oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Re: DEB-based installer bug
ygrec
I can confirm this is also happening in Ubuntu 23.04.
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
# You can verify the status of security fixes using the `pro fix` command.
# E.g., a recent Ruby vulnerability can be checked with: `pro fix USN-6219-1`
# For more detail see: https://ubuntu.com/security/notices/USN-6219-1
The following packages will be upgraded:
  intel-oneapi-compiler-cpp-eclipse-cfg intel-oneapi-compiler-dpcpp-cpp intel-oneapi-compiler-dpcpp-eclipse-cfg
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,924 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-compiler-cpp-eclipse-cfg all 2023.2.1-16 [2,100 B]
Get:2 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-compiler-dpcpp-cpp amd64 2023.2.1-16 [1,764 B]
Get:3 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-compiler-dpcpp-eclipse-cfg all 2023.2.1-16 [2,060 B]
Fetched 5,924 B in 0s (50.4 kB/s)
(Reading database ... 318578 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-compiler-cpp-eclipse-cfg_2023.2.1-16_all.deb ...
Unpacking intel-oneapi-compiler-cpp-eclipse-cfg (2023.2.1-16) over (2023.2.1-16) ...
Preparing to unpack .../intel-oneapi-compiler-dpcpp-cpp_2023.2.1-16_amd64.deb ...
Unpacking intel-oneapi-compiler-dpcpp-cpp (2023.2.1-16) over (2023.2.1-16) ...
Preparing to unpack .../intel-oneapi-compiler-dpcpp-eclipse-cfg_2023.2.1-16_all.deb ...
Unpacking intel-oneapi-compiler-dpcpp-eclipse-cfg (2023.2.1-16) over (2023.2.1-16) ...
Setting up intel-oneapi-compiler-cpp-eclipse-cfg (2023.2.1-16) ...
Setting up intel-oneapi-compiler-dpcpp-cpp (2023.2.1-16) ...
Setting up intel-oneapi-compiler-dpcpp-eclipse-cfg (2023.2.1-16) ...
$ sudo apt upgrade
Fetched 5,924 B in 0s (47.4 kB/s)
$ apt list --upgradable
Listing... Done
intel-oneapi-compiler-cpp-eclipse-cfg/all 2023.2.1-16 all [upgradable from: 2023.2.1-16]
intel-oneapi-compiler-dpcpp-cpp/all 2023.2.1-16 amd64 [upgradable from: 2023.2.1-16]
intel-oneapi-compiler-dpcpp-eclipse-cfg/all 2023.2.1-16 all [upgradable from: 2023.2.1-16]
$ sudo apt upgrade
Fetched 5,924 B in 0s (34.3 kB/s)
Listing... Done
FWIW, /opt/intel/oneapi/logs does not exist
ArpanB_Intel
Hi Ygrec, could you let us know whether the installation was successful?
We would like to know.
ygrec
Hi @ArpanB_Intel
Installation of oneapi using the deb installer was all fine as I can compile, link and run my libraries all fine.
What is strange is the endless loop of installation recommendations for the three packages:
You can see the currently installed version is the same as the new version!
I hope this helps.
Kind regards
ArpanB_Intel
Ygrec, thank you for sharing your findings with us. We will check and get back to you soon on this issue.
ArpanB_Intel
Ygrec, we believe the issue has been addressed. Could you check if you are still facing the issue?
ygrec
Hi @ArpanB_Intel
Due to some system issues I had to change distros, sorry I cannot confirm if the issue has been resolved.
Thank you for your time and efforts.
ArpanB_Intel
Ygrec, thank you for sharing the update.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
