oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Re: DEB-based installer bug
msz59
Same problem on my Ubuntu VERSION="22.04.3 LTS (Jammy Jellyfish)". I always do fresh install of new oneAPI version after purging all previously installed packages. 'apt' tends to install new versions parallel to those already installed, instead of upgrading them
Such a clean install works fine but then, the above mentioned 4 packages are constantly reported as upgradable.
MartinSchreiber
I have the same problem in Ubuntu 23.04
Marcelo2
same problem in Ubuntu 20.04.6.
When I run the command:
$ apt policy intel-oneapi-compiler-cpp-eclipse-cfg
intel-oneapi-compiler-cpp-eclipse-cfg:
Installed: 2023.2.1-16
Candidate: 2023.2.1-16
Version table:
2023.2.1-16 500
500 https://apt.repos.intel.com/oneapi all/main all Packages
*** 2023.2.1-16 100
Eventually should it be "*** 2023.2.1-16 500"?
At least it is what I get for:
$ apt policy intel-oneapi-advisor
intel-oneapi-advisor:
Installed: 2023.2.0-49486
Candidate: 2023.2.0-49486
Version table:
*** 2023.2.0-49486 500
500 https://apt.repos.intel.com/oneapi all/main amd64 Packages
100 /var/lib/dpkg/status
2023.1.0-43480 500
That don't have this problem of  endless upgrade.
RahulC_Intel
Hi Michal, could you please share the below details for further investigation:
  • Correct version of Intel® oneAPI you are installing.
  • Name of 4 packages which always shows for upgrade.
  • Screenshot of an error.
Jellby1
I'm not Michal, but I'm getting this in Ubuntu 22.04:
$ sudo apt full-upgrade
The following packages will be upgraded:
 intel-oneapi-compiler-cpp-eclipse-cfg intel-oneapi-compiler-dpcpp-cpp intel-oneapi-compiler-dpcpp-eclipse-cfg intel-oneapi-compiler-fortran
4 to upgrade, 0 to newly install, 0 to remove and 18 not to upgrade.
Need to get 0 B/7,708 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 487854 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-compiler-cpp-eclipse-cfg_2023.2.1-16_all.deb ...
Unpacking intel-oneapi-compiler-cpp-eclipse-cfg (2023.2.1-16) over (2023.2.1-16) ...
Preparing to unpack .../intel-oneapi-compiler-dpcpp-cpp_2023.2.1-16_amd64.deb ...
Unpacking intel-oneapi-compiler-dpcpp-cpp (2023.2.1-16) over (2023.2.1-16) ...
Preparing to unpack .../intel-oneapi-compiler-dpcpp-eclipse-cfg_2023.2.1-16_all.deb ...
Unpacking intel-oneapi-compiler-dpcpp-eclipse-cfg (2023.2.1-16) over (2023.2.1-16) ...
Preparing to unpack .../intel-oneapi-compiler-fortran_2023.2.1-16_amd64.deb ...
Unpacking intel-oneapi-compiler-fortran (2023.2.1-16) over (2023.2.1-16) ...
Setting up intel-oneapi-compiler-cpp-eclipse-cfg (2023.2.1-16) ...
Setting up intel-oneapi-compiler-dpcpp-cpp (2023.2.1-16) ...
Setting up intel-oneapi-compiler-dpcpp-eclipse-cfg (2023.2.1-16) ...
Setting up intel-oneapi-compiler-fortran (2023.2.1-16) ...
Note that the same packages are still to be upgraded, and that it's installing the same version that's already there.
RahulC_Intel
Hi All,
Thanks for your feedback. We have passed on your valuable feedbacks to our engineering team for further consideration. The issue will be fixed in the next release.
RahulC_Intel
Hi Michal, unfortunately we were unable to hear back from you.
If you have any further query, please post a new question as this thread will no longer be monitored by Intel®.
