.1.0.x86_64
However, today, I am receiving new packaging conflicts.
Last metadata expiration check: 0:00:56 ago on Tue May 30 22:21:11 2023.
Error:
Problem 1: package intel-oneapi-advisor-2023.1.0-43480.x86_64 conflicts with intel-oneapi-common-licensing < 2021.2.0 provided by intel-oneapi-common-licensing-2021.1.1-2021.1.1-60.noarch
- package intel-basekit-2021.1.0-2021.1.0-2659.x86_64 requires intel-oneapi-common-licensing-2021.1.1, but none of the providers can be installed
- package intel-basekit-2021.1.0-2021.1.0-2659.x86_64 requires intel-oneapi-advisor >= 2021.1.1-43, but none of the providers can be installed
- conflicting requests
Problem 2: package intel-oneapi-vtune-2023.1.0-44286.x86_64 conflicts with intel-oneapi-common-licensing < 2021.2.0 provided by intel-oneapi-common-licensing-2021.1.1-2021.1.1-60.noarch
- package intel-basekit-2021.1.0-2021.1.0-2659.x86_64 requires intel-oneapi-vtune >= 2021.1.1-61, but none of the providers can be installed
- package intel-hpckit-2021.1.0-2021.1.0-2684.x86_64 requires intel-oneapi-common-licensing-2021.1.1, but none of the providers can be installed
- package intel-hpckit-2021.1.0-2021.1.0-2684.x86_64 requires intel-basekit-2021.1.0, but none of the providers can be installed
It appears that the kits are pulling in various 2023 packages, which are causing this issue. Does anyone know what changed?
Thanks in advance!
Joshua
Hi Joshua, please share the below information:
- Linux distribution on which you are installing the software
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on your system
- Is the installer an online or an offline package?
- Screenshots of the error screen
- Installation Log files
The default path for a log file for a oneAPI installation is: opt/intel/oneapi/logs
The default path for a log file for a Parallel Studio XE installation is: /tmp/intel.pset.<user>.<machine>.<timestamp>.log
We would like to know.
Thank you for your response, and my apologies for not including those details. This is occurring on a fresh build with Rocky Linux 8.7. An apptainer image can be created using the following recipe:
Bootstrap: docker
IncludeCmd: yes
# sudo apptainer build --sandbox ~/path-to-new-container thisfile.def
%post
yum clean all && dnf clean all && rm -r /var/cache/dnf && dnf upgrade -y && dnf update -y
yum repolist
yum install -y yum-utils
tee > /tmp/oneAPI.repo << EOF
[oneAPI]
name=Intel(R) oneAPI repository
baseurl=https://yum.repos.intel.com/oneapi
enabled=1
gpgcheck=1
repo_gpgcheck=0
gpgkey=https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
EOF
mv /tmp/oneAPI.repo /etc/yum.repos.d
yum update
yum groupinstall -y "Development Tools"
Joshua, there are tools in the toolkit that are not supported on the Rocky Linux 8 and 9. We suggest you to try installation on:
- Red Hat Enterprise Linux* 8, 9
- SUSE Linux Enterprise Server* 15 SP3, SP4
- Ubuntu* 20.04, 22.04
- Debian* 9, 10
- Amazon Linux 2
Joshua, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
