I cannot install this new version w_BaseKit_p_2022.1.3.210
Microsoft Visual Studio Enterprise 2022 (64-bit) - Version 17.1.1
Currently installed is w_BaseKit_p_2022.1.0.116
This is a part from the installaion log.
03/09/2022 10:19:47:997 : 19212 : MESSAGE : Start install/modify sequence execution.
03/09/2022 10:19:48:254 : 19212 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1646817587631994'.
03/09/2022 10:19:48:254 : 19212 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1646817587631994' execution is finished with status Success.
03/09/2022 10:19:48:254 : 19212 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1646817587631994'.
03/09/2022 10:19:48:254 : 19212 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1646817587631994' execution is finished with status Success.
03/09/2022 10:19:48:256 : 19212 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2022,v=2022.0.0-97'.
03/09/2022 10:19:53:017 : 19212 : ERROR : Removal of component has failed.
Component id: intel.oneapi.win.dpcpp_ct.vs2022, name: Intel® DPC++ Compatibility Tool, version: 2022.0.0-97.
Error: Sequence execution failed.
It seems, that only the part of a full new installaltion is fixed.
But i updatet my Visual Studio to Version 17.1 and 17.1.1 after installation of Intel 2022.1.0
I get the same error while trying to repair the installation or to uninstall the intel baseKit.
Peter
Sorry,
but there was a lot of work to do, after loosing two days while uninstalling and installing software.
What finally worked:
- Uninstalling ALL versions of Visual Studio (2022 and 2019)
- Using %ProgramFiles(x86)%\Microsoft Visual Studio\InstallCleanup.exe
- Uninstalling ALL versions of oneAPI (Base and HPC toolkit)
- Installing Visual Studio 2022 17.1
- Installing Visual Studion 2019
- Installing Intel® oneAPI Base Toolkit 2022.1.3.
- Installing oneAPI HPC Toolkit
- Installing all other Extensions (like ReSharper, ...) for Visual Stdio 2019 / 2022
Peter
Hi PSpoenemann,
Thanks for posting your concern on the forum. Yes, you are correct. Our investigation has shown that on Microsoft* Windows*, the installation of Intel® oneAPI Toolkits versions 2022.1 and 2022.1.2 and standalone components will fail using Microsoft* Visual Studio* 2022 version 17.1.x. Its fix is provided in Intel® oneAPI Toolkits version 2022.1.3. However, on your system, to proceed the installer would have to first remove the setup that is causing the issue and then install the new version. Due to that, as you mentioned a full clean installation would work.
Kindly follow the below steps (in the mentioned order).
- Uninstall Visual Studio 2022 (64-bit) - Version 17.1.
- Download the installer for the currently installed Intel® oneAPI Base Toolkit (2022.1.0.116) and try repairing it through the installer.
- Uninstall the repaired version through the same Intel® oneAPI Base Toolkit installer
- Install Visual Studio 2022 (64-bit) - Version 17.1 with the Desktop development with C++ component selected.
- Try installing Intel® oneAPI Base Toolkit 2022.1.3.
However, do let us know if the issue persists. Have a nice day ahead.
Soumya
Didn't work.
After uninstalling Visual Studio 2022 neither repair nor uninstall of oneAPI Base Toolkit 2022.1.0.116 works.
I got the same error.
03/10/2022 10:30:29:181 : 31796 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_ct.vs2022,v=2022.0.0-97'.
03/10/2022 10:30:31:507 : 31796 : ERROR : Repair of component has failed.
I tried a reboot after uninstalling Visual Studio 2022. No change.
Here is a snippet from logging with DebugView.
00000882 678.62658691 [40500] VS2017Detect: Starting DetectVisualStudio 2017/2019/2022...
00000884 678.63189697 [40500] VS2017Detect: Loading Microsoft.VisualStudio.Setup.Configuration.Native.dll and get Com Object inter
00000885 678.63195801 [40500] face
00000887 678.63800049 [40500] VS2017Detect: Microsoft.VisualStudio.Setup.Configuration.Native.dll successfully loaded via COM inte
00000888 678.63806152 [40500] rface
00000890 678.63952637 [40500] VS2017Detect: Done
00000892 678.64062500 [40500] VS2017Detect: Get List of Visual Studio Instances
00000894 678.64154053 [40500] VS2017Detect: Done
00000896 678.64221191 [40500] VS2017Detect: Iterate all founded Visual Studio Instances
00000898 678.65264893 [40500] VS2017Detect: Done
00000900 679.39813232 [40500] CreateSymbolicLink30:ScanTable: Starting...
00000902 679.39898682 [40500] CreateSymbolicLink30:ScanTable: execute query: select Symlink_, Target_, Condition_, ReTarget_, Exc
00000903 679.39904785 [40500] lude_ from CreateSymbolicLink30
00000905 679.40307617 [40500] CreateSymbolicLink30:ScanTable:
00000907 679.40380859 [40500] CreateSymbolicLink30:ScanTable: Processing: symlink = C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\l
00000908 679.40386963 [40500] atest, target = C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\2022.0.0, condition: , re-target: 2, ex
00000909 679.40386963 [40500] clude:
00000911 679.40472412 [40500] CreateSymbolicLink30:ScanTable: There isn't condition for link creation -> link will be created
00000913 679.40557861 [40500] CreateSymbolicLink30:ScanTable:
00000915 679.40631104 [40500] Internal call: error code: 259 (No data avaliable.
00000916 679.40631104 [40500] ), call: MsiViewFetch( MsiHandl
00000917 679.40631104 [40500] e(), &record ), function:msistd::CView::Fetch, file:sources\stdInstallLib.cpp, line:493
00000919 679.40673828 [40500] Internal call: error code: 259 (No data avaliable.
00000920 679.40673828 [40500] ), call: MsiViewFetch( MsiHandle(), &record ), function:msistd::CView::Fetch, file:sources\stdInstallLib.cpp, line:493
00000921 679.40704346 [40500] CreateSymbolicLink30:ScanTable: output XML: <links><entry symlink="C:\Program Files (x86)\Intel\oneA
00000922 679.40710449 [40500] PI\dpcpp-ct\latest" target="C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\2022.0.0" re_target="2" exc
00000923 679.40716553 [40500] lude=""/></links>
00000924
I don't know, why the Installer stills wants to work with VS 2022, which is not on the machine.
And I don't want to re-install my entire computer.
Peter
Next try was to Install Version 17.06 of Visual Studio after uninstalling Version 17.1.1.
I was able to install the version, but still is repeair or remove of the oneApi Version not possible.
Peter
Intel® DPC++ Compatibility Tool was one of the components causing problems with my own attempts to update oneAPI Base Toolkit 2022.1.2 to 2022.1.3 and when that failed, to uninstall 2022.1.2 via normal methods
Hi Peter,
Thanks for the logs and details. Based on what you mentioned, it does seem that traces of Visual Studio are still on the system and are still being detected & loaded. Kindly visit the below link to find Microsoft's recommended ways to uninstall and remove Visual Studio completely.
Link: https://docs.microsoft.com/en-us/visualstudio/install/uninstall-visual-studio?view=vs-2022
Please note, the workaround steps that we had provided are to be followed in the mentioned order and only when the previous step has successfully been completed. Therefore, please proceed with them once you are done uninstalling the Visual Studio completely via the methods mentioned in the link.
However, do let us know if the issue still persists while trying to repair the toolkit product. Looking forward to your update.
Soumya
Hi Peter,
Please let us know if the issue persists.
Soumya
This issue was reported in an earlier post. The only thing that worked was install Windows again.
It actually turned out to be faster than to waste more time on an impossible fix.
It was an interesting challenge.
Hi Peter,
We understand that you might be looking into the issue. However, this is to update you that we have not heard from you on our previous responses. Please reply within the next 24 business hours to keep this ticket active.
Soumya
Sorry,
Peter
Hi Peter,
Thanks for getting back to us with the detailed update on the post. Glad to know that the issue has been resolved. Proceeding further we are closing this thread. If you need any additional information, please feel free to post a new question as this thread will no longer be monitored by Intel®.
Have a wonderful day ahead!
Soumya
